matt92vr4
Well it's open test and tune tonight and this may be the last chance I get before it's 90 degrees every day for another 5 years. Should be about 50 tonight and 10% chance of rain. The G has been loving this cold weather! Gotta go to the track.
Last time out was Jan 2012. I ran a 14.5@93. That was K&N, gutted cat, MBC @ 17psi
Current mods:
2g pistons
evo8 valves, springs, lifters, etc
mls head gasket
arp head studs
BS delete
poly motor mounts
2g exhaust mani
s16g
2g o2 housing
1000cc injectors
chipped eprom
walbro
drop in K&N
MBC@14psi
gutted cat
I hope to beat the 14.5@93. The plan is to get two clean runs in exactly how the car sits. Then I will drop the crappy 2" crush bend exhaust, install my 3"DP and see how much that has been holding me back. Then I'll crank the boost up a bit and see if I can make it home without breaking an axle. I'll probably add a little 110 gas before I crank it up too much as insurance against knock.
I think I'll either break an axle or find the limit to the "stock" clutch before I go home. I'm mainly very interested to see exactly how much the crappy exhaust has been holding me back.
What do you guys think?
Current mods:
2g pistons
mls head gasket
arp head studs
BS delete
poly motor mounts
2g exhaust mani
s16g
2g o2 housing
1000cc injectors
chipped eprom
walbro
drop in K&N
MBC@14psi
gutted cat
