Galant VR-4 Forums » Galant VR-4 » Technical Discussions » hesitation and bog under throttle
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 926163 posted 08/28/10 04:35 AM     Remind Me!  Send Private Message   Edit Post
Ok so 5 Ecu's later, link, and other stuff I just added. FIAV/ISC Blockoff, TB Shaft seals, new BOV, well, I got the car running again today, I always had this problem where it would hesitate at 4k for a bit, then loss of power, boost leak? I have no idea, I use the fog machine to check leaks, and it was only at the TB. Well After I replaced the shaft seals and FIAV/ISC Block off, my vacuum is normal 18 in hg, But now under WOT It seems to bog at 4k hesistate and all the bs. Is this a boost leak? I have no idea, I also have to replace the injector wires tomorrow because the wires are kind of rigged. So, does anyone else have an idea besides BLT?
-Shane
556/1000 KG 8/10/13 .... Sold
352/1000 Summit White sold in 2011 and was totaled by new owner......
92 Eclipse Gsx R.I.P
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (74.51.155.23) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 926236 posted 08/28/10 06:09 PM     Remind Me!  Send Private Message   Edit Post
When i bought 555 it ran like this. Turned out a couple valves were slightly bent.
Check compression. If it's not great, do a leakdown. If everything checks out, make sure your timing is good, your plugs/wires are good, and you're getting proper fuel pressure.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3527 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (76.28.228.51) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 926253 posted 08/28/10 07:23 PM     Remind Me!  Send Private Message   Edit Post
The injector wires might just be the problem. A friends talon recently suffered a similar ailment due to an injector clip that was broken. The car would run as expected until he'd get into the boost. Sometimes at 2 psi, sometimes at 10 or 16, the car would stutter (or bog), lose power, and generally run like crap. He'd back out of it and it'd be back to normal until he'd boost it again. He figured it out by luck, but once we changed that clip it runs awesome.
| | | IP: (68.171.231.16) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 926304 posted 08/29/10 02:58 AM     Remind Me!  Send Private Message   Edit Post
Quoting mitsuturbo:
cant be, I took it to a local dsm shop, he also has a BG vr4. He redid my timing belt and all that, about 1000k miles ago, new plugs new wires, BPR7ES and compression is 150 across the board.
96 Eclipse Gsx Sold
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 926305 posted 08/29/10 03:04 AM     Remind Me!  Send Private Message   Edit Post
im gunna replace it anyways, if you saw how i tried to fix it last time, well lets say Im surprised it runs lol.
96 Eclipse Gsx Sold
bluedeviltsi
Galant VR-4 org Post #: 926540 posted 08/30/10 08:58 AM     Remind Me!  Send Private Message   Edit Post
Could be a bad maf sensor. Once you roll into boost it starts acting up on you could be the maf not reading all of the air the turbo is pulling in correctly.
| | | IP: (76.15.6.146) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 926597 posted 08/30/10 01:45 PM     Remind Me!  Send Private Message   Edit Post
Yea, i did drop the maf hard before installing it hmm
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (207.62.236.106) | Report this post to a Moderator
The_Big_Weave
Member +
Galant VR-4 org Post #: 926605 posted 08/30/10 02:33 PM     Remind Me!  Send Private Message   Edit Post
I had this same problem when I first got 554. One of my lifters broke and shoved a rocker up and away from the valve. So on of the exhaust valves was not open. Take your valve cover off and look and your rockers.
554/1k SOLD
Non-galant owner.
01 S2K
Posts: 390 | From: Rapid City, SD | Member Since: 02/27/09 | IP: (209.159.237.160) | Report this post to a Moderator
farfick
Galant VR-4 org Post #: 926617 posted 08/30/10 02:58 PM     Remind Me!  Send Private Message   Edit Post
This may sound pretty basic, but check your timing. I was having the 4k hesitation issue and my timing was the cause.
| | | IP: (68.118.187.152) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 926982 posted 09/01/10 04:34 AM     Remind Me!  Send Private Message   Edit Post
I dont think it would be anything inside the head, it was all fresh when put together, I am going to do a BLT and Re check timing, but wont be able to check timing til next tuesday. I also changed the injector clips but still same problem, and I will be trying new injectors and dial them in on link and post a log of normal driving, I also replaced the maf and still the same problem, I am thinking the TPS has something to do with it also, and the way i installed the TB shaft seals. Its kind of stiff when I touch the gas pedal.
-Shane
96 Eclipse Gsx Sold
Blown1
Galant VR-4 org Post #: 928487 posted 09/06/10 06:08 PM     Remind Me!  Send Private Message   Edit Post
For the stiff pedal check the throttle cable near where it wraps around the small pulley. If you have a logger just check your tps% I bet it wont be a 100% you can do this with the car not running just turn the key forward and fully depress the pedal. If you are not at 100% when the pedal is all the way in then your throttle cable needs adjusting
| | | IP: (71.235.196.54) | Report this post to a Moderator
stevep
Fixes ECUs
Galant VR-4 org Post #: 928770 posted 09/07/10 04:27 PM     Remind Me!  Send Private Message   Edit Post
The ECU doesn't really care if the TPS doesn't read 100% at WOT, it cares about the changes in position and what it reads when the throttle is closed along with the IPS input.
