Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Methanol as a primary fuel
Trnr
Galant VR-4 org Post #: 974766 posted 03/06/11 02:47 PM     Remind Me!  Send Private Message   Edit Post
Whats everyones thoughts on methanol as a primary fuel?
| | | IP: (204.210.123.163) | Report this post to a Moderator
CSMShaun
981/2000
Galant VR-4 org Post #: 974796 posted 03/06/11 05:12 PM     Remind Me!  Send Private Message   Edit Post
For racing or for driving about? Shep ran meth on his last setup and didn't even run an intercooler.
Posts: 129 | From: Cincinnati, OH | Member Since: 01/02/10 | IP: (12.235.36.158) | Report this post to a Moderator
thedsmguy
Galant VR-4 org Post #: 974808 posted 03/06/11 05:34 PM     Remind Me!  Send Private Message   Edit Post
PITA. I believe strait methanol would eat through your fuel lines and aluminum surfaces if allowed to sit for extended periods of time.
Posts: 1785 | From: Vancouver Washington | Member Since: 03/20/09 | IP: (76.115.73.203) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 974812 posted 03/06/11 05:40 PM     Remind Me!  Send Private Message   Edit Post
I use straight methanol as a supplement over 92 octane pump gas. I inject it using an Alkycontrol pump through teflon coated lines sprayed through an M10 nozzle in the upper intercooler pipe a few inches before the throttle body. It's held in a foam filled three gallon reservoir in the trunk. It interfaces with my Maftpro setup for control.
Works well as I have it setup in my street car. I wouldn't think of using it on its own though, unless it were for a track only car.
-Mark
1051
Posts: 11891 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.113.5.156) | Report this post to a Moderator
Trnr
Galant VR-4 org Post #: 974841 posted 03/06/11 07:13 PM     Remind Me!  Send Private Message   Edit Post
primarily race. Im just exploring options to fuel due to c16 being $75-$85 for 5 gallons. As well as c16 being leaded and chewing through o2 sensors/widebands.
Sounds like using meth as an injection works well, im just trying to use one fuel....just for simplicity sake. although it sounds like a good setup you've got
Edited by Trnr (03/06/11 07:15 PM)
| | | IP: (67.49.128.23) | Report this post to a Moderator
BKatter
Galant VR-4 org Post #: 974902 posted 03/06/11 09:57 PM     Remind Me!  Send Private Message   Edit Post
You'll need a massive fuel system to make big power with methanol. Stoichiometric AFR is 6.4:1.
I think ethanol (e98) is the best replacement for race gas in a race car. It's cheaper, doesn't require as much fuel system as methanol (9:1 stoich AFR), is less corrosive than meth, and, from what I've read, makes more power than race gas.
Edit: Here's a link with some info on using alcohol as a primary fuel. Methanol
Edited by BKatter (03/06/11 10:22 PM)
| | | IP: (63.226.97.142) | Report this post to a Moderator
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 974904 posted 03/06/11 10:11 PM     Remind Me!  Send Private Message   Edit Post
Well I think for you it comes down to what's available... is E85 or E98 in Hawaii?
Lack of boost
Posts: 1076 | From: NY | Member Since: 06/03/07 | IP: (68.192.121.191) | Report this post to a Moderator
Trnr
Galant VR-4 org Post #: 975021 posted 03/07/11 01:11 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the info BKatter, as far as whats available the car is actually in upstate NY. I'm in the military and have about a year and a half left. Once I get out I'll be going back to NY, and who knows from there. I'm not too sure what kind of fuel they have, I haven't been home since the beginning of '08. I'm just trying to get a plan laid out before I get there, so when I do get back to NY I can get to work. Just to give everyone an idea where I'm headed with the car, Im looking to make 600-650whp. I'm thinking about a 2.3, built head, shep trans/case, 5 lug swap so i can run driveshaft shop axles and driveshaft, 4 bolt rear, standalone etc. etc. I'd like to use the "smallest" turbo possible in case I do any street driving.
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 975040 posted 03/07/11 02:37 PM     Remind Me!  Send Private Message   Edit Post
E85 all day
It's pretty available in NY now... starting to get more popular
Lack of boost
Generated in 0.321 seconds in which 0.301 seconds were spent on a total of 14 queries. Turbo powered.
