Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » JDM RS Hood Vents in a 1G & a ***240***
Garfield Wright
Galant VR-4 org Post #: 929895 posted 09/10/10 05:22 PM     Remind Me!  Send Private Message   Edit Post
I normally don't post customers cars here but since it's got some E39A on it, I thought why not..
We finally installed some E39A vents on a customer's 1G. While I would've liked to put them a little further apart, we couldn't as they would be off centered due to the hump. I would've prefered to put them a little lower which we would be able to space them out a little but then we didn't think they would be that effective because that would put them right over the radiator. Hence the current location. Let me know what you guys think.
This car is 700 @ the front wheels. We still need to do a big brake upgrade to finish it off.
Edited by Garfield Wright (09/21/10 02:36 PM)
| | | IP: (70.147.10.249) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 929897 posted 09/10/10 05:30 PM     Remind Me!  Send Private Message   Edit Post
Customer wants... customer pays... customer gets.
That's about all i have to say about that.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3511 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (130.76.32.15) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 929900 posted 09/10/10 05:40 PM     Remind Me!  Send Private Message   Edit Post
I forgot to mention that this is a daily driver & the temps would rise while in traffic. The vents are to help get rid of the hot air & keep the temps down. It will eventually get painted & should blend in more. While there isn't anything out there specifically for this car, these seem to be the best solution. Low profile & very functional. Those hp #s is boost only. It will be retuned shortly with some NO2 spray ~150-200 shot .
crankwalk
Galant VR-4 org Post #: 929903 posted 09/10/10 05:49 PM     Remind Me!  Send Private Message   Edit Post
I would have probably just gotten a better aftermarket fan BUT painted it will look better.
| | | IP: (67.191.139.238) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 929906 posted 09/10/10 05:54 PM     Remind Me!  Send Private Message   Edit Post
Jay,
It's already running 3 or 4 good quality aftermarket fans. The problem is the 4" fmic & full size radiator (alu) is blocking the airflow. If you notice there's barely any opening in the front. Believe me this was the last thing we did to help cool down the temps.
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 929908 posted 09/10/10 05:57 PM     Remind Me!  Send Private Message   Edit Post
It's not too obtrusive & once painted I don't think they'll look bad at all. Of course I'm from the punch louvers in everything era
Soo... Did it help the temp issue or do you not know yet?
How do you make a small fortune racing? Start with a very large one!!!
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: (75.37.164.150) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 929910 posted 09/10/10 06:00 PM     Remind Me!  Send Private Message   Edit Post
No testing done yet. We just installed them today.
marvinmadman
136/1000
Galant VR-4 org Post #: 929912 posted 09/10/10 06:15 PM     Remind Me!  Send Private Message   Edit Post
I want the white one on the rack!
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2350 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (70.189.17.249) | Report this post to a Moderator
BrandonEchols
Snow White
477/1000
12/1000
Galant VR-4 org Post #: 929923 posted 09/10/10 06:52 PM     Remind Me!  Send Private Message   Edit Post
Am I the only one who is curious how the [email protected] one expects to reasonably put down 700 to the front wheels?
Seems like it would be great at roasting tires, and that's about it.
What is hellaflush?
Mitsubishi = Must Involve Turbos, Suck Unless Boost Is Seriously High Inside
Posts: 793 | From: Anchorage, AK | Member Since: 01/18/10 | IP: (216.67.106.234) | Report this post to a Moderator
donniekak
Member ++
Galant VR-4 org Post #: 929930 posted 09/10/10 07:50 PM     Remind Me!  Send Private Message   Edit Post
How effective was this? If it works well i'm willing to run something like this as a "summer hood". I have had some problems out here running a/c with my 3 1/2" fmic. 120* ambient temps cause tons of heat issues.
Posts: 740 | From: surprise az | Member Since: 01/01/09 | IP: (98.177.143.48) | Report this post to a Moderator
BluFalcon
Fantastic Parts Seller
Galant VR-4 org Post #: 929956 posted 09/10/10 10:19 PM     Remind Me!  Send Private Message   Edit Post
It doesn't look bad at all. If it's functional, even better. Nice, clean looking 1G.
Ed
93 Eagle Talon TSi/AWD
98 Eagle Talon TSi/AWD
06 Mitsubishi Raider V8 DuroCross
521/1000
"SOLD"
Posts: 1306 | From: Wichita, KS | Member Since: 01/20/02 | IP: (76.184.131.73) | Report this post to a Moderator
mikewitdaspike
Galant VR-4 org Post #: 930011 posted 09/11/10 04:38 AM     Remind Me!  Send Private Message   Edit Post
Quoting brandonechols:
that's what i was thinking, if i was putting that much into a car that had an AWD version, I would be putting it into an AWD one, not FWD, but to each their own i suppose vents look good though
| | | IP: (68.3.109.170) | Report this post to a Moderator
mountaineerjeff
<3 NJ
1630/2000
1844/2000
181/1000
Galant VR-4 org Post #: 930143 posted 09/11/10 09:04 PM     Remind Me!  Send Private Message   Edit Post
ud be surprised how much fun a front wheel drive car is on the interstate, which is alot of what they do down in the miami area. alot of interstate pulls and runs with supras from 70-80mph. an AWD will NEVER stay with the same motor in a FWD. they have much less drive train loss and are much lighter, and have way less things to break. there is something about just hanging on to a FWD as it shoots you down the interstate climbing towards 200 mph.
We didnt start the fire! Billy Joel:E39A expert
181/1000 half-a$$ rally-fart
1630/2000 Ballin!
