FS: 774/2000 $8500 obo located in orange county NY
Up for sale is car 774/2000. The Car tuned by Erkle at Tach Motor works and the car runs great. I've put so little miles on it since I've owned it and it's a shame to watch it sit. I have numerous projects and unfortunately this one has to go. All performance bolt ones have less than 100 miles on them. Please pm with questions and offers. I haven't figured out how to add pics from my apple device my apologies. I'll gladly send pics via text 917-533-4963
Engine:
-Ross pistons
-Eagle Rods
-Calico engine bearings
-Balance shafts removed
-New oil pump and water pump
-Power Enterprise timing belt
-Ported Head
-SI dual valve springs
-ARP everything
-Mitsu MLS headgasket
-Forced Performance 272 cams
-Mocal 13 row oil cooler
-300m COP setup
-Royal purple 10w40 and OEM Filter since I've owned it
Exhaust:
-Evo III ported exhaust manifold
-Evo III ported O2 housing
-3" Stainless V-band downpipe
-3" ATR Pitbull exhaust system
-HKS Standard external wastegate
Turbo:
-Holset super 40
-Stainless braided oil feed
-BEP housing
Intake:
-Magnus sheet metal intake
-Magnus heat barrier gasket
- S90. 70mm throttle body w/block off plate
-K&N 12" filter
-2.5 intercooler pipes 3" to throttle body
-Spearco intercooler/Buschur 1g street version
-4" Forced Performance intake pipe
- Tail BOV purple 11psi spring
Electronics/engine management:
-AEM EMS
-AEM Tru Boost with 5 bar map sensor
-HKS turbo timer
-AEM wideband
Fuel system:
-Walbro 255lph HP fuel pump
-Aeromotive AFPR
-SS -8an lines from tank to rail
-1200cc  precision injectors
Drivetrain:
-Dogbox racing stage 3 trans w/ welded diff 23 spline
-Rebuilt transfer case 23 spline
-ACT 3200lbs with 6 puck sprung race disc w/extended push rod
-Fidanza flywheel
-4 bolt rear
-Entire driveline rebuilt
-Driveshaft carriers
-U-Joints
-Slave cylinder
-Master cylinder
-Shifter cables
-Fork and ball
Suspension:
-Whiteline springs
-KYB AGX adjustable
-Front and rear strut bars
Brakes:
-Front and rear cross drilled and slotted
-Rebco metal matrix pads
-SS lines
Wheels/tires:
-17" Racing Hart C4's
-Kumho Escata's 215/45/17
-All stock no rips
-MOMO Racing steering wheel
-Stock Paint
-93 headlights
-Powder coated lime green valve cover
-Modified 1g motor mount
-Prothane mounts
-Power steering removed
-Relocate battery to trunk
-New PPG windshield
ktmrider
Tempe, AZ
Nicely detailed ad however it's a REQUIREMENT that you post pics as per forum rules.
93accordEX
Westchester, NY
Maybe you've seen this on the front page (if anyone goes there anymore) Back when Wei (Hksvr4) owned it. It's still just as clean. I bought it in 2007 and then sold it to Donovan shortly after as I was barely using it. However I think he uses it even less than me. He's added so many new parts that basically have no miles on them. I honestly wish I could buy this back but it's just not in the cards for me right now. Here are some newer cell phone pictures:
Hksvr4
NYC
Hey, I see you put alot more stuff in it. Good to see it's still alive.
Edit: what numbers did it put down?
turbojew
Dallas, Tx
Interested in any trades?
thanks! A safe 530hp and close to 6 on race gas.
it now has Tein coilovers with brand new gvr4 specific front camber plates.
Thank you. The car is still for sale. Price is now $5500.00 firm or I'll part it out.
Hksvr4
NYC
^^ Treat her like you would to any girl....dirty! /ubbthreads/images/graemlins/grin.gif
