Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » front/side exit exhaust
mountaineerjeff
<3 NJ
1630/2000
1844/2000
181/1000
Galant VR-4 org Post #: 928353 posted 09/06/10 12:11 AM     Remind Me!  Send Private Message   Edit Post
I have always done a cutout on my mitsubishis. Its ridiculously loud and adds some power as well. On 1630 I did a full 3" turbo back, with an expanded stock cat and muffler, than ran a cutout right before the cat for a straight through setup.the biggest problem with this was ground clearance. (pics wont upload?) the bottom of the cutout was not very far below the rest of the exhaust, but on these steep incline here I got alot more bottoming out, before the change I had never bottomed out.
When 1630 decided to be awesome and catch fire, I went and got the mirage in an attempt to have something to drive while I fixed 1630. Well I pulled the 3" o2 housing off 1630 and had a full 3" exhaust made for the mirage. full 3" turbo back, no cat and 3" in 3" out muffler. I then had the cutout installed around the location of the shifter assembly and had it exit out the driver side. there was absolutely no clearance issues at all. but I had much more room due to not having a driveshaft in the way.
long story short the mirage blew a headgasket and left me carless
Well I have decided that it will be much easier and cost effective to just buy another vr4 and swap all my aftermarket stuff over. so I have my turbo setup, and my 3" o2 and I still have my 3" cutout, so I have to have a 3rd exhaust made. So do any of you have none-stock location exits?
I can and probably will switch to a half size radiator, keep the ac/ps/alt. the only other restriction I have is the outlet is at the stock location on the o2. So does anyone have any advice/experience? I need to be able to do some sort of Y setup to allow me to keep the stock/quiet exhaust, and to also give me the most ground clearance possible. I really dont want to cut the front bumper and send it through there. I do have another bumper if that seems to be the general consensus, but id like that to be the last resort.
Any advice, or successful or failed attempts will be appreciated.
We didnt start the fire! Billy Joel:E39A expert
181/1000 half-a$$ rally-fart
1630/2000 Ballin!
1844/2000 unwillingly put in 'storage'
mirage turbo sold to a guy who will wreck it
2012 EVO, too bad its not a Mitsubishi
Posts: 1155 | From: west virginia | Member Since: 10/22/08 | IP: (98.236.97.23) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 928862 posted 09/07/10 07:57 PM     Remind Me!  Send Private Message   Edit Post
I built a side exit for my GSX when I had it. I flattened a piece of 3" pipe down to approx 2"x4.25" and went out right before the drivers side rear tire. I'm sure it could be done on a Galant. It didn't seem to drag anymore than my 3" normal routed exhaust did.
Vibrant now makes ovaled piping if you want to attempt it.
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
05 CTS-V Stealth Grey
09 Hummer H3T
Posts: 1625 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.135.121) | Report this post to a Moderator
mountaineerjeff
<3 NJ
1630/2000
1844/2000
181/1000
Galant VR-4 org Post #: 928877 posted 09/07/10 08:51 PM     Remind Me!  Send Private Message   Edit Post
well I think I go that far back, i will probably just put an elbow on it and just have the exit under the car, thats what I done for the past 2. I was kinda hoping to set this one up with an exit in front of the front tire
1630/2000 Ballin!
Posts: 1155 | From: west virginia | Member Since: 10/22/08 | IP: (67.163.163.47) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 928889 posted 09/07/10 09:34 PM     Remind Me!  Send Private Message   Edit Post
Well I did this car over the summer. Messed with some seat brackets for it today. 3 to 3.5 to 4 inch with the small half moon being the wastegate. Took 3 days to build the exhaust system that ended up being less than 14 lbs. When the cars is debuted locally or should I say its broke off a bunch of checkbook builds I'll post up the data.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11891 | From: Clarksville TN | Member Since: 05/04/03 | IP: (208.95.177.176) | Report this post to a Moderator
mountaineerjeff
<3 NJ
1630/2000
1844/2000
181/1000
Galant VR-4 org Post #: 928945 posted 09/07/10 11:42 PM     Remind Me!  Send Private Message   Edit Post
see I have an exhaust 'sponsor' so I can come up with the most ridiculous stuff and not have to worry about man hours. The only costs I have is when I need something he doesnt normally deal with, like the cutout, or vbands. my o2 housing does have the wastegate recirculated so I wouldnt have to worry about those complications, and I am still going to have a full exhaust as well so the focus isnt on weight but more on the option to flip to a 'drag' setup on the fly, and then back again once to 5-0 shows up.
1630/2000 Ballin!
Generated in 0.241 seconds in which 0.215 seconds were spent on a total of 14 queries. Turbo powered.
