No spark nor fuel...what could this be?
Scase90
Saint Robert, MO
Im getting no spark and no fuel.... no voltage to the cas, no ecu voltage, i have 2 12v power sources at the mpi relay and the 20a fuse is good..
I used the cas off of my buddys 91 tsi plugged it in and turned the gear clockwise, i got no injector pulse, no spark and no fuel pump... Ive checked all of my fuses inside and out and ive done simple test on everything... Everything checks out good.. Ive used my buddys cas and coilpack and mpi relay still nothing.. any help would be appreciated..
Quoting Scase90:
Try swaping in a known good ecu, if you haven't already.....
Scase90
Saint Robert, MO
yeah ive already use my buddys dsm linked ecu out his tsi and still nothing.
BluFalcon
Wichita, KS
This is a longshot, but is the 10 amp "Room" fuse in the D/S kick panel blown? My roommate's project Talon had a no spark issue that had her stumped, so I took a look at it. Validated all the electrical connections, and checked the fuses. Found the "Room" fuse blown, and swapped another one in. Car started right up afterwards. Could be worth a look.
grocery_getter
The 10A control current to the MPI relay. It is a very important fuse.
Does the CEL cycle when you put the key in the ignition and click it to the "ON" position? The CEL should turn on for a little bit and then turn off, indicating the ECU booting up and readying itself.
With the key in the ON position, do you have 12v at the coil pack, the CAS or the injector? Your TPS and MAS should have 5v too. The 12v at coil pack, CAS and injector comes from the MPI relay, the TPS and MAS 5v comes from ECU.
