Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » 359/2000's new heart
biglady112
or what
359/2000
Galant VR-4 org Post #: 919610 posted 08/02/10 04:45 AM     Remind Me!  Send Private Message   Edit Post
Picked this car up last month. The motor was in bas shape. And so was the tranny. I have just a few more parts before I can drop the motor in. And the tranny I hope will go back together some time this week or next. I leave for Bonneville on the 12th, I am hoping to have it all at least assembled by then. But I have spent a bunch more than anticipated and am basically waiting on another check before I go.
65mm turbo
.040" over topline pistons
.010/.010" turned crank
Reconditioned stock rods
Clevite bearings
Ebay 38mm wastegate
Modified and rewelded ebay T3 manifold
And a few small tricks here and there. Just enough to hopefully make it reliable. Looking for 350-400whp when it is said and done. On stock cams, head and intake.
And yes, that is all that there is to the exhaust. Less than a foot of 2.5" pipe.
I GIVE ZERO FUCKS. I HATE YOU ALL.
Edited by biglady112 (08/28/10 09:25 PM)
Posts: 1233 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (71.229.148.88) | Report this post to a Moderator
JB
Other
Galant VR-4 org Post #: 919632 posted 08/02/10 09:27 AM     Remind Me!  Send Private Message   Edit Post
Looking good.
JBiz
Half Man, Half Amazing
Posts: 5836 | From: MA | Member Since: 08/15/04 | IP: (108.7.34.19) | Report this post to a Moderator
broxma
retard monkey strength
379/1000
Galant VR-4 org Post #: 919651 posted 08/02/10 11:23 AM     Remind Me!  Send Private Message   Edit Post
Looks very much along the lines of what I did so I approve. I like the AN fitting on the pan.
/brox
I am big into recycling though and if your not into sacrifice or burnt offerings, you may want to stick with 93 octane.
/brox
Posts: 911 | From: San Antonio Tx | Member Since: 11/16/09 | IP: (99.52.72.193) | Report this post to a Moderator
mayat
Galant VR-4 org Post #: 919673 posted 08/02/10 01:03 PM     Remind Me!  Send Private Message   Edit Post
it can go till how bhp max??
| | | IP: (120.140.41.154) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 919733 posted 08/02/10 04:02 PM     Remind Me!  Send Private Message   Edit Post
No idea. But I am sure it will do what I need from it.
Blown1
Galant VR-4 org Post #: 919793 posted 08/02/10 07:45 PM     Remind Me!  Send Private Message   Edit Post
looks nice what did you use on the oilpan though looks too thick almost
| | | IP: (71.235.196.54) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 919800 posted 08/02/10 08:17 PM     Remind Me!  Send Private Message   Edit Post
Red RTV. I am a little generous with it as you can see.
biglady112
or what
359/2000
Galant VR-4 org Post #: 926275 posted 08/28/10 10:01 PM     Remind Me!  Send Private Message   Edit Post
The motor is ready to go in. Should be up in the next few weeks running around.
1990/2000
Galant VR-4 org Post #: 926279 posted 08/28/10 10:38 PM     Remind Me!  Send Private Message   Edit Post
That looks ambitious, Steven.
May I humbly suggest that you install an inline filter in your turbo oil feedline...
The only filtered oil on that style housing comes from the angled port that you have plugged.
Posts: 3525 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.90.55) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 926280 posted 08/28/10 10:41 PM     Remind Me!  Send Private Message   Edit Post
If that is the case John, I will just simply swap them. Duly noted.
I assumed on all the housings that the top right port was filtered.
Edited by biglady112 (08/28/10 10:42 PM)
1990/2000
Galant VR-4 org Post #: 926282 posted 08/28/10 11:15 PM     Remind Me!  Send Private Message   Edit Post
Sorry about the shitty pics...
Been meaning to do a how-to on the '90 oil fitler housing and cooler set-up, but haven't had the time to get better pics or do the write up. (shaddup Curtis )
Here's the outer port.
Note that it's fed by the lower passageway
Here's the filter side of things ('91 style lefty/ '90 style righty)
Hopefully, you can see the drilling for the port you've tapped (arrow) is in the same passageway that feeds the outside of the filter.
The oil filter is fed from the outside, and filtered oil goes up the center tube.
The only filtered oil with this style housing is the angled big center port.
biglady112
or what
359/2000
Galant VR-4 org Post #: 926283 posted 08/28/10 11:22 PM     Remind Me!  Send Private Message   Edit Post
How about some pictures or explanation for the 90 air cooled housing? I run that on the other car. I will swap the line before the motor goes in tonight.
