yeti
is this the primary 80amp fuse
and if so is it interchangeable with a 100a fuse cause that's what i had in there
ALSO do i need a special tool to pull the 100a fuse out cause i don't think the metal should be sticking out right? cause it was very hard to get out and also noticed little slits on the sides along with the yellow 60a which wont come out
+the guy at kragen had never seen the fuse before and did not have any
