FS: HX-40 (Complete Set-Up) and Accessories
Chim55117
Little Canada, Minnesota, United States
I've decided to change the set-up on my car and take my project a whole different direction, so I am putting up a bunch of parts on my car for sale. Shipping to be figured out on a part to part basis.
Holset HX-40 Pro Billet 7-Blade BEP bolt on housing (bolts directly to factory style exhaust manifold flanges) was rebuilt by Diesel Components in Blaine, MN. I've run it for less than 3 miles, and maybe an hour worth of idling. My friend who had it before me on the local forum said this is the most desirable HX-40 combo. He made roughly ~550WHP on it, and I was planning to do the same (have some of his old dyno graphs if someone is interested).- $750
Primo Performance Custom Fabricated O2 Housing to 3" V-Band, Tial 38MM Wastegate - $350
Modified 6 Bolt Oil Pan/Oil Drain in -19AN for Holset - $100
Mishimoto 3 core Civic "race" Radiator w/12" SPAL Fan (has only seen idle time, and 3 miles of driving. Beautiful custom made bracket comes as well. - $250
FP "Red" Oil Feed Restrictor + stainless steel feed line - $60
Huge Spearco Core (trapdoor style) with 2.5" powdercoated black piping, and a 3" GM MAF w/MAFT Translator and all couplers and fittings (does not come with BOV, but is flanged for a stock style BOV) - $650
These are individual prices for all the items, but if someone is interested in purchasing the entire set-up (everything above) and installing it into their VR-4, I can cut them a deal, as well as provide consultation on how to install the setup into their own VR-4.
Items are pictured below, and the in the picture is also how your engine bay will look if purchase the whole set from me as a whole. Thinking about the keeping the FP exhaust manifold, but willing to let it go if someone is interested in taking the whole setup from me.
Feel free to PM me with any questions.
Thanks,
- Stephen
blackvr4
NJ
You have any more pictures of the radiator installed? Mainly clearance between turbo and rad, I have a bolt on hx35 just wanna make sure this thing fits my set up.
Chim55117
Regarding the radiator, it's a very, very, very, tight fit, unless you do what I did. We cut back a little bit of the area where the stock radiator sits, and mounted our Civic radiator at an angle (not easily seen in the picture) and then we cut and moved the factory radiator mount on the bottom a few inches over. A slim fan is required, or you'll end up hitting the factory fan on the compressor housing.