475/1000
Galant VR-4 org Post #: 926284 posted 08/28/10 11:23 PM     Remind Me!  Send Private Message   Edit Post
(shaddup Curtis )
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11886 | From: Clarksville TN | Member Since: 05/04/03 | IP: (208.95.177.176) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 926285 posted 08/28/10 11:29 PM     Remind Me!  Send Private Message   Edit Post
-Only- filtered port on the '90 housing
The factory oil flow diagram for this filter housing is a piece of shit!
It looks so simple on paper.
Untill you have it in your hand, you won't understand how it works.
... even then, it's kind of a mind bender of thermo-elasti-visiocositification ...
(shaddup Curtis !!! )
Edited by toybreaker (08/28/10 11:35 PM)
biglady112
or what
359/2000
Galant VR-4 org Post #: 926288 posted 08/28/10 11:37 PM     Remind Me!  Send Private Message   Edit Post
So that is the filtered side on the 90? If so I am wrong there as well. Again, I was told the top right ports were all the filtered ones. That is what I get for not looking and taking someone's word for it.
I do see it now that it has been pointed out to me. I will have to wait on the race car until I bring it home. But I will adjust the galant tonight.
Edited by biglady112 (08/28/10 11:39 PM)
1990/2000
Galant VR-4 org Post #: 926294 posted 08/29/10 12:55 AM     Remind Me!  Send Private Message   Edit Post
Damn, it sucks getting old
Awhile back we had a thread running here that had me wondering about how the oil cooler set-up actually works, and where the best place was to tap the housing for an oil line to feed the turbo.
I've seen all manner of different configurations to feed the turbo, and a few write-ups that conflicted/didn;t match what I was seeing on the housings I had in front of me.
If you start with the premise that the oil filters from the outside of the filter to the center, the best and only sure way to know you're recieving filtered oil is to shine a light down the center hole of the filter housing and use a port that you can see light thru.
After I sober up (tomorrow or the next day ), I'll re-check a few housings and post up something that makes sense
RedTwo
Rangi Kiwi
Galant VR-4 org Post #: 926426 posted 08/29/10 07:58 PM     Remind Me!  Send Private Message   Edit Post
Is that pressure outlet tube to the T/B going to fit?
Posts: 1917 | From: New Zealand | Member Since: 07/16/08 | IP: (210.54.239.228) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 926445 posted 08/29/10 09:06 PM     Remind Me!  Send Private Message   Edit Post
There is a good 4-6" of clearance to the strut. Motor slid right in last night.
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 931138 posted 09/14/10 04:31 PM     Remind Me!  Send Private Message   Edit Post
I really like your water outlet what size an fitting is that and where did you get that
565/2000
699/2000
Random 1gb FWD I bought
Posts: 328 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (64.134.188.16) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 931146 posted 09/14/10 05:12 PM     Remind Me!  Send Private Message   Edit Post
Regarding your water pump drive belt...
How are you going to ensure it stays tight? There is zero adjustment. Is this really a good idea?
I'm not sure if my relocated alternator is going to want to hit the frame, so i picked up a 94 water pump/power steering pulley, and power steering pump. I'll figure a way to make it work. I'm hoping it doesn't hit the frame so it will be easy.
Keeping power steering seems to present more problems when relocating the alt.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3526 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (130.76.32.167) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 931353 posted 09/15/10 02:52 AM     Remind Me!  Send Private Message   Edit Post
They are both -12 fittings. I had a friend help me with them both.
The belt will be fine. I have been running this exact same setup(same size belt) on my colt for two years now. Maybe more. And that car sees nearly 9000rpm each time it runs. The belt has to be walked on and is pretty tight. But not too tight it stresses the water pump. Pretty simple setup really.
I ditched power steering in order to make it look clean, less parts to fail and for more freedom with my turbo setup.
Banthony
555/1000
Galant VR-4 org Post #: 931476 posted 09/15/10 12:25 PM     Remind Me!  Send Private Message   Edit Post
Is there enough room to run the alternator off the outer ribs on the crank pulley?
I'm afraid the alternator is going to want to hit the frame if it's that far forward.
97 CBR900RR
Edited by mitsuturbo (09/15/10 12:26 PM)
Posts: 3526 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (130.76.32.23) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 931631 posted 09/15/10 08:53 PM     Remind Me!  Send Private Message   Edit Post
There is. I think most relocations kits run on the outer ribs of the pulley. If they don't I am pretty sure there is room without a doubt.
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.242 seconds in which 0.203 seconds were spent on a total of 14 queries. Turbo powered.
