Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » 4G63 vs 4B11 what are the difference?
ihatefall
Galant VR-4 org Post #: 808712 posted 07/07/09 04:18 PM     Remind Me!  Send Private Message   Edit Post
I have been trying to google this up but it usually just leads to some forum with members being like "4G63 for life FTW" or "they switch for a reason 4B11, rub one out" or arguement about the 4G63 having proven it's self and it's too early to tell if the 4B11 is going to be the beast that the 4G63 was.
Well that is all good but I can come to that own. I want to know the differences!
Now as we have see, Mitsubishi upgrades don't always mean 'Better' (cough cough 7 bolt cough cough)
So what I want to know is what are the REAL differences?
I know the 4B11 isn't cast iron like the 4g63 is.
What else is different?
| | | IP: (76.118.116.224) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 808715 posted 07/07/09 04:32 PM     Remind Me!  Send Private Message   Edit Post
Not sure if this is the appropriate place for this discussion, but there's an entire
wiki article. So from that, there's a timing chain (yay) and the head on the new cars uses a bucket/shim design instead of lifters.
-Jeff
1881/2000
50/1000
Posts: 7870 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
14bCrazy
turdpolisher
Galant VR-4 org Post #: 808720 posted 07/07/09 04:46 PM     Remind Me!  Send Private Message   Edit Post
It has a open deck block like a Honda motor. Which means it will have to be sleeved to do really big boost.
1240/2000 - Sold
2004 Honda Pilot"It has VTEC!!!" Gave it back.
2005 WRX Wagon - Deer Hunter Edition--RIP
2003 Suzuki Katana 600
2000 Passat wagon crap car
Posts: 5707 | From: Virginia | Member Since: 03/25/03 | IP: (71.171.80.119) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 808729 posted 07/07/09 05:15 PM     Remind Me!  Send Private Message   Edit Post
From what I have read, the 4b11 turbo blocks have extra webbing and can hold quite a bit of boost.
I know for a fact that it can hold over 20psi. A Honda block can't do that (for very long anyway).
1992 Galant VR4 click
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (173.27.93.117) | Report this post to a Moderator
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 808766 posted 07/07/09 08:19 PM     Remind Me!  Send Private Message   Edit Post
Hmm, 4B12 crank in 4B11 block??
JDM E39A - 0010362 VR-4 Project 燃えないゴミ(Unburnable Junk) - stolen
JDM E39A - 0020096 VR-4 Daily - sold
Posts: 752 | From: Wgtn, NZ | Member Since: 06/09/07 | IP: (121.73.146.65) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 808769 posted 07/07/09 08:26 PM     Remind Me!  Send Private Message   Edit Post
Quoting ihatefall:
Way more differences than similarities. Most have already been mentioned short of the turbo swap which means head casting is 180 different.
The now defunct Turbo magazine ran some great articles over two months on the deltas.
AMS has done tons of work with the 4B11, maybe Mark will chime in later.
Mike O.
#464/1000 - Sold
05 Legacy GT - 6MT swap
#86/2000 - Sold ( again )
Edited by ktmrider (07/07/09 08:26 PM)
Posts: 3103 | From: Portland, OR | Member Since: 09/10/07 | IP: (69.254.142.49) | Report this post to a Moderator
Dialcaliper
Flagration Member
1269/2000
Galant VR-4 org Post #: 808776 posted 07/07/09 08:57 PM     Remind Me!  Send Private Message   Edit Post
The 4B11 is basically a completely different engine. The deck is "semi-closed" which means it still has some deck reinforcement, not like a completely open honda block where the sleeves are self-supporting. Everything has been revised to what *should* be better in terms of reliability, performance and emissions. Timing chain, solid lifters, bigger intake valves, MIVEC on both cams, etc. The only performance downgrade is smaller exhaust valves, which were used mainly to meet emissions restrictions.
Also, the block *is* sleeved with plain grey cast iron from the factory, so it's decently robust without resorting to custom ductile iron sleeves. A recent article about an HKS Evo X (latest issue of Modified Mag) has some HKS folks quoted as saying they think the stock 4B11 block is good for close to 500hp without modification, but that the stock internals are the weak point - mainly because the internals are even lighter than the 4G63 - partly since the engine and valvetrain are rated by Mitsubishi for a rev limit of 8000 rpm.
This kind of makes sense in the context of the WRC environment it was designed for (300hp with a restrictor, with about 500 ft-lbs of torque). Forged internals are allowed, but modification of the block is not (except for normal oversizing).
1269/2000 Summit White
Edited by Dialcaliper (07/07/09 08:58 PM)
Posts: 1284 | From: Mountain View, CA | Member Since: 06/22/07 | IP: (158.184.37.55) | Report this post to a Moderator
Zenith
Galant VR-4 org Post #: 808978 posted 07/08/09 01:30 PM     Remind Me!  Send Private Message   Edit Post
I do remember AMS fielding a white EVO X GSR in last years USCC, and I think it made about 475 whp on the dyno tests.
