Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Radiator fan at low speed & fan control
Nabeel
Member +
Galant VR-4 org Post #: 889992 posted 04/13/10 04:09 PM     Remind Me!  Send Private Message   Edit Post
Just wondering how to let the radiator fan runs at low speed continuously when ignition ON tel get the emergency signal to go high speed! Also Any body tryed aftermarket radiator fan controler?
91 VR4
09 GT eclipse
91 Cefiro
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (92.48.24.108) | Report this post to a Moderator
G
obsessed with the turds of others
486/1000
Galant VR-4 org Post #: 890093 posted 04/13/10 09:01 PM     Remind Me!  Send Private Message   Edit Post
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8822 | From: zompton | Member Since: 02/24/04 | IP: (98.144.66.243) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 890155 posted 04/14/10 02:34 AM     Remind Me!  Send Private Message   Edit Post
Mr.G'
I know there are so many aftermarket fan controlers. Have you tryed Sard? or just something come on mind. I am woryed about wiring them. I think GVR4 cooling system is kind of complicated.
91 VR4
09 GT eclipse
91 Cefiro
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (109.82.118.83) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 890437 posted 04/15/10 01:39 AM     Remind Me!  Send Private Message   Edit Post
So...No body knows!
91 VR4
09 GT eclipse
91 Cefiro
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (212.116.220.149) | Report this post to a Moderator
Muskrat
665/2000
Galant VR-4 org Post #: 890462 posted 04/15/10 07:22 AM     Remind Me!  Send Private Message   Edit Post
This is just a guess, you'll need to learn to read the electrical diagrams and confirm for yourself.
The fan switch in the radiator controls low speed operation. Instead of running the switch, wire an automotive relay up to a switched power source, and run the fans directly from that, instead of the stock fan switch.
Brian L.
91 Galant VR-4 #665/2000
Posts: 2105 | From: Lexington, KY | Member Since: 06/13/04 | IP: (63.238.139.239) | Report this post to a Moderator
Galant VR-4 org Post #: 890568 posted 04/15/10 01:07 PM     Remind Me!  Send Private Message   Edit Post
Good answer for the low speed constant operation idea. Not so sure without the temp switch signal that it will ever judge the need to go to high speed. Or does the high speed only run when the AC condenser fan is on? I can't remember.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10526 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.228) | Report this post to a Moderator
Muskrat
665/2000
Galant VR-4 org Post #: 890582 posted 04/15/10 01:38 PM     Remind Me!  Send Private Message   Edit Post
I could be wrong, but I was under the impression high speed control was based off one of the t-stat housing sensors. I think the switch in the radiator is just that a switch. If it needs to be "ON" for high speed operation, your right.
However, here's another, better, idea: Unplug the fan switch and short the wires. That should do exactly what you want, be really simple, and as far as the circuit is concerned the switch would always be closed.
Again, I highly suggest doing the appropriate research and checking out how everything is wired with the circuit diagrams in the FSM.
Edited by Muskrat (04/15/10 01:52 PM)
Nabeel
Member +
Galant VR-4 org Post #: 890651 posted 04/15/10 05:18 PM     Remind Me!  Send Private Message   Edit Post
Actually I did alot of search. there is no clear answer on how GVR4 cooling system works. some electric maps available I thing from the manual. But I could not understand the theory. Recently booth fans will run at high speed only when gets hot. I think it is by the ECU through the temp. sensor. the switch under the fan is new. I am not sure how to bypass the Fan resistor & it should be wired as stock now. both fans will also work at high when AC is ON. I tryed to bypass the radiator switch ...no change..I tested the relays & fuses. They looks fine. Note: the thermostat is new & radiator is also new with fresh cooling water.
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (109.82.174.105) | Report this post to a Moderator
Alainb7
Galant VR-4 org Post #: 1000646 posted 06/20/11 09:03 PM     Remind Me!  Send Private Message   Edit Post
The system is very simple.
You have 2 relay in the fuse box. They are id as Rad Fan. The one nearest the shock tower is the Lo speed one. The middle one is the hi speed one.
The Lo speed relay is activated by the sensor in the bottom of the radiator. It is a 2 wire connector) It start at 185f and stop at 172f.
To go lo speed, the negative wire of the fan is bypass via the fan resistor (bolt on fan housing).
The high speed relay is ativated by the sensor behind the thermostat housing. It is a 1 pin sensor with a Blue wire with a black line on it. It start at 215f and stop at 206f.
If you want to have the hi speed relay activated at on switch position, just unconnect the connector from the 1 pin sensor with a Blue wire with a black line on it behind the thermostat housing and put it to ground.
If you want to have the lo speed relay activated at on switch position, just unconnect the connector from the 2 pin sensor on the radiator, just made a jumper between both pin.
In both case, fan will start at on position because the positive activation of the relay is only powered at on position.
Me what I do is to use 2 fan in High speed. I do not have no more AC.
I want to use AC fan as first to start (To force air to pass true the rad to prevent turbo to heat-up the rad) so i leave the hi speed system to start the Pull fan when temperature hit 215f in the engine.
And i modify the lo speed relay system to start the pull fan (AC oem one)but at hi speed.
I remove the 3 srew that hold the fuse box to acces the wire under the fusebox.
I cut the 2 wire of the lo speed relay (Blue wire with white line and cut also the blue wire) Carefull, both lo & hi speed relay has the blue wire with white line.
Insulate the 2 wire you just cut that go in the wire hardness to prevent short.
Then use the 30a fuse of the AC to feed the AC fan. You cut the Black wire with white line and bring it to the blue wire of lo speed relay, then pass a new wire from the blue wire with white line of the lo speed relay and bring it to the fan.
You cut both wire of the fan, plug the new wire and the other wire of the fan, just put it to ground.
Again, insulate the 2 old wire of the fan to prevent short.
92 Mitsubishi Galant VR-4,4g63 A/T AWD turbo [email protected] mph, 0-60 mph:3.40s, 50-75 mph:2.3s
Gone in 11 seconds GO FAST WITH CLASS, DON'T USE NOS!
Edited by AlainB7 (06/21/11 03:50 PM)
Posts: 60 | From: Montreal, Quebec, Canada | Member Since: 03/24/11 | IP: (65.94.3.65) | Report this post to a Moderator
Darksyne
Galant VR-4 org Post #: 1001131 posted 06/23/11 06:52 AM     Remind Me!  Send Private Message   Edit Post
Posted this in another thread. Looks like it would help here as well.
| | | IP: (96.244.9.4) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 1003389 posted 07/05/11 03:52 PM     Remind Me!  Send Private Message   Edit Post
It seems that my fan does not kick on at high. Which sensor would it be? The sensor on the thermostat? I always thought that was for the gauge?
92 GVR4 #802 link
06 EvoIX SSL-417HP/418TQ-OEM Turbo E85 / Ohlins DFV
94 MX5 M-Edition - On Xidas
SOLD: 92 GVR4 #611
Posts: 790 | From: Corona, CA | Member Since: 04/08/08 | IP: (98.189.79.130) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 1003427 posted 07/05/11 06:57 PM     Remind Me!  Send Private Message   Edit Post
At the thermostat there are two sensors the one with two pin is the one you are asking. But it could be faulty relay. Logger is the easy way to check that sensor.
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (79.170.51.107) | Report this post to a Moderator
Generated in 0.245 seconds in which 0.209 seconds were spent on a total of 14 queries. Turbo powered.
