DynastyLCD
so a few weekends ago, i picked up 73/1000. my first gvr4. supposedly needed a "transmission and an FMIC" and that was the lot of it. also that the car was remarkably clean. while it is a pretty straight body, mostly clean, she has her imperfections. the body has some rust... im not very happy. i drove 5 hours for what was guaranteed to be a clean car. i got a halfway good deal on the whole thing, i suppose if i have to part it out than i could make back what i paid. til then, shes destined to be the spare parts gvr4 beater.
so far i have:
cleaned out the tons of crap that came with
installed good used trans/tcase
installed good used slave, ss clutch line
new 255hp fuel pump
removed 16g for fpgreen setup
new shifter cables (there were none...)
1g shifter
cleaned up/removed all rigged wiring
removed A/C
so when i got the car... the fuel pump housing was out, the tank was full of varnished gasoline, the pump had definetly seen better days, no shifter cables, ABS unit leaks all the brake fluid, no radiator/brackets, so on and so forth. id love to find another belize green or summit white roller and swap it all into it someday down the line... ive got to enjoy this one first. or at least try.
the good news: the key i got was a curtis brand key!
i need to buy the rest of my 5 lug stuff, got a 4 bolt rear and subframe ready just need the front spindles now. need the non-abs kit too. also need to buy a yoke recall kit as mine is so rusted i couldnt slip the transfer case on it... oh well. and the fpgreen with the manifold gate does not like the full size radiator, so half size time it is. a set of injectors, afpr, a gm map, then the VPC i got layin around goes in. got to fab some FMIC piping, and install this evo8 FMIC ive had collecting dust for so many years! so many little bits and pieces. i just want to drive the effin thing! soon enough. thanks for checkin it out.
so far i have:
new 255hp fuel pump
1g shifter
removed A/C