I have those issues of Turbo in my girlfriend's car, and can recall that there are no balance shafts, and that they use bushings in the cam journals, but cant remember if it's on all the journals or just on the pulley side.
Edited by Zenith (07/08/09 01:33 PM)
| | | IP: (68.201.66.163) | Report this post to a Moderator
ihatefall
Galant VR-4 org Post #: 809079 posted 07/08/09 06:19 PM     Remind Me!  Send Private Message   Edit Post
the timing chain is great but... an aluminum one? I ride bikes alot and aluminum/ carbon = catastrophic failure whereas as steel starts to break you can feel it.
Wizardawd
598/1000
Galant VR-4 org Post #: 809171 posted 07/08/09 10:46 PM     Remind Me!  Send Private Message   Edit Post
Don't forget that chains stretch a lot over time as well, ask anyone that has done an old V8 timing chain. So while it may not break, the performance of your motor will degrade to the point of straight up being sluggish.
Also, the downsides of chains, they are usually a bit tougher to change out, a lot more expensive, and have a high failure rate from the tentioners. Nissan, Dodge and others were known for the oil-pressure fed tentioner failing and causing the chain to skip.
I'm still interested in the 4B11 future, it has a lot to live up to and thus far has impressed. Will it be able to take the abuse that the 4G63 can handle? Time will tell. But, having Dodge, Hyundai and Mitsu cars powered by the same motor means a metric buttload of parts available which is an incredibly intelligent move imo.
Wiz
598/1000 Nile Black
12/2000 Nile Black
1995 Montero SR
1997 Talon Tsi AWD Auto
Posts: 1315 | From: Aberdeen, SD | Member Since: 08/08/07 | IP: (24.220.220.162) | Report this post to a Moderator
G
obsessed with the turds of others
486/1000
Galant VR-4 org Post #: 809338 posted 07/09/09 12:38 PM     Remind Me!  Send Private Message   Edit Post
I thought the evo x was no longer a rally car? Just a bloated evo/ galant now?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8815 | From: zompton | Member Since: 02/24/04 | IP: (66.11.222.178) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 809380 posted 07/09/09 03:22 PM     Remind Me!  Send Private Message   Edit Post
Tanner Foust seems to be doing well in Rally America with his Evo.
-Mark
1051
Posts: 11864 | From: Yakima, WA | Member Since: 04/29/01 | IP: (97.90.49.2) | Report this post to a Moderator
Dialcaliper
Flagration Member
1269/2000
Galant VR-4 org Post #: 809416 posted 07/09/09 05:45 PM     Remind Me!  Send Private Message   Edit Post
I believe they said almost the same thing when the Evo VII was released based on the new Cedia chassis, after they stopped making Evo VI to Group A specs. That was probably a bigger change to the character of the car, even though the engine did not change as drastically.
The Evo X is still built to be competitive in Group N rally, and more importantly, even though the WRC cars use a completely unique chassis, they still have to use an engine based on the production car.
Even companies like Ford who built AWD WRC cars that did not return any technology to cars available to the public are still using what is a heavily modified version of a 2.0L Duratec engine (granted, with an added turbocharger), with basically the same crank, block and lubrication system found on street cars (That's about all that's left even when comparing WRC and Group N Evos)
It's kind of a moot point now since Mitsubishi and many others have dropped out of WRC, but they and Subaru are still strongly in support of production based Group N rally.
Quoting G:
Edited by Dialcaliper (07/09/09 05:46 PM)
"Just to be pedantic!"
Galant VR-4 org Post #: 809519 posted 07/10/09 01:23 AM     Remind Me!  Send Private Message   Edit Post
The 4B1x series was heavily based apon the Hyundai Theta II engines, which is the engine powering the new Hyundai Genesis 2.0 Turbo coupe. The main difference is the cylinder head design, and the Hyundai engine uses a different rod and piston combo, and the Hyundai engine is only 2 bolt mains while the Mitsubishi 4B11 is four bolt mains.
Here's a technical video of the 4B11 - click
bottom end a 4B11, showing four bolt mains (with ARP main studs fitted):
and the Hyundai Theta II engine bottom end in comparison:
Posts: 2064 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (118.90.4.56) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 809598 posted 07/10/09 12:06 PM     Remind Me!  Send Private Message   Edit Post
4b11t.org Mitsubishi Lancer Ralliart 4b11
Ryan Hertz
Edited by Hertz (03/26/10 07:54 PM)
Posts: 13492 | From: Chicago, IL | Member Since: 07/29/02 | IP: (69.209.93.194) | Report this post to a Moderator
RTSGVR-4
Galant VR-4 org Post #: 810449 posted 07/13/09 01:15 PM     Remind Me!  Send Private Message   Edit Post
Quoting Dialcaliper:
.... That was probably a bigger change to the character of the car, even though the engine did not change as drastically.
