FS: '91 Gvr4 Partout (1335/2000) NB *Updated September 22, 2021
pot
Fayetteville, NC
FS is nearly everything from a 1991 Galant vr4 badge number 1335/2000 with 216,909 miles.
All parts prices include <b>PayPal fees &amp; Shipping Costs for CONUS based transactions</b>. I accept all payments via PayPal to: <b>[email protected]</b>
If interested please contact me via PM or mobile no <b>(910) 689-6150</b>. Thank you for looking!
<b>ENGINE</b>
*GM Alternator part no P8107-3 (Advance Autoparts) $80.00
Throttlebody Elbow $12.00
Rear Upper Timing Cover Tin $15.00
Rear Lower Timing Cover Tin $15.00
Fuel Feed Line $8.00 w/ Banjo Bolt
Fuel Rail $20.00
Fuel Pressure Regulator $15.00
Fuel Filter Bracket $3.00
Engine Mount Bolt (Driver Side) $8.00
ECU Harness Retainer $2.00
EGR Valve $15.00
Radiator Fan Blade 15.00
Water Pump Pulley Set $15.00
Tensioner Hardware $2.00
<b>BODY</b>
Front Horn Set $12.00
Panel *Locate on Passenger Frame Rail $3.00
Fender Bolts $3.00
Front Side Windshield Trim $20.00 each
Front Driver Dogleg $50.00
Door Hinges $5.00 each
Door Pin Set $1.50
Alarm Horn Relay $3.00
Air Inlet (Passenger Side) $8.00
Coolant Overflow Bracket $5.00
Radiator Overflow Line $3.00
Radiator Bracket $15.00
Exhaust Hanger Set $25.00 or $5.00 each
Hood Latch $15.00
Hood Hinge Set $15.00 *Only Driver side available
Hood Bumper Set $3.00
Hood Bumper $1.00 for pair
Cowl Trim (Driver Side) $3.00
Cowl Hardware $1.00
Air Guide Panel $3.00 each
Hood Release Cable Guide $8.00
Fuel Filler Door $15.00
Fuel Filler Door Hook $2.00
Fuel Pump Wiring Cover $5.00
Trunk Dampener $3.00
Plugs, Trunk $1.00 each
Trunklid Striker $3.00
Rear Bumper Support Bracket Set $15.00
Trunklid Weatherstrip $20.00
License Plate Light Set $20.00
<b>HVAC</b>
Blower Motor Assembly $40.00
HVAC Vent part no MB439025 *Below Glove Box $15.00
<b>Interior</b>
Instrument Cluster Mount $15.00
Datalogger Cable $20.00
ETACS Computer $50.00
Interior Front Window (Headliner Strip $20.00
Headliner Handles $5.00 each
Interior Weather Trim (Driver, Front) $20.00
Interior Weather Trim (Driver, Rear) $20.00
Interior Weather Trim (Passenger, Front) $20.00
Interior Weather Trim (Passenger, Rear) $20.00
Foot Rest $12.00
Gas Pedal $25.00
Dash Speaker Cover $20.00 *Driver Sold
Defroster Switch $20.00
Horn Pad $20.00
Front Lap Belts $20.00 each
Retractor Mounting Bracket $20.00
Retractor Bracket 15.00 each side
Automatic Seatbelt Trim A. $3.00 each
Automatic Seatbelt Trim B. $12.00 each
Control Unit Auto Seat *Part No MB617345 $30.00
Air Vent $3.00 each
Air Vent Tab $1.00 each
Amplifier Power Adapter Part no MB 665345 $25.00
Buzzer $12.00
Sunroof Wiring Harnes part no MB665197 $20.00
Sunroof Felt Trim $30.00
Sunroof Shim Set $8.00
Sunroof Relay $12.00
Sunroof Control part no MB543075 $30.00
Kick Panel (Driver Side) $15.00
Interior Door Handle Pull $12.00 each
Interior Door Handle Backing $3.00 each
Door Card Clip $3.00 each
Door Ajar Switch $4.00 each
Clutch Interface Switch $12.00
Clutch Switch $12.00
Rear View Mirror Cover (Passenger Side) w/ hardware $5.00
Doorcard Lights $5.00 each
Door Sill, Rear $12.00 each
Door Sill, Front $12.00 each
Manual Transaxle Shift Lever Panel $20.00
ECU Tray $15.00
ECU Harness Retainer $3.00
Stopper (Glove Box) $2.00
Glove Box Frame $8.00
Glove Box Latch Bar $8.00
Glovebox Reinforcement Bracket $3.00
Glove Box Striker $5.00
Console Side Trim $15.00 each
Seat Trim Cover $3.00 each
Rear Wiring Harness Retainer (Passenger Side) $5.00
Seatback Trim A. $8.00
Seatback Trim B. $8.00
Trunk Access Trim $8.00
Trunk Dome Light $10.00
Trunk Trim $20.00
<b>DRIVELINE</b>
Shift Cable Selector $12.00
Shifter Cable Clip $1.00 each
Clutch Line to Slave Cylinder Hard Line $5.00
Rubber Clutch Line $3.00
Reverse Sensor $15.00
Front Differential $80.00
<b>Suspension &amp; Steering</b>
P/S Rack Bracket $15.00
Cruise Control Cable Guide $2.00
P/S Return Tube $15.00
Rear Strut Mount Cover $5.00 for the set
Rear Shock Lower Mount Hardware Set $5.00
Rear Wheel Hub (4 Lug) $50.00
Rear Subframe Stud $15.00
Rear Swaybar Bracket $12.00
<b>BRAKES</b>
Rear Brake Caliper Bracket $12.00 each
ABS Hydraulic Unit $125.00
ABS Computer $80.00
ABS Proportioning Valve $30.00
ABS Connector Bracket $3.00
Rear ABS Wheel Speed Rotor $20.00
Emergency Brake Cable Retainer $5.00
91galantvr4_4WS
Active member
Salem, IL
I sent a PM and an e-mail since my last one never got to you.
Illinoisinc
Active member
Chicago, IL
Hey do you have the driveshaft????? Let me know
johnnyRacer
Chicago
Do you have the throttle body bolts? What you want for em?
Scientist
Roseau/Dominica
Hi Pot it's me again....
Need the following:
Trans to Engine bolts
Engine Mount bolts
Front cross member
May need more as I continue to put my car back together and find out whats lost or stolen
galantgti
netherlands
No rear calipers available?
GSXftw
medford, OR
I need the trunk/fuel door opening levers that are on the drivers floor, along with the fuel door latch (the part that opens from the cable being pulled)how much?
TurboDSM
Merica
Would you be willing to do a roof cut? From the 5" down on all the pillars? How much would that be including the headliner, and all sunroof components?
Gsxhybrid
Member
Nevada
Still have Cruz control?
