some simple questions
When using a GM maf as a blow through setup, how far away from the throttle body should you mount it?
On the back of the t-stat housing is the "emergency" fan switch that turns the fans on in the event of overheating. The wire needs to be grounded to activate the fans right?
When installing the WBo2, the generally accepted location seems to be after the flex section in the down pipe. Yes? No?
Can anyone tell me the wire colors for the oil pressure dummy light switch and for the P/S pressure switch. I need to fix both and don't want to mess them up.
Thanks!
SouthCaliVR4
North county San Diego
on the wires brown to oil press & yellow with a black sleeve to ps. Not sure on the t-stat housing switch. Don't think the distance from the ttl makes any difference to the maf.
1990ggsxnj
Blackwood, NJ
I believe you're correct on the wire needing to be grounded for the fan switch.
Generally the accepted locaton is before the flex section but after the stock location. I think this is a "what better suits me" question. Do you want more accurate readings [closer to the manifold] or do you want the sensor to last longer [further from the manifold]? Just make sure it is before the bend so that moisture does not accumulate on the sensor and ruin it and always install it with the tip angling up.
CSMShaun
Cincinnati, OH
Are you running the GM MAF with ECMLink? The ECMLink wiki suggests 8" from the throttle body plate. But that would not necessarily matter if you are not running Link, or even if you are.
I have been told by tuning "pros" that the wideband needs to be a variety of distances away from the turbo. Some say 12", others says 18" or some other distance. I ran mine in the front O2 location and had no problems with sensitivity or longevity. That requires having Link, though, so the front O2 signal can be simulated. There is also a discussion about using a wideband in the front O2 location in the ECMLink wiki.
