Part numbers we all need to know... with pictures.
Engine -->
Balance Shaft:
Belt - MR984778 - $22.11 - $22.64
Tensioner - MD115976 - $21.84 - $22.36
Balance Shaft Elimination:
Rear Bearing - MD103722 - $8.70 - $$$ - img - img
Front Bearing - MD040597 - $10.03 - $$$ - img
Cap - MD092785 - $6.50 - $$$ - img - img
Stub Shaft - MD098626 - $8.24 - $8.44 - img
Spacer - MD128107 - $3.37 - $3.45 - img
Timing:
Belt - MD326059 - $57.89 - $67.35 - img - img
Idler Pulley - MD129355 - $21.09 - $21.59 - img
Tensioner Arm - MD130032 - $$$ - $$$ - img
Tensioner Pulley - MD156604 - $25.78 - $26.39 - img
Adjuster - MD164533 - $64.07 - $65.58 - img
Lower Timing Cover Gaskets:
One - MD121986 - $3.92 - $4.02
Two - MD156770 - $0.93 - $0.95
Three - MD006665 - $1.92 - $2.30
Oil Seals:
Crankshaft - MD343563 - $$$ - $$$ - img - (NOK AH2554J)
Oil Pump - MD365697 - $$$ - $$$ - img - (NOK AH0984H)
Balance Shaft - MD343565 - $$$ - $$$ - img
Balance Shaft Elimination Plug - (NOK EZ2937B)
Camshaft - MD372536 - $$$ - $$$
EGR:
Blockoff plate - MD103510 - $8.86 - $$$ - img - img
Blockoff plate (newer) - MD103510 - img
Gasket - MD183535 - $0.79 - $$$ - img
Gasket - MD119127 - $1.87 - $1.87 - img
Intake Gaskets:
J-Pipe (Turbo OutletJ-Pipe) - MD189460 - $1.79 - $$$
Compressor Bypass Valve (BOV) - MR312761 - $1.28 - $$$
Throttle Body Elbow (TBElbow) - MD340327 - $1.83 - $$$
Throttle Body (TBIntake) - MD146399 - $2.69 - $2.75
Manifold (ManifoldHead) - MD176459 - $7.28 - $$$
Crank Pulley - MD376608 - $95.16 - $106.86 - img
Belts:
Power Steering - MD178430 - $ 7.53 - $7.71 - img
Alternator/Water Pump - MD186126 - $15.25 - $19.50 - img
Air Conditioning - MB568898 - $17.65 - $18.07
'90 Oil Filter Adapter - MD132912 - $55.46 $$$ - img - img - img
Oil Filter Adapter Gasket - MD149370 - $$$ - $$$
Knock Sensor - MD141510 - $61.34 - $62.79 - See below for post from gvr4737
Oil Filler Cap Gasket - MD311638 - $0.77 - $0.80
PCV Valve - MD024719 - $4.24 - $4.34
Half-Moon Seal - MD050536 - $1.92 - $1.97
03-06 EVO VIII Metal half moon seal - MD372348 - $2.04 - img
Spark Plug Hole Gasket - MD125940 - $3.59 - $$$ - img
Valve Cover Gasket - MD125939 - $19.55 - $20.01
OEM 4 layer metal headgasket - MD349347 - 8$2.96- $103.70
Engine dipstick - MD127058
Engine Dipstick tube - MD124782
Dipstick tube o-ring - MD075834
Front Cover Gasket - MD149393 ~$7.24
Rear Main Housing Gasket - MD183243 ~$1.85
Rear Main Seal - MD343564 ~$23.52
Reverse Switch - MD730979 ~$11.89
2.4L:
Crankshaft - MD080691 - $512.60 - $524.71
Crank Bearings (std) - MD091399 - $66.29 - $67.86
Rod Bearings (std) - MD071298 - $56.34 - $57.67
Cam Gear - MD189399 - $$$ - $$$
Cam Gear - MD300439 - $$$ - $$$
Timing Belt - MD182292 - $$$ - $$$
Turbo
Oiling:
Feed Line - MD140394 - $$$ - $$$
Return Line - MD150523 - $$$ - $$$
Head To Feed Crush Washer (2x) - MF660063 - $$$ - $$$
Turbo To Feed Crush Washer (2x) - MF660064 - $$$ - $$$
Return Line Gasket (2x) - MR258477 - $0.88 - $$$
