installed 1g wheel now horn won't work
vr4hotness
Chino Hills, California
I'm guessing I installed it wrong.
The horn only work when I turn the wheel to the right lol I don't even need to push it.
How do I fix this?
Put a GVR$ wheel on it. JK
Take it apart and recheck your assembly.
transparentdsm
Cherry Hill, NJ
i could be wrong, but i think i read something about the ground needing to be redone when installing a 1G wheel. not 100% sure though, could have been a different wheel.
EfiniX
portland, or
Quoting prove_it:
Or rewire your horn so that there's a button directly behind the stick shift like I did. I found that easier than trying to put something together for the racing wheel I have installed with the added benefit of allowing my girlfriend to honk at other drivers without reaching over me to reach the wheel /ubbthreads/images/graemlins/smile.gif
Quoting EfiniX:
Quoting prove_it:
Should have put it on a harness then you could set the button on your lap so when she wants to honk.....
G
zompton
The 1g ground ring is a different distance from the contact then the vr4.
