HMMM: Evo VIII/IX turboback?
5OF2k
colorado springs, colorado
Hello, all.
In my boredom at work, I've let my mind wander a tad, amongst other things. Basically, whilst cruising the interwebs for EVO8/9 parts, I came accross a very good deal on an Evo 9 3" turbo back exhaust($200). Now, mine isnt terrible, and it works, but for the T67 it's far from ideal. I dont know how many of you have actually seen an Evo's exhaust system, but it's rediculously straight, very few bends, therefore optimising flow.
Now, I realize it'll be nothing like a bolt/on system, given the orientation of the Evo's engine/trans being flip-flopped, and Im not opposed to modifying it at all to fit.
For those of you curious, here's a few basic specs of our cars vs evo vs DSM size-wise: (WB=Wheel base, OL= Overall length)
Evo 8/9: WB: 103.3in
OL: 176.8-178.5in
GVR4: WB: 102.4in
OL: 179.5in
T/E/L: WB: 97.2in
OL: 172.8in
As you can see, just off of the basics the GVR4 is much closer to the overall size of the Evos rather than the DSMs. This makes me think it'd be a lot less effort to make the Evo exhaust fit, especially if you already have an exhisting 3" downpipe/etc, to where you dont have to modify it to clear our Tcases.
Has this been contemplated before, done before, any feedback/ideas?
-Jake
EHmotorsports
Beaverton
I'm not sure if you know how to weld. If you do go pick up an exhaust builder kit that has mandrel bends for 80.00 and 5 foot section of straight for 40.00. Then build a perfect fit exhaust.
Defiant
Houston, TX
wont work without major modifications.
1G exhaust
EVO 8/9 Exhaust
5OF2k
Quoting EHmotorsports:
I can indeed weld, not an issue at all!
EHmotorsports
Beaverton
awesome! I just see cutting and welding to the evo exhaust to make it fit better. so for me at least its less of a headache starting fresh. I have done it both ways with past cars of mine. made due with what i had on hand. more work but the outcome was still the same.
5OF2k
Quoting Defiant:
1G exhaust
EVO 8/9 Exhaust
I see your point, to a point, but Im also looking to have as few bends as possible to promote the best flow possible. I've built an exhaust for my old 1G a loooooong time ago that had 2 bends in it; one where the downpipe met the O2 housing, and one back just before the diff to clear everything. Best par of all is it didnt rattle or vibrate audibly at all. sure, clearance was closer than factory in a few spots, but nothing that would become an issue. I also had a small flexjoint section near the tcase/oilpan as typical, and used 2 3" but joint band couplers to hold it all together.
Sure, it was loud because there was no resonators or anything of the sort, but i could've easily added a few inline glasspacks to use as resonators if I so desired.
Basically, the Evo exhaust is the closest pre-made exhaust to the exhaust I made for my Talon years ago, and was curious why nobody had thought of modifying one to fit our cars, yet.
I have a buddy coming by the shop tonight with his 9 to let me take some measurements and so-on, I'll update as I go!
-Jake
5OF2k
Excellent, thanks! I looked for a while yesterday and couldnt find anything on it. Appreciate it!
By all means, dont think I expect it to be a direct bolt-on or anything of the sort. BUT, a viable option? sure.
-Jake
