what are these connections?
stealthtt24
Orlando, FL
So its been awhile since I've wrenched under the hood of the g ride. I'll be posting a bunch more /ubbthreads/images/graemlins/grin.gif. These look like coolant connections of some sort. UPDATE- the wires in the 2nd picture have been confirmed.
1st pic right connection- 02 sensor left connection- 02 ground, tape off
2nd pic right connection- ecu temp sender on the front of the t-stat housing
2nd pic middle connection- temp sender for the gauge, front of the t-stat housing
2nd pic left connection- Its the coolant temp switch for the a/c system
toybreaker
iconoclast
top pic is for the o2 pigtail and resides in that bracket down on the tranny under the t-stat housing
second pic, two pin is for ecu temp sender on the front of the t-stat housing
second pic, single pin is for temp sender for the gauge, also located on the front of the t-stat housing.
stealthtt24
Orlando, FL
Thanks toybreaker, I had a feeling that one was the o2 gauge connector. I know these connections look like sh*t, this is how it was when I got the car. I'll be posting more up soon. You own!
stealthtt24
Orlando, FL
Toybreaker, you see in the first pic the wire next to the o2 sensor? It's damn near bare, what is that one?
Also, in the second pic you see the wire that is on the very left of the screen? It's a 2 pin wire as well, almost looks like it goes into wire loom but it doesn't, whats that?
toybreaker
iconoclast
That's the end of the shield wire. It cuts down on electrical interference on the o2 signal wire.
It goes to ground at the other end by the ecu.
Just wrap it back around the wires, taking care to avoid any damaged areas of those wires, and tape it down with a quality electrical tape like "scotch super 33"
stealthtt24
Orlando, FL
You da man, edited one of my post wondering about the 2nd pic /ubbthreads/images/graemlins/laugh.gif
toybreaker
iconoclast
Quoting stealthtt24:
The one that passes thru your hand, has two wires and doesn't have a connector on it?
I *think* that's the coolant temp switch for the a/c system. It goes to the connector that's on the top of the t-stat outlet neck.
What are the wire colors?
desant78
Clarksboro, NJ
Quoting toybreaker:
When i bought 1662, the PO cut all the factory plugs. Does it matter if you switch the yellow wires shown? I might have accidentally done that and that would be causing all my problems of reading 7 to 15degF temps..
toybreaker
iconoclast
Quoting desant78:
For a quick test to sort this out, with the key in the on/run position, take the single wire that runs out to the t-stat and jumper it to ground briefly while someone watches the temp gauge.
If that is indeed the wire that runs to the gauge, it'll peg the temp gauge on hot.
A few seconds won't hurt anything, but don't leave the wire grounded for long, as it will eventually piss off the resistors that make up the wheatsone bridge inside the gauge, and that will affect it's accuracy.
If that wire really belongs in the two pin set that runs out to the ecu, the temp gauge won't move.
stealthtt24
Orlando, FL
Quoting toybreaker:
Sorry I forgot about this. I don't have A/C, can I just get rid of that wire?
The color wires of the single wire is green/black and green/red.
stealthtt24
Orlando, FL
Here are more pictures...
These are near the power steering reservoir. Orange plug- A/C plug
Black/purple plug- ??
These are on the passenger side by the firewall- ???
Ignore the large plug on the left. Small black plug- ???
These are by the front of the car, passenger side, near the battery and headlight
Two black plugs and one black/purple plug- ??
Black plug- ??? black/purple plug- ??
Brunoboy
San Bruno,CA Home of SFO
the orange cap is for the AC Line......Driver side wall by the headlight plug,
4th pic: solenoids on air can and your reverse light switch I think.
5th pic: Fan connectors
6th pic: a 2g maf plug (is it wired permanently in)?
stealthtt24
Orlando, FL
I'm bumping this cause I've edited what I now know and will be posting more plugs in a few minutes...
stealthtt24
Orlando, FL
Damn this is frustrating. I keep finding plugs and they are either too damaged and I need to replace them or I don't know where they need to go /ubbthreads/images/graemlins/bawling.gif
Big plug- Alternator Yellow plug- Power steering
A/C compressor plug
stealthtt24
Orlando, FL
This is off my transmission, broke obviously. what is it? REVERSE LIGHT SWITCH
JSchleim18
Long Island, NY
1. Alternator Plug is the big one...the small one you are holding is for the power steering
2. AC Compressor Plug
3. Reverse Light Switch Plug
