FS: '91 Gvr4 Partout (1335/2000) NB *Updated September 22, 2021
dave
Member
Brooklyn ny
sup i send the money i think the name on paypal is karry put dave callender if you can same address thanks
11secDSM
Member
PA
Pot, do you have any of these items in your part outs?
- Radiator fan harness (radiator side that plugs into the chassis harness)
- functioning power antenna
HadesOmega
Active member
San Jose, California
Do you have the HVAC center vents?
Defiant
Houston, TX
Do you have the passanger side hvac vent without broken fins or the rear view mirror?
brasian
New member
Faribault, MN
Hey pot I just sent you a text message wondering if you are able to cut me the rocker panels of your car if it is not rusted anyway. thank you!
Vince
Puget Sound, WA
Passenger door mirror w/working motor? (Casing unimportant.)
Drivers door lower window exterior rubber trim (Glass slides between it when lowering) still flexible?
Rear passenger door lock pull? (lift to unlock from inside) Mines snapped... may be a compatible part with other doors?
Drivers side front window trim (Vertical part that runs left side of windshield to down under the hood area?
PM me
Vince
Nicky67
New member
San Diego, CA
Do you happen to still have the bumper? The plastic trims that cover the front seat belt track on the drivers and passengers side? Appreciate pictures. Thanks
