FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated May 10th 2022
91galantvr4_4WS
Active member
Salem, IL
I didn't see this on your list but figured it wouldn't hurt to ask if you had a working brake booster for a Vr4? I am needing the AWD/ All Wheel ABS booster. Apparently there are 4 different boosters that went on the car and I'm needing the one I listed last sentence. (MB699345)
Eaglesfly
St. Cloud, FL
Which AC line is the one you have for sale? I'm looking for the line that goes from the compressor to the condensor. I already have the line that runs from the evaporator to compressor and evaporator to drier.
galant55
New member
vancouver b.c.
i was interested in the following parts:
1)ETACS control relay module(under speed control module)my dome light doesnt work.
2)gas tank rubber hose(mine is rotten)
3)passenger side door lock security system switch(the yellow tab is broken on mine)
4)left and right rear quarter dog legs (summit white if possible)
also in your parts list:
1)1g turbo outlet pipe (is this for galant vr4 or talon? i need one for a vr4)
2)fps and resistor pack mount
3)intercooler hose bracket
4)battery liner
5)fuel purge solenoid with mounting bracket
6)relay located on rad support (does this include bracket?)
kjbtsi6686
Active member
Cumming, GA
You wouldn't happen to have the side skirts in summit white available would you?
Tre3zy
South San Francisco, CA
looking for hood cushions or stopper basically the 2 big rubber cushion on both edge near the fender... if you have a pair how much shipped to CA? thnx
GTX
Toronto, Canada
Rear suspension trailing arms? both sides
E39_VR4
Member
Lenoir City, TN
Do you have the headliner board? I am in dire need. Also, I need the two trim panels at the bottom of the console on each side. Please PM me with price and availability. Thanks!
E39_VR4
Member
Lenoir City, TN
Could you keep me in mind if you part another non-sunroof car? Thought mine was a factory power sunroof, but Iceman saw it Sunday, said it was an aftermarket, so I will need a non-sunroof headliner to cut the sunroof hole in. Thanks heaps!
