Need Help
dmj
orlando FL
So I took 3 days off work to upgrade my car.Today I installed a new MHI evo 3 turbo , injectors ,evo 8 mas and a stage 3 ecm that was chipped by Keydiver.after installation about 12.10 am this morning the car started fine I let it idle for about 15 mins while checking for fluid leaks etc I then tried to rev engine to about 1,500 rpm and the engine just died , it will not restart. the engine won't turn over, no check engine. oil ,alt or any engine function lights at all, Horn and lights are ok.Key on acc does not function So no radio . Battery is fine.What should I be looking at?All ideas welome.
Terry Posten
Davenport, Iowa USA
The starter does not spin or the motor cranks but wont fire?
There are 4 large fuses that hang off the battery, check these.
dmj
orlando FL
I found problem Ignition fuse blown in main fuse box. do I need to check for a short to ground or is this normal with these cars?
Terry Posten
Davenport, Iowa USA
There is a large plug/harness that runs directly over the passengerside frame rail from the battery area into the cabin. That plug can become unplugged just a little and you will lose starter and a bunch more.
Make sure that plug is fully seated.
