Galant VR-4 Forums » Galant VR-4 » Newbies » Stock Intake Manifold Modifying?
mean_green
Member +
1632/2000
Galant VR-4 org Post #: 844111 posted 10/26/09 11:27 PM     Remind Me!  Send Private Message   Edit Post
While I have my intake mani off is there anything I can do to it to make it perform better? Can I port it out? Maybe someone has a link they could show me on a 'how to' do this...
TIA
-Al
1632 & now 1793 -1/6/18
Posts: 310 | From: Park City, MT 59063 | Member Since: 11/12/07 | IP: (24.72.223.108) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 844129 posted 10/27/09 12:50 AM     Remind Me!  Send Private Message   Edit Post
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (71.38.145.95) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 844198 posted 10/27/09 11:40 AM     Remind Me!  Send Private Message   Edit Post
Just get a cyclone manifold and kiss the stocker good by. It flows just as well as stock and will lower your boost threshold by about 200 rpms as seen in this dyno comparison.
Roger B. Scott
'91 Belize Green
Posts: 3295 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (72.175.127.40) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 844205 posted 10/27/09 12:10 PM     Remind Me!  Send Private Message   Edit Post
Don't bother porting it yourself. You'll get maybe 1 hp and could end up with metal shavings getting into the engine if you don't clean it well enough. You can however send it off and have it extrude honed. This smooths out the runners and polishes the runners too. It will increase air flow and power, but if your running a stock engine you'll barely notice.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: (24.220.12.198) | Report this post to a Moderator
Ralli380Gvr4
Bearded Snow Leopard
380/1000
Galant VR-4 org Post #: 844226 posted 10/27/09 01:31 PM     Remind Me!  Send Private Message   Edit Post
I've been planning on getting my factory intake manifold extrude honed. I wish there was a flow comparison between an extrude honed manifold, cyclone and the Evo III. Does anyone on the board run an Evo III intake manifold?
-E
#380/1000 A72 Summit White E39A - Daily click
1993 Mustang GT - Resto Mod/Project Car
Posts: 587 | From: BOULDERADO/UWS-NYC/BURQUE | Member Since: 12/27/06 | IP: (216.55.149.217) | Report this post to a Moderator
1qkfwd
1868/2000
Galant VR-4 org Post #: 844333 posted 10/27/09 06:17 PM     Remind Me!  Send Private Message   Edit Post
I'm getting ready to run an Evo III mani. From what I read it's only gonna make a difference if your running a 2g head since the ports line up in size.
And to add isn't the extrude hone almost if not more than buying an aftermarket intake. Originaly when I was looking, I ended up paying about the same for my JMF as the extrude hone.
92 eclipse FWD [email protected]
92 Talon AWD Best et [email protected] 1.39 60'
2011 GTX series here we come!
#1868/2000 Looking for 10s on pump
Edited by 1qkfwd (10/27/09 06:21 PM)
Posts: 209 | From: Sun Valley, NV | Member Since: 09/29/09 | IP: (166.205.130.187) | Report this post to a Moderator
RedTwo
Rangi Kiwi
Galant VR-4 org Post #: 844348 posted 10/27/09 06:41 PM     Remind Me!  Send Private Message   Edit Post
Bimmerbishi? ran a dyno comparison of a 2g manifold vs Evo 3 manifold.
I thought the 2g/evo manifold didn't even seal around the intake ports on a 1g/VR4 head?
Posts: 1917 | From: New Zealand | Member Since: 07/16/08 | IP: (210.54.239.228) | Report this post to a Moderator
Rock Star Status
Galant VR-4 org Post #: 844412 posted 10/27/09 10:03 PM     Remind Me!  Send Private Message   Edit Post
!g and 2g/early Ebo ports are indeed different. Anythign that will fit the latter will not just bolt up to a 1g head and work.
The Extrude honing was a great option when there really weren't any options, or if you're of the 'every last ounce from a bone stock car' persuasion.
