boring knuckles to use evo camber bolts
Tre3zy
South San Francisco, CA
just wondering if its safe to bore the knuckles to accept larger evo bolts? i wanted to do this because im running evo suspension.... and wanted to be able to properly adjust camber.... thnx....
belize1334
Bozeman, MT
I'll just add that the strut offset on Evo suspension is slightly different from 1G suspension so if you drill the holes exactly center you'll end up with a bit of positive camber. If I were doing it I'd take them to a machinist with a mill and have him offset the holes for maximum negative camber. That way the default will be ~-1* instead of ~+0.5* or so. Just my $0.02.
Tre3zy
well here is my plan.... i bought camber plates and it gave me some negative camber but not enough.... so if i bore the holes bigger i can run some evo camber bolts to get some more camber....
