BNIB Sprint Lowering springs on a GVR4
RHDgalantVR4
Calgary Alberta
Have a chance to get them for $100 they are off a 91 TSI AWD they gonna work?
belize1334
Bozeman, MT
They'll bolt in but the rear will probably ride a bit low.
Barnes
Richland, WA
Won't the front ride low too? Aren't stock GVR-4 springs taller than stock DSM springs?
RHDgalantVR4
Calgary Alberta
2" drop and buddy selling them says they worked in his 2000GTX? I dunno /ubbthreads/images/graemlins/confused.gif
AWDnoobie
Alberta, Canada
Well a 2000gtx is a Eagle copy of the galant. I wonder if it was a awd version too. Sorry for lack of help, may a bump will get you more info
belize1334
Bozeman, MT
All I know is that, proportionately, Galants have more rear travel that DSMs. So, a DSM spring will lower the back more than the front and it ends up squatted down in the back. Now, depending on the particular spring this may not be an issue. But stock DSM springs on a Galant look like your always launching at the strip.
Hertz
Chicago, IL
Quoting AWDnoobie:
2000 GTX = Galant GSX
Not so much a copy as it is just re-badged.
RHDgalantVR4
Calgary Alberta
one more thing is a 255/40ZR17 with a 2" drop possible without spacers?
mmc_gsx
Edmonton, AB. Canada
Hey Corey, Are you sure about 255? or may be 225?
RHDgalantVR4
Calgary Alberta
nope 255 off a 8"wide Mustang G/T i can get a set of 4 one season old for $100
RHDgalantVR4
Calgary Alberta
this is my VR4 hope pic works
Quoting RHDVR4GALANT:
I'm running a 225/50R17 on 4G eclipse wheels with factory springs and I only clear the front struts by 1/4 inch, the rear trailing arms clear by even less, and under moderate suspension compression the tires rub lightly on the front fenders.
