belize1334
I'm fiddling with my L2A setup and right now I'm hoping for a new power source for the water pump. I have been running it off of a relay up near the power steering pump. I've moved the pump so it now sits above the transmission so I'm hoping for a keyed power source in the main fuse box. If it is hefty I can pull straight from it. Otherwise I'll use it to fire a relay. I want it to be live any time the key is in the "On" position, regardless of whether the engine is actually running.
Suggestions on the best way to do this? Fan circuit? EFI circuit?
