Galant VR-4 Forums » Galant VR-4 » Newbies » FIAV block off ??
FIAV block off ??
dsmless
gay without homosexual tendencies
96/1000
Galant VR-4 org Post #: 917585 posted 07/24/10 12:42 AM     Remind Me!  Send Private Message   Edit Post
I have tried to find the passageway to plug up, i searched here but no luck and i found a good pic on tuners but for some reason I should of saved it but i didnt so any one know of it, ?
96/1000 back in the driveway jsb getting a
lego motor
Posts: 224 | From: tucson,az | Member Since: 06/12/08 | IP: (206.29.188.178) | Report this post to a Moderator
brisvr4
Oceania Distict Enforcer for the Galant VR4 Mafia
Galant VR-4 org Post #: 917595 posted 07/24/10 01:28 AM     Remind Me!  Send Private Message   Edit Post
Here you go. Look at the very last post, pretty easy to do. Watch out for the screw heads though, they are very soft and strip easily! I replaced mine with allen head bolts.
Fiav
Tim
1992 Auspec
11.37 @ 131.46 - E85 goodness and stock block!
Official Australian home of the Ugh decal!
Edited by brisvr4 (07/24/10 01:29 AM)
Posts: 936 | From: brisbane australia | Member Since: 02/13/04 | IP: (121.208.180.27) | Report this post to a Moderator
SmoothCustomer
Public school educated knowitall
Galant VR-4 org Post #: 917596 posted 07/24/10 01:29 AM     Remind Me!  Send Private Message   Edit Post
Huh? You know it's a plate right? It's just the lower part of the throttle body. I think it's the part that has water lines coming off of it iirc.
-Eric
2015 FR-S
Posts: 3319 | From: Lexington, KY | Member Since: 07/06/08 | IP: (74.74.141.199) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 917621 posted 07/24/10 10:48 AM     Remind Me!  Send Private Message   Edit Post
The above image shows the lower half once separated. Steps are as follows...
1) Remove TB
2) Remove the 5 screws which connect the lower half of the TB. If they strip then drill them out and then remove with vice-grips once the TB is separated.
3) If blocking both the FIAV and ISC then you can toss the lower half and just slap the block-off-plate on with some rtv. If you're just blocking FIAV and leaving the ISC intact then you have to bolt the lower half back on using the plate in a "sandwich" fashion.
Roger B. Scott
'91 Belize Green
Posts: 3295 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (174.45.93.14) | Report this post to a Moderator
Adorsey
Member +
1942/2000
Galant VR-4 org Post #: 917804 posted 07/25/10 01:21 PM     Remind Me!  Send Private Message   Edit Post
throttlebodys.com for both types of plates.
+1for Steve, very good guy.
1942/2000 DD
[email protected]
93oct b16g
Posts: 355 | From: mass | Member Since: 04/22/09 | IP: (74.75.0.172) | Report this post to a Moderator
dsmless
96/1000
Galant VR-4 org Post #: 917918 posted 07/26/10 01:10 AM     Remind Me!  Send Private Message   Edit Post
Thanks for all the help, I just ended up bypassing the FIAV by removing the freeze plug on one side and using a pair of needle nose pliers to screw the adjusting nut until it "bottomed" out on the valve seat, then just filled the rest of the passage with high temp rtv and banged the freeze plug back in waited for an hour for the rtv to set and tuned the car on, it does require me to press the throttle for like ten seconds and then it will idle fine, adjusted idle at 950 with AC on and 850 regular idle, very happy with this mod sould of done it sooner, the best thing is that I didn't even separate the throttle body just popped the freeze plug off, know one question
1) what do you have your TPS sensor set at at idle? Mines at 12%, is this to high or.......
lego motor
Posts: 224 | From: tucson,az | Member Since: 06/12/08 | IP: (206.29.188.190) | Report this post to a Moderator
Adorsey
Member +
1942/2000
Galant VR-4 org Post #: 917955 posted 07/26/10 09:20 AM     Remind Me!  Send Private Message   Edit Post
The HZ? or.... are you using a palm? or link?
1942/2000 DD
[email protected]
93oct b16g
dsmless
96/1000
Galant VR-4 org Post #: 918086 posted 07/26/10 04:03 PM     Remind Me!  Send Private Message   Edit Post
Im using a palm and TPS says 8.9% MAF 25hz at 1187 idle
lego motor
Posts: 224 | From: tucson,az | Member Since: 06/12/08 | IP: (206.29.188.185) | Report this post to a Moderator
speedyvr4
Still looking for the forest!
536/1000
Galant VR-4 org Post #: 918415 posted 07/27/10 09:06 PM     Remind Me!  Send Private Message   Edit Post
wow that seems like high idle for such low hertz. are you compensating with anything? afc? maft?
Posts: 1245 | From: miami, fl | Member Since: 01/02/06 | IP: (174.48.147.208) | Report this post to a Moderator
Generated in 0.034 seconds in which 0.016 seconds were spent on a total of 14 queries. Turbo powered.
