Dynatek Arc-2 problems.
JamesFoster
ALL
I just installed a Dynatek Arc-2 on my car, only to find it was bad right out of the box. Tried to start the car, it misfires and bucks and backfires, I changed the switches on the side to see if that was what was doing it, same thing happens. Unplug it and the car starts right up. Brand new in the box, Although it's been sitting for a few years. Bummer. I yanked it back out. f***ing waste of time.
EDIT: I'm editing this post because I may have been hasty to be so negative about the product. I'm sure it's a good ignition amplifier, I just had some issues. I'm sending it in to find out of it was bad or if user error caused mine to not function properly.
curtis
Clarksville TN
I'd call them up and see if there's anything they can do about replacing it.
Champ_168
IL
You can not just switch the switches, you have to disconnect power to change the switches.
You probably have the wrong settings selected on the switches.
TRBODSM
Northglenn, CO
^ is right. Power needs to be off to switch settings. If there is a problem with it they have the best customer service I know of. They will take care of you.
boostin4door
Chicago, Il.
I did a post on this awhile back.
I had a similar prob with mine when first installed it a couple of years back. It would pop and backfire. It grounded to the fire wall w/paint sanded off. It was a new unit out the box. Sent it back to them and had them check it out. Spoke directly to a tech and he was very helpful supportive. It tested out fine.
What I found out was, it HAS to be grounded really WELL or actually preferrably directly to the BATTERY. Since my battery was in the trunk I ran the ground cable all the way to it.
IT has Worked perfectly ever since!!
So try grounding to your battery and see what happens.
good luck.
Ps,
Also I'm using cop w/a oem plug. If your using stock coils I think theres a mod you need to do in order for it to work.
JamesFoster
ALL
Quoting Champ_168:
I tried that, didn't make a difference.
Quoting TRBODSM:
I'm sure they will, I was pretty frustrated when I started this thread. And I know the power has to be off to switch settings, didn't help.
Quoting boostin4oor:
good luck.
Ps,
I had it grounded to the same ground I have going to the alternator and the block, but maybe it needed to be connected to the battery. I have the same setup, battery in the trunk. Maybe I'll run the ground to the trunk and connect it to the battery before I send it back to Dynatek.
I also have a COP with the stock plug, so it should be ok.
thecman02
Kalamazoo,MI
I'm a little late to the discussion, but everyone friend I know that has one has had a problem with theirs at one time or another. Its becoming a little worry some.
Champ_168
IL
To reconfirm, you are disconnecting power to the arc2 to change the settings?
Not just turning the car off....
Physically disconnecting it from power...
Quoting JamesFoster:
Quoting Champ_168:
Quoting TRBODSM:
good luck.
Ps,
cheekychimp
East Sussex, U.K.
Quoting thecman02:
I don't really know anything about this model but a long time ago a member on here told me that there were only three CDi systems out there used by serious competitors in Motorsport and they are all manufactured in Australia. M&W, Motec and Autronic.
Street Surgeon
Omaha, Nebraska
Eh, Kiggly uses one with no issues /ubbthreads/images/graemlins/smile.gif I had one on my old Talon but that was involved in a head-on collision so it only lasted about 763 miles, nice thing is I sent it in to Dynatec to have it looked at and they're shipping a new one back to me! No fuss, no charge, that's some good customer service!
JamesFoster
ALL
I'm sure it's a great product, I just couldn't get mine to work properly. Due to a faulty product or user error? I'm not sure yet. I'm gonna send it it to them and have them test it out for me.
