S256 O2 Housing
doelcow
Active member
Norfolk, VA
I just purchased a Borg Warner S256NET. It has a mitsu turbine housing without a divider between the turbine outlet and the (internal) wastegate outlet. Similar to this but opened up mayabe a little more. What 02 housing should I run with it? I hate the idea of the exhaust flow running smack dab into the divider of a standard O2 housing... I thought about knife edging an EVO III O2 housing... Would that create a corrosion problem?
EMX5636
Bucks County, PA
Knife-edging the E3 housing shouldn't affect much corrosion. I don't think they are coated on the inside anyway. I think I used to remember an o2 that was also open, but I did a quick Google search, and couldn't find it, sorry.
doelcow
Active member
Norfolk, VA
I wasn't too worried about the coating. My main concern is thinning a surface that hot exhaust gases travel across. I seem to recall an O2 housing that was open all the way too... but maybe I'm just thinking of the 5 bolt O2 housing.
doelcow
Active member
Norfolk, VA
Well.. after days of search I just came up with this (and put it on order):
It's a little late but does anyone on here have any experience with them?
EMX5636
Bucks County, PA
I'm not sure if that's what I had pictured in my head, but it looks like it will flow well! Never heard of the brand, but it's cast, so it should hold up pretty well. Seems to be dense like the FP manifolds.
JNR
ca
Well, if you're concerned about a knife edge (which IMO shouldn't worry too much), then put a radius at the end.
cheekychimp
East Sussex, U.K.
Quoting doelcow:
When that arrives, could you post up some larger pictures and tell us if that will work with the stock lower heat shields.
Paul.
steve
NJ
Why, what's wrong with the pics on that website?
/ubbthreads/images/graemlins/bowroflr.gif
doelcow
Active member
Norfolk, VA
Quoting cheekychimp:
Paul.
Will do
cheekychimp
East Sussex, U.K.
Quoting steve:
ISWYDT. I thought it was my browser at first or that age was finally catching up with me and my eyesight had gone /ubbthreads/images/graemlins/rofl.gif
alansupra94
Wayne,NJ
Nothing is wrong with the picture, that is the actual size he will be getting. /ubbthreads/images/graemlins/rofl.gif
doelcow
Active member
Norfolk, VA
Quoting alansupra94:
Hopefully it'll fit...
doelcow
Active member
Norfolk, VA
It arrived about 10 minutes ago. I am VERY impressed!!
EMX5636
Bucks County, PA
Looks good indeed. I'm pretty impressed with those pictures. get it on there and test it out!
JNR
ca
Is that cast stainless? Looks nice whatever they did...
doelcow
Active member
Norfolk, VA
Yep. Cast stainless... line-up is garbage though. Just test fit it and it's going to take me a day to port match it...
doelcow
Active member
Norfolk, VA
cheekychimp
East Sussex, U.K.
Will the heat shields work with it? Are those bosses to allow you to drill and tap for mounting or only for sensors?
EMX5636
Bucks County, PA
The boss at the bottom flange looks like it's in the right place for the stock heat shield.
Port matching won't be too bad, it's less than 1/4" it appears.
