Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » [email protected] 21psi.
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 841066 posted 10/17/09 12:20 AM     Remind Me!  Send Private Message   Edit Post
Just when I post in a thread that my car does not miss it starts missing bad . Before I went to the track I changed the plugs and had them gaped to 27. Did a few pulls on the way to the track and all was good.
Now once I got to the track and made my first pass its was missing like crazy . Thinking it was rich miss, I turned up the boost from 20 to 22 . No go on that, car was missing really bad still. So I pull the plugs and check the gap. WTF 3 of them were at 30+ and 1 was at 27. So I knock them all down to 25, thinking it should clean every thing up. Nope it was still missing but not as bad. I ended up running a [email protected] on that pass. So on the next pass, I think maybe I will try turning down the boost and see if that will help. Nope same shit but still ended up running a [email protected] on 21psi.
I am thinking that the cold was really fucking with the car but also liking it(mph). It was in the mid 50s tonight and today when I was doing some pulls it was in the upper 60s. I think tonight was the coldest temps I have ever ran the car in. Most of the time its in the upper 70s to low 80s. Maybe e85 in cold weather just needs a much smaller gap. Say around 22.
Oh well I had fun and the car is still running at the end up the year. Time to put it away for its winter hibernation.
1992 Gaylant vr4 #439/1000
11.1at131 562awhp/484awtq
E85 FP3052 parted out
05 EB EVO SSL 11.48at124mph
450awhp/400awtq New 2.3 e85 hks 7460r
05 JEEP liberty CRD DD/ski slut
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (166.129.104.175) | Report this post to a Moderator
Redmaster89
Galant VR-4 org Post #: 841072 posted 10/17/09 12:48 AM     Remind Me!  Send Private Message   Edit Post
I saw that run! Looked like it ran pretty well, all things considered.
-Colton-
| | | IP: (24.22.107.2) | Report this post to a Moderator
thecman02
too lazy to look
580/1000
Galant VR-4 org Post #: 841074 posted 10/17/09 01:39 AM     Remind Me!  Send Private Message   Edit Post
Awww winter hibernation. That's no fun, but atleast she can be put away with her wheels on. No JSB for you haha. I wonder why you were breaking up so bad. I hadn't had any problems with e85 on a colder day such as30 degrees, except when the engine isn't up to full temp. Its dumb to beat on her when she isn't warm anyways but yeah. I'm curious why it was breaking up. I guess its just bad luck that you'd talk about stock ignition being the cats pajamas and then get effed. In theory maybe with it being colder the gas didn't atomize enough giving bad combustion.
580/1000
2013 Max Effort Winner
-Chris
Posts: 911 | From: Kalamazoo,MI | Member Since: 11/03/07 | IP: (69.128.217.6) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 841076 posted 10/17/09 01:41 AM     Remind Me!  Send Private Message   Edit Post
No ignition issues with COP huh? You should have knocked on wood.
-Mark
1051
Posts: 11884 | From: Yakima, WA | Member Since: 04/29/01 | IP: (97.90.49.2) | Report this post to a Moderator
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 841133 posted 10/17/09 12:44 PM     Remind Me!  Send Private Message   Edit Post
Don't know what the deal was. It was doing fine before I went to the track. I did some 30+psi pulls and it never missed once. Then when I get to the track about and make my first run(about 2HR later)its missing. It also could be that because it was a lot cooler the car was just making a far amount more power. I should have just dropped my plug gap down to 20-22 but I did not want to pull them out again. So I just said fuck it and called it a night.
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (166.187.136.223) | Report this post to a Moderator
1qkfwd
1868/2000
Galant VR-4 org Post #: 841254 posted 10/18/09 12:31 AM     Remind Me!  Send Private Message   Edit Post
What was your timing like? If it's to far retarded it will miss to. It sounds almost like spark blow out but more consistant. It will also widen your gap some.