As long at the TPS reads correctly then the throttle is closed and the throttle cable actually opens the butterfly 100% your all good and what the TPS reads is what it reads. (Within reason, discounting a bad TPS)
The throttle cable needs a bit of slack when the throttle is closed to avoid pulling the throttle open when things heat up.
Edited by stevep (09/07/10 04:29 PM)
Posts: 412 | From: St. Charles, IL USA | Member Since: 10/23/04 | IP: (67.175.252.163) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 928779 posted 09/07/10 04:55 PM     Remind Me!  Send Private Message   Edit Post
On link lite it says 80% on the tps when my foots at WOT. I have a log.
[url=http://www.dsmtuners.com/forums/newbie-forum/378971-hesitation-bog-wot.html]log on tuners
[/url]
96 Eclipse Gsx Sold
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 928991 posted 09/08/10 04:08 AM     Remind Me!  Send Private Message   Edit Post
hey, can my bog be because I have a low temp thermostat installed? 160*F, Maybe its running super rich because it doesnt warm up?
96 Eclipse Gsx Sold
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 929218 posted 09/08/10 04:25 PM     Remind Me!  Send Private Message   Edit Post
bump bump
96 Eclipse Gsx Sold
Banthony
555/1000
Galant VR-4 org Post #: 929251 posted 09/08/10 05:49 PM     Remind Me!  Send Private Message   Edit Post
Quoting brunoboy:
No.
These cars run fine dead cold, in my experience.
I assume since you said compression is 150 all the way across... you DID check it, right?
Just because it was fine last time you checked it, doesn't mean it's fine the next day.
97 CBR900RR
Posts: 3527 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (130.76.32.144) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 929316 posted 09/08/10 09:30 PM     Remind Me!  Send Private Message   Edit Post
shopped checked it, and Ive been getting response on tuners that my log shows I fluctuate from 160-190*F and anything between 126-170 degrees is going to be adding fuel. Also whenever I drive around, the car temp gauge drops all the way back to cold.
-Shane
96 Eclipse Gsx Sold
Tre3zy
correct me if im rite...Wyldcarz been rolling hard for a long time
637/2000
Galant VR-4 org Post #: 929393 posted 09/09/10 12:48 AM     Remind Me!  Send Private Message   Edit Post
your thermostat might be shot if if drops like that....
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
Current Personal Best 11.75 @ 119
Posts: 601 | From: South San Francisco, CA | Member Since: 11/25/08 | IP: (67.169.105.18) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 929414 posted 09/09/10 02:42 AM     Remind Me!  Send Private Message   Edit Post
I will replace it tmrw with a 180*F one, and I maybe getting Phantom Knock. If I gas the car, it rise all light bars of knock without boost......
96 Eclipse Gsx Sold
Banthony
555/1000
Galant VR-4 org Post #: 929457 posted 09/09/10 09:11 AM     Remind Me!  Send Private Message   Edit Post
That sounds like it could possibly be a disconnected/faulty knock sensor.
97 CBR900RR
Posts: 3527 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (130.76.32.145) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 939278 posted 10/13/10 12:28 PM     Remind Me!  Send Private Message   Edit Post
I have a new knock sensor, I put in a new maf, and the hesitation has gotten a LOT better. but still knocks from time to time, I have either and exhaust leak now, or intake manifold gasket leak. I hear it under boost. 0_o.
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (74.51.159.219) | Report this post to a Moderator
dsm10o0
Member ++
705/2000
556/1000
Galant VR-4 org Post #: 939377 posted 10/13/10 04:14 PM     Remind Me!  Send Private Message   Edit Post
Basically we have the same identical problem. haha My car knocks once in awhile and hesitates alot less than before.
91 VR-4 705/2000
92 VR-4 556/1000
03 Evo 8 -New toy
05 Nissan Armada toy hauler
Posts: 680 | From: San Jose CA | Member Since: 06/16/10 | IP: (76.103.136.177) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 939424 posted 10/13/10 06:56 PM     Remind Me!  Send Private Message   Edit Post
lol hopefully someone at the meet knows
96 Eclipse Gsx Sold
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 944342 posted 10/29/10 04:47 AM     Remind Me!  Send Private Message   Edit Post
resolved, the last 4k miles i have been driving with one intake valve not opening due to a fallen rocker. Tre3zy and Ryuto fixed my problem tonight thinking i had to retorque the head and I saw the rocker. replaced and good to go.
-Shane
96 Eclipse Gsx Sold
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (74.51.145.216) | Report this post to a Moderator
citymunky
Fake Title
733/2000
1505/2000
923/2000
832/2000
Galant VR-4 org Post #: 944969 posted 10/31/10 08:00 PM     Remind Me!  Send Private Message   Edit Post
I'm have the same problem with my car, right at 4K or just before 4k my car starts to bog and shutter. The funny thing is if I start boosting after 4.5K I don't have the shutter. After reading this thread I have a lot of stuff to check. I hope I can fix my problem asap
1990 MMC GVR-4
733/2000 (R.I.P. TurboRen) Sold.
1505/2000 (Loves strippers) Sold.
832/2000 (parts car) R.I.P.
923/2000 (my 1st) R.I.P.
Posts: 1749 | From: Chesapeake, VA | Member Since: 09/22/10 | IP: (108.111.192.188) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.267 seconds in which 0.223 seconds were spent on a total of 15 queries. Turbo powered.
