presterone
So I found out My knock sensor wasn't hooked up at all today. The connector (wiring harness side) looked a little messed up and it was hard to plug in but I managed to get it plugged in, then my car wouldn't start. It just cranks and dies it won't idle. I think when I hooked up the knock sensor it shorted the power wire to the ground wire. I checked the MPI fuse and its good. I have voltage to my injectors, fuel pressure is good. Spark is being distributed to my plugs. No voltage at the knock sensor with the key on. Although I am not sure if there is supposed to be until the car is running. I unplugged the knock sensor still the same thing. I am now stranded outside of work. I'm not sure if there is a main ECU fuse that may be blown or something.
