Galant VR-4 Forums » Marketplace » Parts For Sale » FS: GVR4 1552 partout: aftermarket parts
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 969422 posted 02/12/11 02:09 PM     Remind Me!  Send Private Message   Edit Post
Update 4/12: car is 100% parted and went to scrap. Today: update to sale lists and prices lowered
[email protected] for questions and paypal. Prices don't include shipping.
PLEASE NO PM's....just email me. I can't search PM's or keep track of info on 7 different forums, it's much easier for me to have all corespondance in one searchable inbox.
NGK plug wires $25
3 Turboback exhaust 150 (pretty rusty, Im going to see if sanding/painting can fix it up)
89 Tail lights $60
5lug swap set $100
Rebuilt 6bolt shortblock: 2g pistons, 90 rods, recent Tbelt, front case, and water pump parts $500 Waterpump, front case, tbelt parts, oil pan, pickup, and hardware are cleaned and boxed up but come with.
1G head, ported, SS valves, farrea springs and retainers. $500
rear ss brake lines $20
DSG delrin shift knob $5
89 dash pad and glove box $40 (These are dark blue in color)
Blue cloth galant GS seats (set of 4) $50 excellent condition!
13" front brake kit $175 (includes nice rotors, dual piston aluminum calipers, aluminum brackets, and SS lines. Brackets not shown in pics. The calipers are very light and from a camaro, rotors are from a mustang cobra.
Act 6bolt awd flywheel $100
HKS VPC and custom keydiver eprom chip $200 - setup for VPC hardwired into the engine harness. Keydiver chip is setup specifically for the hardwired VPC to eliminate the "plug n play" ecu adapter harness. Includes MAP and AIT sensors with wiring harness. I believe there are 550 and 660 VPC eprom chips as well.
Alpine headunit CDA7839 $40
17x8 Acura TL wheels with tires $180
kirban afpr with -6 lines, 1g rail adapter, and gauge $130
Slim fans (2) $40 each one push/one pull
Pull
Push
SOLD:
93 headlight set 100
HKS 264/272 cams 285
Tien camber plates 120
Greddy profec B (blue) 150
FP exhaust manifold 160
Tial silver bov 145
Driven Innoventions SMIM for 1g head 375
Denso 720 injectors 120
90 OFH, -6 SS lines, 90 cooler set 65
battery relocation parts 75..nice SS box, cutoff switch, circuit breaker, and wire. Does not include battery.
Act 2600 clutch 150
3speed scattersheid 75
DSG AWD Galant fuel pump pickup 100
SS clutch line from frame rail to slave $20
Decent set of black (GVR4 specific) plastic timing covers $40
Indy Racecores 216 spearco FMIC kit 400
AEM wideband gauge 145
Dogbox racing rebuilt awd 1g trans. Have receipt. Evo forks, welded diff. 750
PTE SCM6152E T3T4 turbo w/ oil lines $425
ST rear swaybar 75
CF GVR4 hood w/ hoodpins 245
CF GVR4 grill 45
-6 fuel feed line from oem filter to rail w/ adapter $45
AFC blue screen (original version) 110
AGX shocks 200
3 intake pipe and filter 65
Autometer Sport-Comp 35psi, mechanical oil press, and electric water temp gauges $75
AEM fuel rail $75
non cruise throttle cable 20
ABS delete kit $65
Blitz turbo timer with 1G harness 50
Walbro 255 $55
Will be adding these parts to the DSMpartout.com website as I remove and get individual photos, so they will be available for online ordering. I'll also have another thread with all the oem stock parts from this car (non sunroof 91 white GVR4).
GVR4 #418/2000: [email protected] - pump/alky -
GVR4 #431/1000: [email protected]+
GVR4 #139/1000: T3T4: [email protected] - 14B: [email protected] (sold)
www.PerformancePartout.com
Edited by NateCrisman (04/12/11 08:26 PM)
Posts: 2054 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (71.48.189.181) | Report this post to a Moderator
talontyme
Member +
224/2000
1505/2000
Galant VR-4 org Post #: 969428 posted 02/12/11 02:46 PM     Remind Me!  Send Private Message   Edit Post
Hey Nate here is a little list of the parts i would like.
front dome light cover
st rear sway bar
ss brake lines
front bumper cover
shifter boot(if factory and in good shape)
intake manifold.
I sent an e-mail before I knew you and your family were sick i hope you all feel better just get back to me when you can.
95 Mitsu GSX-650hp monster
92 Laser RS awd-sold
1505/2000-sold
224/2000-traded
Edited by talontyme (02/19/11 03:43 PM)
Posts: 329 | From: Portsmouth,VA. | Member Since: 03/16/09 | IP: (70.184.170.246) | Report this post to a Moderator
Jesh
Member +
898/1000
Galant VR-4 org Post #: 969433 posted 02/12/11 03:08 PM     Remind Me!  Send Private Message   Edit Post
Do you have any pics of the 3" exhaust? Also, was it setup to bolt onto factor 02 housing?
