DOES ANYONE KNOW THIS??
chop91vr4
new haven indiana
Does anyone know if any other dsm motors will fit this motor? mine decided to spring a hole right where the heat exchanger tube meets it.
/ubbthreads/images/graemlins/mad.gif /ubbthreads/images/graemlins/banghead.gif
umm.. what? Motor fitting a motor?
Maybe he means the engine temperature reduction cooling transfer unit.
chop91vr4
new haven indiana
Quoting chop91vr4:
motor 1g, part the water pump inlet pipe.
IncorpoRatedX
Arizona
Any 91-95 DSM water pipe will work. If you're water cooled oil cooler (stock) if someone swapped the car to 90 oil filter housing and external oil cooler,
You'd need a 90 pipe.
467
Fremont Ca
There's a large o-ring on the pipe where it fits into the housing. Are you sure it isn't the o-ring seal leaking?
chop91vr4
new haven indiana
Quoting 467:
No it seems to be leaking at the smaller pipe where it is welded. looks like I need a new pipe.
chop91vr4
new haven indiana
Quoting jepherz:
Technical? I think not.
So then what is your definition of technical? technical should be anything that involves a mechanical question or electrical,or something that has to do with non General questions. henc my question in regards to a mechanical issue.
ktmrider
Tempe, AZ
Quoting chop91vr4:
So then what is your definition of technical? technical should be anything that involves a mechanical question or electrical, or something that has to do with non General questions. henc my question in regards to a mechanical issue.
Here we go ( again ), another new owner who doesn't even try to search and gets snarky at the drop of a hat.
EHmotorsports
Beaverton
Chop. Noob questions belong in the newb section.
Where did Mark go, this is his area. Or even Negros...
Jesus_Negros
USA
Nope. I'm getting soft, remember?
Oh yea. Let's see, was it Wooklar that was taking over your spot?
Jesus_Negros
USA
Nah Wooklar wasn't trolling. He's just ignorant and fail at being a conspiracy theorist.
LIV4PSI
O-H-I-O
OP, it does belong it the newb section as it is very basic stuff, don't take it personally.
I have both water pipes available. And I disagree with Alpha Male, you can still use a 91-94 turbo water pipe with a 90 OFH. You just have to block two coolant passages, which is much more common than switching water pipes.
Also, thedsmguy (Paul) is another great source for used parts
Wookalar
Arizona USSA
^ for all the newbs.
donkeylips
Rochester, NY
Quoting LIV4PSI:
Yeah but swapping water pipes is the way to go! You just have to plan ahead a little bit and do it when the thing is apart. Thermostat housing too!