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (76.189.146.118) | Report this post to a Moderator
1qkfwd
1868/2000
Galant VR-4 org Post #: 844441 posted 10/28/09 01:49 AM     Remind Me!  Send Private Message   Edit Post
They don't line up the ports on a 2g are slight higher than a 1g. That's what gives it a straighter shot of air to the valve. I am going to use a 2g head on my 6-bolt. That way I'll be able to use the Evo 3 mani. There's rumors going around that the Evo mani has made upwards of 600 hp, and that's about where it becomes a restriction. I will test that theory.
I believe the only good option is a ported cyclone manifold. I've seen dyno results of the two and cyclone has incredible low and mid range. It tends to die off a Lil more than the 1g. Knowone really wants to take the time to properly port and setup the cyclone. It's just to easy to fork out the cash for a sheet metal intake.
715/1000
1284/2000
Galant VR-4 org Post #: 844495 posted 10/28/09 10:45 AM     Remind Me!  Send Private Message   Edit Post
I like my cyclone manifold. My horsepower and torque curves are crazy. Some day I'll have it extrude honed so I can pick up a few in the high end. I like the increase in torque and drivablity of the cyclone manifold in a daily driver. If your going full blown 10sec drag car, then a SMIM is the best option.
12yr+ Vr4 owner.
Family Guy
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 844496 posted 10/28/09 10:49 AM     Remind Me!  Send Private Message   Edit Post
Quoting Rausch:
......if you're of the 'every last ounce from a bone stock car' persuasion.
I like the idea of keeping the engine bay "stock looking". I also like the idea of an easy 20hp from the process BUT $440+core for the work is just not worth the $$$ IMO. It comes out to $22 per 1HP. Again, personally I would like to keep the stock look over the SMIM for sleeper effect only..... I do have several cores to send out so there would be no down time if FFWD would do sometig on the price
Sent from my iPhone
2007 Shelby GT
2002 RAM 1500 Quad Cab DD
1968 Camaro 427BB
2006 GSX-R 750 SOLD 3/19/12
1991 GVR4 #381 SOLD 3/27/12
Edited by 381gvr4 (10/28/09 10:51 AM)
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (72.209.35.48) | Report this post to a Moderator
1qkfwd
1868/2000
Galant VR-4 org Post #: 844517 posted 10/28/09 12:14 PM     Remind Me!  Send Private Message   Edit Post
You can add a 50 wet shot for half that price and still keep the stock look. So it looks as if the process is still up there in price. I guess the only advantage I see in this is road racing and running in a stock class.
You should be able to hand port the cyclone, that the joys of takin it apart.
Lonewolf64
Obviously the answer is......
889/1000
1247/2000
Galant VR-4 org Post #: 844522 posted 10/28/09 12:24 PM     Remind Me!  Send Private Message   Edit Post
Is it possible to get a cyclone manifold extrude honed? I would imagine this would be the best of both worlds.
1992 Galant VR-4 #889
1991 Galant VR-4 #1247
2007 Civic Si DD
Posts: 1195 | From: Birmingham, Alabama | Member Since: 05/18/06 | IP: (141.166.236.76) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 844535 posted 10/28/09 01:09 PM     Remind Me!  Send Private Message   Edit Post
No reason you couldn't. You'd have to take the butterfly plates out and then plug the shaft holes and then reassemble the manifold so that the process was uniform for each runner w/o compromising the butterfly shaft seals. On the other hand, you could leave the primaries alone and just hone the secondaries. That'd keep the low RPM the same and just exaggerate the affect of the secondaries.
Roger B. Scott
'91 Belize Green
Posts: 3295 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (153.90.194.247) | Report this post to a Moderator
Ralli380Gvr4
380/1000
Galant VR-4 org Post #: 844545 posted 10/28/09 02:02 PM     Remind Me!  Send Private Message   Edit Post
Oh yeah...I forgot about the Evo III/2g head difference.
Quoting 381gvr4:
Quoting Rausch:
I like the idea of keeping the engine bay "stock looking". I also like the idea of an easy 20hp from the process...I would like to keep the stock look over the SMIM for sleeper effect only....