92 eclipse FWD [email protected]
92 Talon AWD Best et [email protected] 1.39 60'
2011 GTX series here we come!
#1868/2000 Looking for 10s on pump
Posts: 209 | From: Sun Valley, NV | Member Since: 09/29/09 | IP: (166.205.130.173) | Report this post to a Moderator
Mark
Trying To Sell Out
Galant VR-4 org Post #: 841257 posted 10/18/09 12:53 AM     Remind Me!  Send Private Message   Edit Post
brian you should buy my 850R =)
Posts: 2515 | From: Naperville, IL | Member Since: 10/11/05 | IP: (67.184.86.21) | Report this post to a Moderator
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 841361 posted 10/18/09 02:29 PM     Remind Me!  Send Private Message   Edit Post
Well after knocking my plug gaps down to .021 it fixed the problem. The nice denser charge was just to much for the .025 gap. This just goes to show how stupid you become when you don't take your car to the track that much and just drive it in nice warm weather.
Oh on a plus note my little 3052 is now holding 35psi up to 6800rpms and falling down to 32psi and holding in this cold weather. It maybe time to put it back on the dyno and see what it can do at 32psi with the cooler air.
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (32.177.50.94) | Report this post to a Moderator
rlturbo35
461/2000
Galant VR-4 org Post #: 841571 posted 10/19/09 07:11 AM     Remind Me!  Send Private Message   Edit Post
i used my spark plug gap at .015 , it works for any misfires and my ignition systems is stock, just tried , i have been as high as 860 hp and 9.97 in the quarter no misfire problems at all , Later Rolo from www.tunedbycft.com .
Life's Short Drag Race Hard!!!!!
www.cftshop.com
Posts: 44 | From: Orlando,Florida | Member Since: 08/21/09 | IP: (76.26.179.16) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 841632 posted 10/19/09 11:06 AM     Remind Me!  Send Private Message   Edit Post
Hibernation
Sucks about the last time at the track for the year not going as planned. Any plans for changes over winter or are you keeping the setup the same?
GVR4 #418/2000: [email protected] - pump/alky -
GVR4 #431/1000: [email protected]+
GVR4 #139/1000: T3T4: [email protected] - 14B: [email protected] (sold)
www.PerformancePartout.com
Posts: 2054 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (76.6.50.229) | Report this post to a Moderator
Kenny_Kline
belligerent idiot
1370/2000
Galant VR-4 org Post #: 841633 posted 10/19/09 11:11 AM     Remind Me!  Send Private Message   Edit Post
Quoting turbowop:
Why is it that everytime I see your name, its you being negaitve? Do you ever have anything positive to say or usefull information?
Posts: 789 | From: Seekonk, MA | Member Since: 12/27/07 | IP: (71.192.95.42) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 841637 posted 10/19/09 11:14 AM     Remind Me!  Send Private Message   Edit Post
I believe Mark was being sarcastic...
-Jeff
1881/2000
50/1000
Posts: 7870 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 841679 posted 10/19/09 01:25 PM     Remind Me!  Send Private Message   Edit Post
Quoting Kenny_Kline:
Quoting turbowop:
Hey moron. Brian and I are friends. Even in real life, not just the internet, OMG. My reply was in response to him talking about never having any ignition breakup with his COP setup in a thread just a couple days before he had these issues. I guess you wouldn't understand, Mr. Serious.
-Mark
1051
Jonvr4
Galant VR-4 org Post #: 841751 posted 10/19/09 05:49 PM     Remind Me!  Send Private Message   Edit Post
Careful Mark, he may try and put you in an e-submission hold with his e-mma leet skills. He is "nationally ranked"....
| | | IP: (216.160.138.184) | Report this post to a Moderator
CarRacer
Giant Sack of Ginger
83/2000
Galant VR-4 org Post #: 841763 posted 10/19/09 05:57 PM     Remind Me!  Send Private Message   Edit Post
James
83/2000
Missed Shift | Auto News
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (75.73.133.56) | Report this post to a Moderator
thecman02
too lazy to look
580/1000
Galant VR-4 org Post #: 841772 posted 10/19/09 06:10 PM     Remind Me!  Send Private Message   Edit Post
On a serious note the .15 gapping thing is interesting. I may try it. Usually the gap widens with use, but I'm worried the gap would do something stupid like close on me haha.
