FS: 1992 Galant VR4 795/1000 NEOhio $5000 OBO
This is a 92 VR4 Belize Green #795/1000. The car is from Cali,yes the paint is faded! sunroof, 4WS deleted, manual steering rack, ABS deleted. I have owned a dozen dsm's and this is the cleanest one EVER! NO RUST! ANYWHERE!! This could be the main reason I have been wanting to keep it, But I bought an evo so the vr4 will just sit.
PICS
Sitting on steelies in pics, Cleaning up the 17'' this weekend
Recaro Black Seat w/actual Recaro Galant specific brackets.
buschur 20g 7cm port stainless O2 housing w/ full arp stainless hardware
ported 2g manifold
custom earl lines
2.5" turbo back exhaust w/titanum muffler
1mm oversized valves with titanium retainers
RRE ported head
crower 280's
kevlar timing belt
powercoated valve cover
metal head gasket
ARP head studs
low milage jdm longblock
balance shaft eliminated
hallman manual boost controller
Walbro 255 rewired
aluminum radiator fluidyne
Tial 50 mm bov
RRE FMIC
ceramic coated 2.5 intercooler pipes
samco couplers
ceramic coated Venon intake manifold
720cc injectors
SAFC black screen
Aeromotive FPR
Maf Translator
-6 fuel line entire feed
KYB AGXs front and rear
Eibach springs
Whiteline Front and Rear sway bars
poly busyings in all control arms
ACT 2600 clutch
92 vr4 trans
Fidanza flywheel
stainless clutch line
stainless brake lines
extended slave cylinder rod
RRE crank case breather/catch can
eprom ecu with TMO stage 3 chip
91 VR4 grill
5 lug converstion
slotted and drilled front and rear rotors
17'' enkies with kumho 225 40 17
Battery in trunk
twin piston brakes with hawk pads & power slot rotors
A/C still holds a charge!!!
2 inch stack of records dating back to when it was new
Will consider SOME trades & will sell as a roller,part out ect... ,but cash is king! $5000. OBO
[email protected]
216 310 4728
this was my car along time ago. yes it had no rust. super clean under the car.