You are mostly right, but the engine from the 6 to the 7 had hardly any changes at all, just a bit better internal oiling. Its basically the same 4G63 from the evo 4-9, with the 4 having one less main bearing than the 5+, and the 9 getting mivec.
Also, ford does have a turbo Focus, but it is just fwd as you stated.
Edited by RTSGVR-4 (07/13/09 01:16 PM)
| | | IP: (24.9.123.218) | Report this post to a Moderator
Rock Star Status
Galant VR-4 org Post #: 810450 posted 07/13/09 01:18 PM     Remind Me!  Send Private Message   Edit Post
Quoting Hertz:
4b11t.org
Excellent site!
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (63.253.227.122) | Report this post to a Moderator
1990ggsxnj
Member ++
1578/2000
Galant VR-4 org Post #: 810475 posted 07/13/09 02:30 PM     Remind Me!  Send Private Message   Edit Post
A bike chain will have more load than a timing chain. Load variance is very minimal in a timing chain as well.
Quoting ihatefall:
"Is that Spool Drool? EWW!"
90GGSX Blue-Chesapeake
91GVR4 Nile Black-Sidney (Sid)
Posts: 525 | From: Blackwood, NJ | Member Since: 11/21/08 | IP: (12.175.119.20) | Report this post to a Moderator
ihatefall
Galant VR-4 org Post #: 810536 posted 07/13/09 05:19 PM     Remind Me!  Send Private Message   Edit Post
"A bike chain will have more load than a timing chain. Load variance is very minimal in a timing chain as well.
Quoting ihatefall:
the timing chain is great but... an aluminum one? I ride bikes alot and aluminum/ carbon = catastrophic failure whereas as steel starts to break you can feel it."
I wasn't comparing the chain, actually most bike chains are steel and zinc/nickel coated. I just have broken frames before and its always like WHOA! One time it ended with me in the hospital with a cracked skull and blood in my brain. Aluminum can form minor stress fractures that are too noticeable and then BAMN! snap
Bimmubishi
giant log
Galant VR-4 org Post #: 810602 posted 07/13/09 08:35 PM     Remind Me!  Send Private Message   Edit Post
This is the most in depth discussion of the differences to date. This is from Tomei.
-Alex
www.dentsport.com
Posts: 5698 | From: Boston, Massachusetts | Member Since: 07/15/03 | IP: (65.96.129.171) | Report this post to a Moderator
77/2000
Galant VR-4 org Post #: 810749 posted 07/14/09 11:30 AM     Remind Me!  Send Private Message   Edit Post
Oh hai, you're a Tomei dealer.
Ryan Hertz
ihatefall
Galant VR-4 org Post #: 811196 posted 07/15/09 05:08 PM     Remind Me!  Send Private Message   Edit Post
it is in depth and answers all my questions!
3rdstrikedsm
Now mandatory for Wendy's Chili to come with cheese
Galant VR-4 org Post #: 842023 posted 10/20/09 01:02 AM     Remind Me!  Send Private Message   Edit Post
I believe there was an evo x over on evo m that made 670ish whp on an internally stock engine so I believe the 4b11 is going to be quite worthy. Since when has Mitsu downgraded?
1994 supra 6spd 612whp and more to come soon!
1995.5 Audi s6 Vi-pec powered!
Posts: 3402 | From: 32159, FL | Member Since: 02/18/08 | IP: (98.220.250.101) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 842025 posted 10/20/09 01:10 AM     Remind Me!  Send Private Message   Edit Post
Here is what I have found after driving my RA for 6 months.
Mitsu has really tightened up the ECU programming so that you can't mod anything without reflashing.
The MIVEC head is noisy. When the motor is at full operating temp, the valve train rattles. (the dealer say they all do it which I call BS but I don't have anything to compare to).
Other than that, I would bet that the 4G and the 4B stock turbo blocks w/stock internals will handle about the same power.
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (173.27.92.201) | Report this post to a Moderator
3rdstrikedsm
Galant VR-4 org Post #: 842027 posted 10/20/09 01:22 AM     Remind Me!  Send Private Message   Edit Post
Well combine the puck style shim over bucket lifter with crappy mitsu castings and I would say for sure the head will be noisy for sure but nothing that could be fixed with 8-12 hours of lifter reshiming
Edited by 3rdstrikedsm (10/20/09 01:23 AM)
Pages: 1 | 2
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.272 seconds in which 0.207 seconds were spent on a total of 15 queries. Turbo powered.
