Need help
valdez4o8
New member
gilroy
so i have a weird issue i came across today. im getting a grinding type of noise when i push in the clutch to the floor now if i push it down 90% of the way it wont grind and shifts fine. has anyone came across a issue like this?
MellowVR4
Milwaukee, Wi
Did you do a clutch job recently?
mistaVR4
Boulder, CO
Hello,
Reading your message I presume a shop did the work for you? If so I'd take it back to them and explain your issue with their work and have them address the issue. Although, here are a few links found using the search function (very helpful here!!). These are just random examples, however a grinding noise is not a good thing to hear, I would lean towards a possible loose bolt/TOB/Spring from the disc, if it is an sprung disc. Most definitely check Jackstransmissions.com website for excellent information!
Hope this helps a bit. GL!
desant78
Clarksboro, NJ
IWhen I first did my clutch, I had the same issue! This is most likely a clutch master cylinder issue. I had to just adjust it and it worked fine. For what its worth, a friend who works in trans shop says this is a typical problem when the master cylinder is not properly adjusted.
Either a bad throw-out bearing (should have replaced it doing a clutch job hopefully), or too much travel causing you to compress the springs into the clutch disc.