580/1000
-Chris
Kenny_Kline
belligerent idiot
1370/2000
Galant VR-4 org Post #: 841888 posted 10/19/09 09:02 PM     Remind Me!  Send Private Message   Edit Post
Quoting turbowop:
Quoting turbowop:
Hey moron. Did you ever sit back and look at yourself? Not only do you do it to people you dont know but you do it to your friends. Its an all the time thing with you. Everytime I see the name turbowop, its something sarcastic, rude, or just plain childish. Congrats on you being a tool both online in person. I hope you feel like you accomplish alot. I can already tell that your just some schmoe probably still living at home with mommy/daddy, single (not even a household pet), and your life REVOLVES around whats on the internet. SAD!
Kenny @ Dynotech Tuning
[email protected]
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 841892 posted 10/19/09 09:08 PM     Remind Me!  Send Private Message   Edit Post
And the e-thug award goes to...
If you ask the right questions Mark has a wealth of knowledge that he will gladly share. After *years* of being a resident of this board, his patience for stupidity is low. You are fighting a battle you can never win. You should seriously just give up.
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (71.83.253.110) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 841895 posted 10/19/09 09:20 PM     Remind Me!  Send Private Message   Edit Post
Lighten up Kenny. Jeez!
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.62.73) | Report this post to a Moderator
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 841900 posted 10/19/09 09:26 PM     Remind Me!  Send Private Message   Edit Post
Well I may take it to the track one more time. I have tell Oct 30th as that is the last night the track is open. But being the PNW the rain is here so we will see.
I would have liked to run the QTP but just never got the time to get them back from my friend. Oh well there is always next year.
Hey Mark your a big ass hole. Shame on you for giving me shit. Just for that I am going to push you off a cliff this winter. That will teach you to be a ass to your friends
200hp/385tq
Edited by Brianawd (10/19/09 09:28 PM)
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (32.177.118.190) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 841926 posted 10/19/09 10:02 PM     Remind Me!  Send Private Message   Edit Post
OMG serious business
I don't think you realize just how bad you fail in everything you said in that rant. Not only am I one of the most helpful people on this board, I also post all kinds of shit about my life not related to cars, including buying my house, my dogs, skiing, etc. All you can do is claim some 4th place title in the nation at driving in a video game? Better than your fail at cars, I guess. When are you going to do your reverse leakdown test?
-Mark
1051
Edited by turbowop (10/19/09 10:06 PM)
Jonvr4
Galant VR-4 org Post #: 841933 posted 10/19/09 10:09 PM     Remind Me!  Send Private Message   Edit Post
/\ flawless victory
| | | IP: (71.212.187.65) | Report this post to a Moderator
4doorDSM
Galant VR-4 org Post #: 841936 posted 10/19/09 10:12 PM     Remind Me!  Send Private Message   Edit Post
wats this kenny guys problem waht a crybaby
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 841943 posted 10/19/09 10:22 PM     Remind Me!  Send Private Message   Edit Post
blah blah blah
That pretty much what your joke of an existence has become on this board.
Quit being such a whiny bitch about everything. First you cry that people should only make fun of others they "know", then when Wop makes fun of someone he actually knows you still get butt hurt about it.
Michael
The rebuild of 1101
Posts: 4084 | From: Scottsdale, AZ | Member Since: 04/20/06 | IP: (72.208.240.174) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 841944 posted 10/19/09 10:22 PM     Remind Me!  Send Private Message   Edit Post
I would love to see Kenny and drunk Mark face to face some time.
That would be some great entertainment.
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (71.38.148.144) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 17 anonymous users are browsing this forum.
Generated in 0.281 seconds in which 0.214 seconds were spent on a total of 15 queries. Turbo powered.
