fmic?
jforn93
Member
altoona pa
What fmic are you guys running with shortest route
I was thinking about running a half radiator and just getting a vhrs kit for a 1g since they are pretty similair to the slowboy kit that i have on my 1g the core is just not as tall which i thought would be perfect for a galant. What do you guys think?
MellowVR4
Milwaukee, Wi
I would recommend the afco scirroco radiator and either a spearco intercooler or the vr-speed setup. I had to make my own pipes but it works fine.
LIV4PSI
O-H-I-O
Why did you make your own pipes Mellow?
mitsuturbo
Near Seattle, Washington
Mine looks exactly like the VRSF. It may be the same thing. IDK. It probably is, but I got it from MachV and they don't sell them anymore.
I shortened the pipes on my endtanks and changed the angle on them a bit, so it would fit better. Oh, i also had the mounting tab in the center welded on in a different spot so that i could bolt it directly to the hood latch support bracket. I think i spent about $70 having a guy TIG weld the pipes and tab back where i wanted them. Then i made my own piping out of stainless. The plumbing that came with the kit left a lot to be desired for a GVR4, and didn't really "work" for me. The FMIC fits very well, though. I'm quite pleased with how it looks.
You can see some pics of it here: click
Chi271
Chicago,IL
Running a 1g VRSF kit and absolutely love it!! Highly recommended, I'm also on a 3core Honda half radiator if that means anything. But I will be switching to an afco come summer.
turbohf
Lake Stevens, WA
i run a 1g race intercooler (IRC/Spearco 2-216) with 1g radiator. and custom short route pipes... its a tight fit.
MellowVR4
Milwaukee, Wi
Quoting LIV4PSI:
I just wanted to route it a different way then what the kit had in it. Ive changed my setup a few times and just changing the route of my setup.
5OF2k
colorado springs, colorado
I ran the VRSF 1g kit on my car with the T67 and an triple core Civic 1/2 rad. With the factory/16g setup and supplied j pipe Im sure it'd fit with minimal modifications, because the only things I had to modify to get mine to fit was a coupler(because of the Magnus manifold and it being lower) and the hot charge pipe due to the T67's size and location as a result of the manifold I was running, plus the 2" wasnt going to cut it flow-wise.
I had to fab up some mounting brackets and mount them to the bumper support area, but other than that it worked very well and fit perfectly with minimal work/adjustments.
-Jake
I was also looking at purchasing a VRSF kit. The price is amazing right now. They are on sale for around $309 (+55 for the 16G J-pipe) for the holidays. I was looking at the 2G kit though, and was wondering how much modification it would take to get it to fit. The core in the 2G kit is larger that that of the 1G kit, and looks like it would fit better.
For you guys who were running the 1G VRSF kit, you got any pics of the install, fitment or after shots?
That's cheap. That sucks I just bought an old 1g dejon front mount. I'd rather go this route but, oh well. People buy them up. There are several cars with the 1G kit on it.
5OF2k
Quoting GSTwithPSI:
I think I have pics of it in my build/member thread? Look for "johnny #5"
I thought about the 2g kit too, before I got the 1g kit. while the core is bigger on the 2g kit, I dont know how well it's tuck behind the bumper on our cars. I had a JDM bumper, and even the 1g kit filled the opening and I still had to trim the bumper support a little bit. I think the 2g inlet would have to be modded a bit too, or a bit of re-shaping on the lower drivers' side to make clearance for the hot side pipe....?
Either way, they're good setups. Cheap, and very funtional, plus they fit with very little modification!
-Jake
Diego
My short route setup. The first picture is just mocked up so it was a little slanted but it's okay now.
Diego
swe_gvr4_1991
Sweden, Alingsås
I went for the shortest possible route with an IC. Without an IC it can be even shorter if running E85. But that's another topic.
Here's how mine is routed:
Top fed IC with half size radiator placed in the middle.
All steel 2.5" pipes. No long flexible sections.
All that work to have a short route IC set-up and you still use the factory intake? Swap that out asap!
bmxr152
Lake tahoe, NV
I think the vrsf 1g intercooler is the shortest route, that is the only reason why i chose it.
