Galant VR-4 Forums » Galant VR-4 » Newbies » Transfercase removal qs
Drdamm21
Galant VR-4 org Post #: 950962 posted 11/20/10 01:59 AM     Remind Me!  Send Private Message   Edit Post
I have taken all the bolt out and I can see the gears inside but it just wont come all the way apart what am I missing ? Thanks to all
| | | IP: (174.254.0.220) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 950964 posted 11/20/10 02:23 AM     Remind Me!  Send Private Message   Edit Post
Umm, if you can see the gears, you took the wrong bolts out. You should only have to remove the exhaust (enough to get it out of the way) remove 5 long bolts holding the x-fer case to the tranny,and then gently pry it off with pry bars. You'll have to support the driveshaft too.,
-Jeff
1881/2000
50/1000
Posts: 7870 | From: KC, Missouri | Member Since: 08/08/04 | IP: (173.118.11.202) | Report this post to a Moderator
Adorsey
Member +
1942/2000
Galant VR-4 org Post #: 951000 posted 11/20/10 08:23 AM     Remind Me!  Send Private Message   Edit Post
17mm bolts. Some are shorter than others, just don't loose em' and put fluid back in it AFTER you re-install it. If needed.
Leave the drain plug in.
1942/2000 DD
[email protected]
93oct b16g
Posts: 355 | From: mass | Member Since: 04/22/09 | IP: (74.82.64.16) | Report this post to a Moderator
geno
Galant VR-4 org Post #: 951070 posted 11/20/10 02:33 PM     Remind Me!  Send Private Message   Edit Post
pulled from VFAQ.com
| | | IP: (76.174.81.70) | Report this post to a Moderator
Diego
Mad Hatter Suite Touche Debackle Guage filled by Justin
1309/2000
Galant VR-4 org Post #: 951158 posted 11/20/10 08:13 PM     Remind Me!  Send Private Message   Edit Post
Why are you looking for GEARS? Are you trying to open it up or just remove?
If remove do what they said ^^^^ 5 bolts a ratchet and an extension will be your best friends here.... pry with a small flat screwdriver and viola... there it is.... support the driveshaft, you don't want drivshaft woes when your said and done with it.
Replace and fill, make sure the tailprop has nothing foreign inside before you install... also check the bushing/bearing inside the tail prop for any defects that could lead to a leak.
"I love blackjack. But I'm not addicted to gambling. I'm addicted to sitting in a semi circle."
91 nile black vr4, 1309/2000
Posts: 2132 | From: In a van down by the river, Io... | Member Since: 12/09/07 | IP: (174.253.180.216) | Report this post to a Moderator
Drdamm21
Galant VR-4 org Post #: 951304 posted 11/21/10 12:44 PM     Remind Me!  Send Private Message   Edit Post
thank you guys for all your help now we will see what option I go with as money will also be tight with xmas and such only around 2k and here in arizona thats not alot.
| | | IP: (66.182.122.10) | Report this post to a Moderator
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.102 seconds in which 0.087 seconds were spent on a total of 14 queries. Turbo powered.