Return Line To Pan Crush Washer (2x) - MF660031 - $0.06 - $$$
Cooling:
180 Degree Thermostat - MD997607 - $13.17 - $$$ - img
190 Degree (stock) Thermostat - MD997608 - $16.16 - $$$ -
Water Pump Kit - MD972052 - $95.25 - $97.50 - img
Upper Radiator Hose - MB356964 - $6.35 - $6.50
Lower Radiator Hose - MB356967 - $8.18 - $8.38
Heater Hose Kit - MB527995 - $19.08 - $19.52
Exterior:
Mitsu aftermarket roof rail kit w/ removable plates for roof rack towers - MZ540008
1993 headlight(clear) left side - MB912847
1993 headlight(clear) right side - MB912848
Interior:
Clutch/Brake Pedal Pads - MB193884 - $2.11 - $$$
Clutch Pedal Assembly - ??? - $$$ - $$$
Radio Bracket - MB861252 - $9.09 - $9.31 - img
Dual-DIN Face Plate - MB716801 - $7.67 - $$$ - img
Lower Pocket - MB424422 - $13.58 - $13.90 - img
ECS Pod (dash) - MB716913 - $$$ - $$$
Drivetrain:
Master Cylinder (Eclipse) - MB555133 - $88.60 - $90.69
Slave Cylinder (Green, 20.64mm)- MD733227 - $$$ - $$$
Slave Cylinder Rebuild Kit (Green) - MD997838 - $$$ - $$$
Slave Cylinder (Pink, 19mm) - MD733623 - $49.21 - $50.37
Slave Cylinder Rebuild Kit (Pink) - MD997786 - $$$ - $$$
Shift Cables - MB659306 - $119.76 - $$$
Clutch Release Fork - MD770506 - $47.31 - $48.42
Clutch Pivot Ball - MD719602 - $$$ - $$$
Clutch Lever - MB599203 - $$$ - $22.39
Clutch Fluid Lever - MB844603 - $$$ - $14.20
Clutch Release Bearing (throwout bearing) - MD749998 ~$20.12
Clutch Release Clip - MD706185 ~$0.96
Clutch Fork Rubber Boot - MD718077 ~$9
Transfer Case Recall Kit (contains new yoke, spider, caps and clips) - MR470072
Front wheel bearing Outer Seal - MB303875
Front wheel bearing Inner Seal - MB573309
Front wheel bearing - MB303865
Exhaust:
Turbo->Manifold Bolts - MD132656 - $5.50 - $5.63
6CM Turbo->Manifold Gasket - MD128901 - $2.02 - $2.07 - img
7CM Turbo->Manifold Gasket - MD171220 - img
Exhaust Manifold Gasket - MD181032 - $13.08 - $17.04
EVO VIII Exhaust Manifold Gasket(3 or 4 layer gasket compared to the stock 2 layer) - MR323654 - $17.77
Turbine->O2 Housing Gasket - MD124675 - $3.66 - $$$
Exhaust Manifold Nuts - MD092806 - $0.41 - $$$
O2 Sensor - MD188208 - $98.76 - $101.09
Evolution II/III Exhaust manifold - MR224509
Evolution II/III Exhaust Manifold heat shield - MD130345
Evolution II/III Downpipe/O2 housing Gasket - MB687004
Misc:
Non-Cruise Throttle Cable - MB539465 - $31.42 - $32.16
Left Parking Brake Cable - MB520774
Right Parking Brake Cable - MB520775
Ball Joint - MB241883 - $35.70 - $$$
Fuel Filter - MB504761 - $$$ - $$$ - img
Engine Coolant Temperature Sensor - MD069879
Mitsubishi key blank - MB543949 - img
Locking lug nut set - MZ312853 - $29.95 - $$$ - img - img
Dog-leg clips - MU481092 - $1.10 - $$$ - img
Fuel filler hose - MB678633 - $32.33 - $$$ - img
Of course there's a TON missing, I thought that we could collectively get a good list together for a sticky. Prices are Mitsubishiparts.net and Partznet.com respectively.