I'm w/ 381gvr4, I Like keeping a sleeper engine bay..I like the idea of honing a cyclone, and leaving the primaries alone. Seems like it would be costly venture but the results might be cool for a street car. But a hawver cast manifold seems like a good option for the price($550+s/h), here's a dyno comparison to a 1g.
-E
Posts: 587 | From: BOULDERADO/UWS-NYC/BURQUE | Member Since: 12/27/06 | IP: (216.55.149.216) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 844550 posted 10/28/09 02:11 PM     Remind Me!  Send Private Message   Edit Post
Contacted Darren at FFWD and he said they are still offering the EH service. I'll ask him about a group buy if anyone is interested. I will find out pricing based on # of manifolds being done.
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
belize1334
1334/2000
Galant VR-4 org Post #: 844551 posted 10/28/09 02:13 PM     Remind Me!  Send Private Message   Edit Post
I'm still intrigued by the idea of running Cyclone runners w/ a SMIM plenum. Since the butterfly valves are built into the 3rd section of the manifold (that bolts to the head) you could just disassemble it at that point and then build a SM plenum with normal runners that then bolts to the cyclone runners right before the head. You could then have velocity stacks and all that jazz in the plenum and still make use of the butterfly actuated secondaries.
Roger B. Scott
'91 Belize Green
1qkfwd
1868/2000
Galant VR-4 org Post #: 844553 posted 10/28/09 02:17 PM     Remind Me!  Send Private Message   Edit Post
If they do it see if it will be manifold specific or if they will do a mix of 1g, 2g, evo3, or cyclone. I will send in my evo3 if that's the case
Ralli380Gvr4
380/1000
Galant VR-4 org Post #: 844555 posted 10/28/09 02:33 PM     Remind Me!  Send Private Message   Edit Post
I would have to see a price first, might be interested.
-E
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 844565 posted 10/28/09 03:06 PM     Remind Me!  Send Private Message   Edit Post
Trust me, I'm in the same boat. $250 would be the highest I think I would go. I have seen SMIM, like magnus for about that price range, used on epay..... Who knows, he may not respond to the discount. I'll update when I hear back.
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Edited by 381gvr4 (10/28/09 03:08 PM)
715/1000
1284/2000
Galant VR-4 org Post #: 844568 posted 10/28/09 03:17 PM     Remind Me!  Send Private Message   Edit Post
That Hawyer manifold is huge! Nice gains though. massive increase in power all over the place.
12yr+ Vr4 owner.
Family Guy
Ralli380Gvr4
380/1000
Galant VR-4 org Post #: 844573 posted 10/28/09 03:27 PM     Remind Me!  Send Private Message   Edit Post
Yeah and they offer a lifetime warranty
Quoting 381gvr4:
Cool man, let me know what you find out.
-E
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 844585 posted 10/28/09 04:25 PM     Remind Me!  Send Private Message   Edit Post
Quoting 381gvr4:
NO GO ON GROUP BUY! $440 IT IS FOR EXTRUDE HONE...... Anyone else know of local shops that do extrude honing??? FFWD is not the ONLY ones. EH has been used by hotroders for decades!!!
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Edited by 381gvr4 (10/28/09 04:32 PM)
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 844594 posted 10/28/09 04:52 PM     Remind Me!  Send Private Message   Edit Post
Quoting belize1334:
Ditto.
Another option (if you can find one) would be an AMG galant manifold, same runners/cyclone but the plenum is approx 33% larger.
JDM E39A - 0010362 VR-4 Project 燃えないゴミ(Unburnable Junk) - stolen
JDM E39A - 0020096 VR-4 Daily - sold
Posts: 752 | From: Wgtn, NZ | Member Since: 06/09/07 | IP: (121.73.146.65) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 844601 posted 10/28/09 05:12 PM     Remind Me!  Send Private Message   Edit Post
^^ Curious... I'll keep my eye out.
Roger B. Scott
'91 Belize Green
Pages: 1 | 2
1 registered and 13 anonymous users are browsing this forum.
Generated in 0.286 seconds in which 0.223 seconds were spent on a total of 15 queries. Turbo powered.
