FS: My Stash of OEM Mitsu Gaskets & Hardware
89coltgt
Ste Genevieve, MO
I have a bunch of OEM Mitsu gaskets and hardware parts that I no longer need. I am looking to sell the entire stash as a whole. Here is a list of what's there:
3 1g wheel studs
1 turbine to manifold bolt
1 turbine to o2 bolt
1 ex manifold stud/nut
1 o2 housing stud
4 front diff pins, MF472404
1 6 bolt oil squiter MD329806
3 sets of 91-94 throttle body gaskets(elbow and manifold gaskets)
3 water neck to head gaskets
3 6 bolt OFH gaskets
4 oil return line gaskets
1 rear cover gasket
8 oil return bolt crush washers
various copper crush washers
1 rear 6 bolt crank seal MB343564
2 front 6 bolt crank seals MB343563
1 front wheel bearing seal MB573309
2 CAS Orings
1 half-moon gasket
1 front case oring MD041021
1 oil cooler oring MD620908
2 oil cap gaskets MD311638
1 7cm SS turbine gasket
2 engine to bellhousing dowels
multiple 6mm bolts for tbelt cover
1 balance shaft belt MR984778
1 clutch fork boot
1 camshaft seal
This list of parts cost over $270 buying from JNZ and Extremepsi, I will sell the entire lot for less than half, $125 shipped. Here is a pic of everything bagged up:
89coltgt
Ste Genevieve, MO
Still have all of this stuff
89coltgt
Ste Genevieve, MO
Still here....
89coltgt
Ste Genevieve, MO
Lowered price.