Cooling -->
Interior -->
ECS Pod (dash) - MB716913 - $22.56
Drivetrain -->
Slave Cylinder (Eclipse) - MD733623 - $49.21 - $50.37
Clutch Pivot Ball -
Clutch Lever: MB599203- $???? - $22.39
Clutch Fluid Lever: MB844603 $????/$14.20
Exhaust -->
Misc -->
Ball Joint- MB241883 (BIG thanks to RussianE39)
Turbo Oiling
MD140394 Feed line,
MD150523 Return Line
MF660063 x2 Head to feed line crush washer
MF660064 x2 Turbo to feed line crush washer
MR258477 x2 Return line to turbo/oil pan
MF660031 x2 Oil Return to oil pan bolt crush washer (it will NOT seal with out these)
g64b:
maroonmetallic
central WI
Just a helpful hint for that radio pocket, but the pocket in the colt's summit's and mirage's of 1989-1992 are the same (US spec)
steve
NJ
Knock Sensor info Posted by gvr4737
so here is some good news for everyone.
I purchased a GP Sorenson Knock sensor for a 1991 Mitsubishi Eclipse Gsx from Advanced Auto parts.
$58 it cost me and they got it the next day.
soo i pull my old knock sensor( which i baught from Mitsubishi directly $115 ) . i open the Gpsorenson box and find out that they are excactly the SAME knock sensor. The gpsorenson one says mitsubishi on it and same number, same wire colors .. same everything .. they are the identical knock sensor
soo anyone that ever needs to replace theyre knock sensor .. dont waste ur $$$ at satan . Go to advanced and order the $58 Gp Sorensen knock sensor .
Rausch
Cleveland, OH
Still looking into the differences.
BoostedAWD91
Danville,Pa
brake master cylinder bracket: MB534537
Bolts for bracket
holds bracket to firewall: MF240051 x2
bolt that tightens bracket around reservoir: MF243623
MD614948 part # for the BISS
MD608806 part # for the O-ring
MD614150 part # for rubber cap - img
KGVR4
Bellevue WA
Exhaust Manifold studs - MD005317 - $.53 each - for 6 bolt dsm
Here's some info for anyone that needs to replace the center driveshaft U-joints. I had an emergency with my car and after some searching I found an AC Delco U-joint that is perfect. All dememsions are exact. No part stores list a U-Joint for our cars, or even a T/E/L.
ACDELCO PN# 45U0016
GM PN# 89029281
What's great is you can cross reference these and most likly find a U-joint in your town the same day. Most GM dealers will have one or two on stock also. Best part is I paid $18.00 for one. Cheaper than the recall kit from mitsu, and they are still a great quality joint.
brisvr4
brisbane australia
Gearbox bearing part numbers...
These are the generic numbers for the W5m33 gearbox bearings.
Where the listing says inner I mean the flywheel side of the box and outer means the other end!
Input Shaft:
Outer bearing: Koyo 26118YR1-N
Outer Race: Koyo 26283-N
Inner bearing: NSK HR32205
Inner Race: NSK HR32205
Intermediate shaft:
Outer bearing: NSK R28-9
Outer Race: NSK R28-9A
inner bearing: Koyo 303/28R-N
inner race: Koyo 303/28-N
Center Diff case:
Outer bearing: Koyo LM300849
Outer race: Koyo LM300811
Inner bearing: NSK R41-1g
Inner race: NSK R41-1g
Center diff drive shaft:
Outer bearing: NSK R31Z-11g
Outer Race: NSK R31Z-11g
inner bearing: Koyo 32009JR
inner race: Koyo 32009J
Frt Diff bearings:
Koyo 6207R (Qty 2)
Mitsubishi part numbers for these ...
Input - MD732314
Input - MD726235
Intermediate - MD726236
Intermediate - MD724117
Center Diff case - MD727860
Center Diff case - MD720623
Center diff drive shaft - MD718322
Center diff drive shaft - MD727861
strokin4dr
Savannah, GA
Fuel door spring - MR970563
