Galant VR-4 Forums » Galant VR-4 » Newbies » Intermittent jerking/bucking while driving?
kitcho
I'm A Canadian
Galant VR-4 org Post #: 921911 posted 08/11/10 03:12 AM     Remind Me!  Send Private Message   Edit Post
I've been having intermittent problems with my car bucking back and forth while driving at normal driving speed (40-60kph). It has happened to me twice in the last two week and is very noticeable. After fairly short, erratic bursts of power loss and car bucking it subsides and my car drives normally.
Searching here, people here mentioned the possibility that it's the transfer case. I had my mechanic who is familiar with dsm's checked it just a couple weeks ago and found no issue (no fluid leak from the yoke). Should I double check the fluid level?
On another site people mention that it could be a coil pack, spark plug, spark plug wire, or injector problem. How do I go about narrowing it down? All I have is a logger and keydiver chip that shows me knock.
thanks
- Adrian
1991 JDM "Evolution" VR-4
Posts: 578 | From: canada | Member Since: 09/11/06 | IP: (24.89.87.11) | Report this post to a Moderator
SmoothCustomer
Public school educated knowitall
Galant VR-4 org Post #: 921912 posted 08/11/10 03:18 AM     Remind Me!  Send Private Message   Edit Post
I agree about the ignition stuff. You narrow it down by replacing all of it because it's cheap and could probably use it anyway. Also I would bet your problems are actually just a boost leak.
-Eric
2015 FR-S
Posts: 3319 | From: Lexington, KY | Member Since: 07/06/08 | IP: (74.74.141.199) | Report this post to a Moderator
Specter
Member +
Galant VR-4 org Post #: 921915 posted 08/11/10 03:36 AM     Remind Me!  Send Private Message   Edit Post
Could be your fuel pump too Mine used to do the same, turned out to be a dieing fuel pump. Start with the usual things, check the fuel pump flow, check your spark plugs, check for boost leaks, check for any torn vacuum pipes etc
Posts: 367 | From: Karachi, Pakistan | Member Since: 04/20/08 | IP: (124.29.192.88) | Report this post to a Moderator
kitcho
I'm A Canadian
Galant VR-4 org Post #: 921985 posted 08/11/10 01:05 PM     Remind Me!  Send Private Message   Edit Post
Weird.
I did a quick log this morning, only to find that my front o2 sensor is showing 0.00v all the time for some reason. I guess I'll start with that.
Thanks for the replies as well
broxma
retard monkey strength
379/1000
Galant VR-4 org Post #: 922011 posted 08/11/10 02:25 PM     Remind Me!  Send Private Message   Edit Post
Also, BOV. In particular if you replaced it with an aftermarket one with an adjustable spring.
Start with the easiest to check and move from there.
/brox
I am big into recycling though and if your not into sacrifice or burnt offerings, you may want to stick with 93 octane.
/brox
Posts: 911 | From: San Antonio Tx | Member Since: 11/16/09 | IP: (99.52.72.193) | Report this post to a Moderator
Dbossman
Galant VR-4 org Post #: 922712 posted 08/14/10 01:26 PM     Remind Me!  Send Private Message   Edit Post
Sounds like a miss IMO. Check ignition components and definitely do a boost leak test first off. Very well could be a leak for sure. Boost leak test is your cheapest, check that first. Then look at your plugs.
| | | IP: (166.137.143.139) | Report this post to a Moderator
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.275 seconds in which 0.261 seconds were spent on a total of 14 queries. Turbo powered.
