Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Thermostat Question
Thermostat Question
dmj
Rod Stewart
998/1000
Galant VR-4 org Post #: 977906 posted 03/18/11 09:17 PM     Remind Me!  Send Private Message   Edit Post
My car runs pretty hot in the Florida Heat 220 degrees and above with the factory 195 degree thermostat. I know a 180 degree would help, but would it cause the car to run a little richer and is there any known negative side effects?
Posts: 673 | From: orlando FL | Member Since: 02/02/08 | IP: (97.100.20.147) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 977950 posted 03/19/11 01:46 AM     Remind Me!  Send Private Message   Edit Post
I was running a 160 in 611 and was still getting the same MPG as I was before I swapped out the thermostat. Believe I was getting 20mpg. I installed one in 802 as well
92 GVR4 #802 link
06 EvoIX SSL-417HP/418TQ-OEM Turbo E85 / Ohlins DFV
94 MX5 M-Edition - On Xidas
SOLD: 92 GVR4 #611
Posts: 790 | From: Corona, CA | Member Since: 04/08/08 | IP: (76.170.48.229) | Report this post to a Moderator
speedyvr4
Still looking for the forest!
536/1000
Galant VR-4 org Post #: 977991 posted 03/19/11 10:47 AM     Remind Me!  Send Private Message   Edit Post
i have a 180 deegree in mine, and didn't notice a difference in mpg either. with this florida heat coming up, if your gonna be beating up on it, a 170 deegree thermostat might not be a bad idea.
Posts: 1245 | From: miami, fl | Member Since: 01/02/06 | IP: (65.83.180.6) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 978074 posted 03/19/11 08:02 PM     Remind Me!  Send Private Message   Edit Post
As long as the ECU sees coolant temps over ~180F, it won't hurt gas mileage. All it knows is coolant temps, not what thermostat is installed, so if you install a 180F unit and your temps stay above that due to high ambient temps, you'll be fine.
-Mark
1051
Edited by turbowop (03/19/11 08:02 PM)
Posts: 11891 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.113.5.156) | Report this post to a Moderator
Edge729
Galant VR-4 org Post #: 978169 posted 03/20/11 12:42 AM     Remind Me!  Send Private Message   Edit Post
I had to run a colder thermostat when I was in FL
| | | IP: (24.8.109.121) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 978470 posted 03/21/11 01:51 AM     Remind Me!  Send Private Message   Edit Post
I seem to be doing ok with a 160 in mine. I use the coolant offset on ECMLink set at 30, so once it reaches 160, the ECU thinks it's at 190. Fuel trims adjust accordingly and mileage in the low 20s in town is common.
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (67.171.235.101) | Report this post to a Moderator
Adorsey
Member +
1942/2000
Galant VR-4 org Post #: 978505 posted 03/21/11 11:00 AM     Remind Me!  Send Private Message   Edit Post
I had a 180* in mine, with a 3/16" hole drilled in it. It took longer to warm up, and always ran in the 163~175* range, never saw coolent temps over 186* unless I was beating on it.
Also had the stock boost gauge for a coolent temp indicator, the first bar was at 186* and it was bearly ever on.
CEL was set for 204* so it would give me a heads up if it was getting too hot.via ecmlink.
Posts: 355 | From: mass | Member Since: 04/22/09 | IP: (134.241.100.250) | Report this post to a Moderator
Hondakiller
Galant VR-4 org Post #: 980876 posted 03/29/11 10:03 PM     Remind Me!  Send Private Message   Edit Post
I have a 160 and i live in florida and it seems to be running fine
Posts: 109 | From: Deltona Florida | Member Since: 05/13/10 | IP: (97.100.161.35) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 981039 posted 03/30/11 04:20 PM     Remind Me!  Send Private Message   Edit Post
You have to get to 180*F in order to run in closed loop. BUT... you have to reach 190*F in order for the ecu go into learning mode and update the fuel trims. So, I wouldn't want a car to run colder than 195*F when fully warm or you risky having trims that are just pegged on a particular value...
Roger B. Scott
'91 Belize Green
Posts: 3298 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (153.90.194.143) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 981344 posted 03/31/11 09:06 PM     Remind Me!  Send Private Message   Edit Post
I'm running a 180, I haven't had an issue. I'm running 2 10 inch slim fans as pullers with the factory AC fan as a pusher.
Thats in the FL heat with AC nice and cold
Cory McGee
1997 Jeep Cherokee - DD/Tow Rig
1992 Galant VR4 #623 - SOLD
1992 Galant VR4 #199 - Parted and Gone
Posts: 204 | From: Bradenton FL | Member Since: 01/27/08 | IP: (97.97.88.121) | Report this post to a Moderator
0 registered and 21 anonymous users are browsing this forum.
Generated in 0.216 seconds in which 0.196 seconds were spent on a total of 14 queries. Turbo powered.