'92 Galant VR4 898/1000
'91 Galant GSX - parts
'93 Laser RS - gone
Posts: 281 | From: Soldotna, Alaska | Member Since: 11/12/09 | IP: (216.67.43.135) | Report this post to a Moderator
Jordangvr4
Member +
Galant VR-4 org Post #: 969444 posted 02/12/11 04:00 PM     Remind Me!  Send Private Message   Edit Post
Pm on cams!!
1991 Gvr-4 Amg
1991 Gvr-4 Jdm rhd
Posts: 318 | From: Nassau,NYC. | Member Since: 11/02/08 | IP: (208.54.45.62) | Report this post to a Moderator
oldman_tau
1837/2000
Galant VR-4 org Post #: 969445 posted 02/12/11 04:01 PM     Remind Me!  Send Private Message   Edit Post
ygm for the headlights
Posts: 232 | From: cerritos,california | Member Since: 06/13/10 | IP: (108.0.9.73) | Report this post to a Moderator
Jesse_W
Galant VR-4 org Post #: 969454 posted 02/12/11 04:49 PM     Remind Me!  Send Private Message   Edit Post
interested in hood. also would like pics.Email sent
thanks again
Jesse
Edited by Jesse_W (02/12/11 04:50 PM)
| | | IP: (66.76.18.251) | Report this post to a Moderator
throughfaith323
39, 40, 41
1922/2000
Galant VR-4 org Post #: 969456 posted 02/12/11 05:06 PM     Remind Me!  Send Private Message   Edit Post
Interested in the 89 pad and glove box. Will wait for pictures. Are they color matching?
Ed
1991 GVR4 1922/2000--selling performance parts
Posts: 528 | From: Forked River, NJ | Member Since: 09/24/08 | IP: (71.255.10.200) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 969458 posted 02/12/11 05:08 PM     Remind Me!  Send Private Message   Edit Post
Ok guys. I went to the shop and took some pics, they are uploading now. I'll insert them into the thread as soon as the batch finishes uploading. The car literally just came off the trailer and I haven't pulled anything yet. Im going to get the car on the lift tomorrow and start yanking off the "low hanging fruit" first. As parts come off or become accessable to photograph, I'll add more pics.
I actually have to run out to dinner, but will insert pics into the thread when I get back. For now: here's a link to the gallery of pics from this car thus far: photo gallery for GVR4 1552 partout
shredder2010
1833/2000
Galant VR-4 org Post #: 969459 posted 02/12/11 05:15 PM     Remind Me!  Send Private Message   Edit Post
Pm on trans
5/1000- rebuilt sold
1833/2000- sold 2011 bought again 2013 fully built motor, tmz trans and a pte6262 should be running soon
Posts: 59 | From: Racine,Wi | Member Since: 05/12/10 | IP: (72.135.206.176) | Report this post to a Moderator
dsmless
gay without homosexual tendencies
96/1000
Galant VR-4 org Post #: 969546 posted 02/13/11 07:52 AM     Remind Me!  Send Private Message   Edit Post
payment sent for boost controller pm me if any questions
Posts: 224 | From: tucson,az | Member Since: 06/12/08 | IP: (195.226.234.34) | Report this post to a Moderator
AlaskanOwned
Galant VR-4 org Post #: 969636 posted 02/13/11 08:03 PM     Remind Me!  Send Private Message   Edit Post
Does the 4 Bolt LSD include axles/cups?
| | | IP: (75.95.146.107) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 969770 posted 02/14/11 08:42 AM     Remind Me!  Send Private Message   Edit Post
I'm at the shop now. Have replied to PM's on this board (and requested everyone please continue the conversation via email rather than PM). Im replying to Emails next, then going to start tearing the car down. Im hoping to have the engine/drivetrain on the floor late this afternoon. Should have more pics and info to update the thread tonight.
Happy Valentines day
Posts: 2054 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (71.2.34.190) | Report this post to a Moderator
4wheelsqueal
Member +
Galant VR-4 org Post #: 969814 posted 02/14/11 01:04 PM     Remind Me!  Send Private Message   Edit Post
Email sent
1997 Eclipse GSX - sold
2004 Evo RS
1996 Eclipse Spyder AWD - sold
555/2000 NB - 286,000 miles - sold
713/1000 KG - sold
1945/2000 BG - sold
1803/2000 SW RHD - sold
1049/2000 - sold
Posts: 446 | From: Shawano,WI | Member Since: 12/06/08 | IP: (74.112.57.173) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 970091 posted 02/15/11 07:01 PM     Remind Me!  Send Private Message   Edit Post
I hate to have to do this, but I'm forced to push back the teardown, packing, and shipping of the parts from this car. My household came down with the flu monday afternoon, I had to cut the day short and spent today at home with my kids (who stayed home from school). Im not sure if they are going to school tomorrow or if I'll be able to work either.
Anyway, I figured I should drop a line and let everyone know that there is going to be a delay.