1844/2000 unwillingly put in 'storage'
mirage turbo sold to a guy who will wreck it
2012 EVO, too bad its not a Mitsubishi
Edited by mountaineerjeff (09/11/10 09:05 PM)
Posts: 1155 | From: west virginia | Member Since: 10/22/08 | IP: (98.236.97.23) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 930148 posted 09/11/10 09:40 PM     Remind Me!  Send Private Message   Edit Post
Yeah.. gotta love how FWD has chronic torque steer that changes lanes for you when on coming on boost.
Posts: 2070 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (122.58.186.10) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 930149 posted 09/11/10 09:48 PM     Remind Me!  Send Private Message   Edit Post
Just FYI, Torque steer can be greatly alleviated by swapping in an AWD halfshaft and seal.
97 CBR900RR
Posts: 3511 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (76.28.228.51) | Report this post to a Moderator
Speed_Racer
Galant VR-4 org Post #: 930226 posted 09/12/10 01:25 AM     Remind Me!  Send Private Message   Edit Post
Ever seen HIN? It can be done, doesn't mean its the best option, but its thoroughly possible. Weight transfer is actually counter productive, and traction is still a challenge, but those guys manage. I suppose from a rolling start its less of an issue.
For me? AWD FTW.
Oh as for the vents, looks good to me they don't really improve the look, but it doesn't detract, and they are functional. Wish I had some for my gvr4! Looks better than some of the ricey cf vented hoods.
Edited by Speed_Racer (09/12/10 07:32 PM)
| | | IP: (174.30.8.2) | Report this post to a Moderator
Turboman_456
456/1000
Galant VR-4 org Post #: 930303 posted 09/12/10 12:57 PM     Remind Me!  Send Private Message   Edit Post
Looks good paint them red look better!
If you don't have AWD you don't have SheIit!
Posts: 80 | From: Mason OH | Member Since: 10/24/09 | IP: (24.20.168.48) | Report this post to a Moderator
geno
Galant VR-4 org Post #: 930305 posted 09/12/10 01:04 PM     Remind Me!  Send Private Message   Edit Post
call me retarded ... but i think they would look good painted or not. all the colors go together well. maybe because his in more shiny than mine
| | | IP: (76.174.81.70) | Report this post to a Moderator
Galant VR-4 org Post #: 930422 posted 09/12/10 10:23 PM     Remind Me!  Send Private Message   Edit Post
Looks fine in my opinion. There are far worse choices for vents and these were designed to work in that location to dissipate heat not to direct flow down to a filter, intercooler etc Black on Red looks cool in my opinion because I like the contrast and it matches the black/red thing that's already going on with the car (but by all means colour match them to the hood if you want it to be less obvious).
Posts: 7298 | From: Hong Kong, New Territories | Member Since: 04/19/04 | IP: (116.48.200.146) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 932147 posted 09/17/10 09:21 AM     Remind Me!  Send Private Message   Edit Post
Can someone photo shop these on a 2g for me? Preferably a red & a black one.
| | | IP: (66.229.166.41) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 932152 posted 09/17/10 09:35 AM     Remind Me!  Send Private Message   Edit Post
I think they look about as good as vents can. The car looks great paint wise and I really think the evo8 wheels go well on there.
I'm really wondering if putting those vents in will actually help the overheat problem, though. Maybe I'm wrong but I'd think a really thick radiator is only helping that situation.
-Jeff
1881/2000
50/1000
Posts: 7870 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
Galant VR-4 org Post #: 932153 posted 09/17/10 09:37 AM     Remind Me!  Send Private Message   Edit Post
Leave the vents black and powder coat the wheels to match = badass!
Posts: 7298 | From: Hong Kong, New Territories | Member Since: 04/19/04 | IP: (218.250.63.244) | Report this post to a Moderator
Red_Bird
Galant VR-4 org Post #: 932166 posted 09/17/10 10:11 AM     Remind Me!  Send Private Message   Edit Post
Once they get painted body color I think it will look much better. It's a shame how they can't be more spread apart.
| | | IP: (66.119.4.107) | Report this post to a Moderator
speedyvr4
Still looking for the forest!
536/1000
Galant VR-4 org Post #: 932191 posted 09/17/10 11:05 AM     Remind Me!  Send Private Message   Edit Post
like it was said before, they look about as good as vents can. nice car, yeah here in miami or south florida for that matter since there's so many straight level roads, there's tons of high hp FWD cars roaming around. one thing still remains though, thre's no roll lane at the track . hey garfield hit me up if the guy needs a nice paintjob.
Edited by speedyvr4 (09/17/10 11:06 AM)
Posts: 1245 | From: miami, fl | Member Since: 01/02/06 | IP: (74.169.56.82) | Report this post to a Moderator
2of9
Hellaflush
808/1000
Galant VR-4 org Post #: 932208 posted 09/17/10 11:52 AM     Remind Me!  Send Private Message   Edit Post
Quoting Garfield Wright:
I'm attempting to do it on a 2ga but it looks strange. Trying to find a red 2gb at the moment.
EDIT: here it is. If I could possibly get better pics of the vents or the cars, it could probably look a bit better.
#808/1000
Team Nines DSM Specialist
Edited by 2of9 (09/17/10 12:27 PM)
Posts: 869 | From: IGH, MN | Member Since: 08/29/07 | IP: (65.248.219.46) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 73 anonymous users are browsing this forum.
Generated in 0.23 seconds in which 0.193 seconds were spent on a total of 15 queries. Turbo powered.
