Galant gsx
Brianawd
Portland OR,
Well I picked up the Galant gsx yesterday from Jason. f*** mapquest. That sh*t had us taking the long way. Any way got home last night and just left the car on the trailer. Unloaded it this morning and got it put where I was thinking it was going to sit for some time. Any way went and did some things and when I got home started working on the car. I found a old ass kenwood alarm system so I pulled it out and all the wires. Tossed a battery in the car and gave it a crank. Oh f*** me it started on the first try. /ubbthreads/images/graemlins/grin.gif Now just need to give it a really good bath and fix some little things.
cspetros
Port Norfolk, VA
I've been watching this one. There are a few pics in the For Sale ad. Nice one man. Definitely interested in cleaned up pics.
Brianawd
Portland OR,
Brianawd
Portland OR,
Is the blue side stripe stock? Pretty interesting end on that.
I have know idea.
So got the fans back in the car. Fixed the idle problem it was having. It was missing the idle switch. Looks like the stuck caliper is because of the ebrake cable. I pull the cable on the passenger side tell I can fix the cable. Now comes the fun part of cleaning the inside and out. This weekend I am going to change the oil and fuel filter. Change the tranny fluid,tcase and rear diff fluid. Oh and flush the cooling system.
Oil in that should be brand new mobil one with a new filter. Memory could fail me on this so you might as well change it. /ubbthreads/images/graemlins/dunno.gif
Glad to hear it is working out for you. It was my brother's project and the look on his face when I said it was because of some stupid alarm in there was one of shock and disappointment. Ah well.
Brianawd
Portland OR,
It looks new but it smells like gas bad. Most likely from when you were trying to start it.
Brianawd
Portland OR,
Well been driving the car all week to work and back. Be doing good. Only real problem I have found was that broke carrier stud. I was able to get that some what fixed for the time being. Today after work I changed out the tps because I was getting a check engine light for it. I also reset the timing. Who ever set that last time was a tard. It was 6degs retarded. So now its back at 5degs btdc. Runs much much better. I still have a lot of cleaning to do. /ubbthreads/images/graemlins/grin.gif
Brianawd
Portland OR,
Well did a little more work on the ggsx today. I pulled the ecu and put in some new caps. The old ones had just started to leak onto the board. So I cleaned up the board and it was still good. So tossed the ecu back in the car and all is well. I then pulled the door panel to fix the lock. The rod for the door lock fell off so I could not lock or unlock the car from the drivers side. All and all the car is getting better and better every time I work on it.
1990ggsxnj
Blackwood, NJ
Definitely liking the Summit White. 2nd fav after the Nordic Blue ;o)
Myles
Skokie, IL
Good work. I think that deserves a lunch time visit to the A-Crop!
/ubbthreads/images/graemlins/applause.gif /ubbthreads/images/graemlins/rofl.gif