4wheelsqueal
Member +
Galant VR-4 org Post #: 970232 posted 02/16/11 08:17 AM     Remind Me!  Send Private Message   Edit Post
Haven't received a reply on gmail. Tried sending email to [email protected]
2004 Evo RS
713/1000 KG - sold
1945/2000 BG - sold
1049/2000 - sold
4wheelsqueal
Member +
Galant VR-4 org Post #: 970430 posted 02/16/11 10:34 PM     Remind Me!  Send Private Message   Edit Post
Payment sent on FP manifold. Could i get the bolt that hold the manifold to the exhaust housing too? Thanks, Nate!
2004 Evo RS
713/1000 KG - sold
1945/2000 BG - sold
1049/2000 - sold
Posts: 446 | From: Shawano,WI | Member Since: 12/06/08 | IP: (173.254.130.23) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 970504 posted 02/17/11 09:46 AM     Remind Me!  Send Private Message   Edit Post
John's old car. I recall this car being a solid performer & John had a lot of fun with it. He didn't take shortcuts putting it together years ago. For those that don't know, that's one of the best aftermarket intake manifolds built for the gvr4 & 1g's. I wanted one so bad when Tommy 1st designed & built them. For the new guys, Tommy is a very detailed guy who put a lot of thought & engineering into building this manifold & would not compromise on anyting until it was perfect. If I was going to put an aftermarket intake manifold on my car it would be this one.
| | | IP: (66.229.166.41) | Report this post to a Moderator
desant78
Member ++
1662/2000
995/1000
Galant VR-4 org Post #: 970550 posted 02/17/11 12:58 PM     Remind Me!  Send Private Message   Edit Post
email sent to dsmpartout.com yesterday. hear from you soon!
i wanna go fast.
1991 GVR4 1662/2000 (parts car)
1992 GVR4 995/1000 (JSB)
2008 Evo X GSR (DD with bolt ons, 17x,xxx miles)
Posts: 732 | From: Clarksboro, NJ | Member Since: 06/23/10 | IP: (150.250.98.141) | Report this post to a Moderator
boosted_85
1320/2000
Galant VR-4 org Post #: 970567 posted 02/17/11 01:45 PM     Remind Me!  Send Private Message   Edit Post
Email a couple days ago, still haven't heard back
Posts: 198 | From: milwaukee, wi | Member Since: 04/02/09 | IP: (67.53.146.49) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 970587 posted 02/17/11 03:59 PM     Remind Me!  Send Private Message   Edit Post
Quoting desant78:
I'm tryin guys...the flu is a bitch! Iv got a full inbox to sort through and haven't sat at computer long enough to make a full dent in it. Hopefully tonight I won't go to bed at 5:30pm like I did yesterday.
Posts: 2054 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (166.137.138.83) | Report this post to a Moderator
alansupra94
Excuse the retarded question.
4/1000
Galant VR-4 org Post #: 970704 posted 02/17/11 10:53 PM     Remind Me!  Send Private Message   Edit Post
You better email me back or I will steal your jackstands!
1992 Galant VR4
1996 Toyota Supra TT
Posts: 1908 | From: Wayne,NJ | Member Since: 03/03/10 | IP: (173.3.24.20) | Report this post to a Moderator
gst4
Galant VR-4 org Post #: 970988 posted 02/19/11 08:58 AM     Remind Me!  Send Private Message   Edit Post
pm sent
| | | IP: (76.172.148.41) | Report this post to a Moderator
Jesse_W
Galant VR-4 org Post #: 970995 posted 02/19/11 10:09 AM     Remind Me!  Send Private Message   Edit Post
Feel better soon! Cant wait to get the fmic.
Jesse
talontyme
Member +
224/2000
1505/2000
Galant VR-4 org Post #: 971044 posted 02/19/11 03:43 PM     Remind Me!  Send Private Message   Edit Post
Quoting talontyme:
st rear sway bar
ss brake lines
front bumper cover
intake manifold.
added parts to list.
1505/2000-sold
224/2000-traded
Posts: 329 | From: Portsmouth,VA. | Member Since: 03/16/09 | IP: (98.141.3.180) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 971045 posted 02/19/11 03:46 PM     Remind Me!  Send Private Message   Edit Post
Ok...yesterday was shot (promised Wife I would do something with her and kids if weather was good, as they are off from school...we went to Philly Zoo). I spent today at the shop, and busted out the majority of part removal. Engine/trans are on the floor, lots of stuff went in the parts washer today. Have to go to a family dinner party, but:
Tonight, I PROMISE, I'll respond to every email that's stacked up in my inbox.
Tomorrow Im going to the shop specifically to make photos and clean/organize parts. Lots of parts have been sold already sight unseen, which I have to say Thanks to everyone that is so trusting of me. hahah Some people have even sent me paypal payments without even contacting me yet.
Edited by NateCrisman (02/19/11 03:46 PM)
Pages: 1 | 2 | 3 | 4
2 registered and 16 anonymous users are browsing this forum.
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Generated in 0.079 seconds in which 0.03 seconds were spent on a total of 15 queries. Turbo powered.
