Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Lube your parking brake cables!
Banthony
555/1000
Galant VR-4 org Post #: 947860 posted 11/10/10 04:19 PM     Remind Me!  Send Private Message   Edit Post
I've owned numerous 6g AWD galants over the years. Every single one of them has either had, or developed a stuck parking brake cable. I recommend to each and every one of you, that you lube your parking brake cables at least annually.
I am replacing one now, and if rock auto hadn't had the right cable (after sending me the wrong one once already) i'd be having a hell of a time finding one, since none of the Vato-Zone style stores seem to carry a parking brake cable for our cars. I tried NAPA, O'reilly, Vatozone, and a couple local places. Nobody had one listed! They may be available from the stealership, but i'd guess they're stupid expensive, and we all know about how the availability of GVR4 specific parts is getting to be. Also, these things are NOT fun to change if you have a rusty car, and dont have the rear subframe down a bit for some other reason. Fortunately, i had to take mine down to put a 4 bolt rear end in, making it easier to get at the cable. I was also fortunate enough to have a car with ZERO rust, so all the bolts came out just like they were brand new.
It's not cool to have a parking brake you can't use, and it's even less cool if one side locks up when it's engaged!
97 CBR900RR
2012 Hyundai Veloster
Posts: 3527 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (130.76.32.197) | Report this post to a Moderator
vapid
"Private" clan, pivot man
674/1000
Galant VR-4 org Post #: 948003 posted 11/10/10 10:14 PM     Remind Me!  Send Private Message   Edit Post
OEM e-brake cables are available, and aren't that expensive. IIRC I paid less than $100 for both.
"Those who hammer their guns into plowshares will plow for those who do not."
-Jefferson
Posts: 918 | From: IL | Member Since: 09/24/05 | IP: (71.201.192.37) | Report this post to a Moderator
Romanova
the coolest person to ever post in the past 2 hours
Galant VR-4 org Post #: 948004 posted 11/10/10 10:17 PM     Remind Me!  Send Private Message   Edit Post
$30 each from JNZ... just ordered a set.
tyler
2016 Explorer PI
2006 LS430
2012 GX460
Posts: 3854 | From: Cypress, TX | Member Since: 08/07/02 | IP: (98.199.14.23) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 948010 posted 11/10/10 10:29 PM     Remind Me!  Send Private Message   Edit Post
Quoting Romanova:
Good to know.
They are still a total bitch to replace.
I'll be making sure mine have a bit of lubrication annually, regardless of their age.
I'm pretty sure my left cable has already been replaced, but I'm not sure.
97 CBR900RR
Edited by mitsuturbo (11/10/10 10:30 PM)
Posts: 3527 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (76.28.228.51) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 948012 posted 11/10/10 10:31 PM     Remind Me!  Send Private Message   Edit Post
Quoting mitsuturbo:
You have no idea what it's like under my car , when I changed out the trailing arms I used a hack saw to get separate the cables from the calipers. The e-brake never worked when I originally bought the car and I probably spent about an hour and half getting the cables off the car. I did it with the car on a lift at the base hobby shop (drive on lift, so no lowering of the subframe), it was easier to use a flat head and mallet to pry the cables loose from where they go into the cabin of the car. The exhaust heat shield is no longer on my car, all those bolts snapped off and plus the shield was crumbling away anyway.
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2714 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (208.79.15.162) | Report this post to a Moderator
Galant VR-4 org Post #: 948013 posted 11/10/10 10:39 PM     Remind Me!  Send Private Message   Edit Post
Use the brake regularly and it will do most of the work for you. I always use mine in all my M/T vehicles.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10607 | From: Michigan | Member Since: 03/05/01 | IP: (74.44.125.7) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 948294 posted 11/11/10 10:17 PM     Remind Me!  Send Private Message   Edit Post
I've always used mine every time i park as well. I've still had 2 lock up. Once while parked.. damn that sucked.
A little oil will help keep water out. It certainly can't hurt to lubricate them from inside the car once a year or so.
I also will remember to lube them from the back end any time the rear wheel comes off for any reason.
97 CBR900RR
Boostdtalon
Member +++
Galant VR-4 org Post #: 948451 posted 11/12/10 03:31 PM     Remind Me!  Send Private Message   Edit Post
I'm going to have to replace mine as one seized up already. Which is the reason I had that caliper seize up too.
Posts: 913 | From: Buckley, Wa. | Member Since: 10/15/09 | IP: (65.188.240.110) | Report this post to a Moderator
citymunky
Fake Title
733/2000
1505/2000
923/2000
832/2000
Galant VR-4 org Post #: 948536 posted 11/12/10 08:10 PM     Remind Me!  Send Private Message   Edit Post
Lube with what? WD-40? Grease?
1990 MMC GVR-4
733/2000 (R.I.P. TurboRen) Sold.
1505/2000 (Loves strippers) Sold.
832/2000 (parts car) R.I.P.
923/2000 (my 1st) R.I.P.
Posts: 1749 | From: Chesapeake, VA | Member Since: 09/22/10 | IP: (70.161.89.44) | Report this post to a Moderator
stealthtt24
Holy deer monkey donkey balls looking for a pole
Galant VR-4 org Post #: 948878 posted 11/14/10 12:02 PM     Remind Me!  Send Private Message   Edit Post
I'm messing with my rear calipers now. Where should we put the grease?
91 GVR4s 1332, 1635, 1507, all sold
Posts: 2746 | From: Orlando, FL | Member Since: 05/25/05 | IP: (71.52.201.14) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 949012 posted 11/14/10 06:32 PM     Remind Me!  Send Private Message   Edit Post
Quoting citymunky:
Check the boot at the back of the cable, if it's torn at all, i suggest getting any kind of lubricant you can in there. Preferably something that displaces water. If you have some way to get some grease in there, then by all means, go for it. ANY lubrication is better than none at all on old cables.
If the boot is not torn at all, i'd just spray copious amounts of WD-40 or PB Blaster down the opening in the center console. Oil has a way of making it to every nook and cranny, as anyone who's had an oil leak already knows. I'm pretty sure that with enough oil going down the cable via gravity and use, this method would keep things working for a long time.
I was VERY fortunate. My cable was VERY easy to replace since i had my diff dropped down already, and my car is rust free. Others have not had such luck, and i'm actually afraid to get under 1411 and see what i'd be dealing with there.
97 CBR900RR
alansupra94
Excuse the retarded question.
4/1000
Galant VR-4 org Post #: 949396 posted 11/15/10 06:21 PM     Remind Me!  Send Private Message   Edit Post
I will be spraying back there tomorrow
1992 Galant VR4
1996 Toyota Supra TT
Posts: 1908 | From: Wayne,NJ | Member Since: 03/03/10 | IP: (173.3.24.20) | Report this post to a Moderator
bobdole
Old member with new to me VR4 and starting over. Respect your elders kids
504/2000
Galant VR-4 org Post #: 949708 posted 11/16/10 03:57 PM     Remind Me!  Send Private Message   Edit Post
just ordered these from the dealer. Mine don't look so good.
Posts: 750 | From: tampa | Member Since: 08/23/07 | IP: (92.26.135.58) | Report this post to a Moderator
1 registered and 9 anonymous users are browsing this forum.
Generated in 0.255 seconds in which 0.213 seconds were spent on a total of 14 queries. Turbo powered.
