Alarm installers, Dome light question,
Brunoboy
San Bruno,CA Home of SFO
I have never wired up my dome light because I dont know which wire it is and where its located, does anyone have their dome lights hooked up to their aftermarket alarms? if so, where is this wire or how do I get the dome to come on?
-Shane
alansupra94
Wayne,NJ
My dome light doesn't even work right all the time. I think my door sensors are fucked up /ubbthreads/images/graemlins/bawling.gif
Brunoboy
you tapped it into the door trigger? which wire is that and where is it located?
-Shane
Brunoboy
also what did you hook the trunk trigger to?
jepherz
KC, Missouri
You'd have to hook the trunk trigger to a solenoid since our cars are manual trunk releases. The door switches get corroded and need a cleaning once in a while. I never had my dome light working with the alarm, but I did use one of the dome light wires to tell when the door got opened (to trigger the alarm).
Brunoboy
im not trying to pop the trunk lol, i just want it to know when its opened, can i wire it to the trunk light? I mean when it turns on it means its opened so can i wire the alarm to one of those wires? also which and where is the dome light wire you used?
jepherz
KC, Missouri
You didn't specify what the trunk wire was doing. What does your alarm say it's looking for? Most likely you'd tie the door (dome) light and the trunk light together using diodes so either will trigger the alarm. You could put the hood switch on that same circuit too.
Brunoboy
alarm is looking for a negative trunk trigger, My hood pin switch is already installed for the hood, and the dome i read is a relay to the door trigger. so what to do about the trunk?
