Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » 139/1000 Rebuild
139/1000 Rebuild
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 786728 posted 04/30/09 08:08 PM     Remind Me!  Send Private Message   Edit Post
I picked up #139/1000 this last weekend. The car was previously Turbotommy's car from NJ, then it went to Maryland for some lawn ornament time.
The body is really really nice, two single dings (rear pass door and under the pass tail light) and only a couple scratches. Interior is very very nice, but is currently full of parts. Bought the car as a rolling chassis, needing an engine/trans, fuel parts, ecu, and all engine accessories. 86k miles on the chassis.
My plan is to swap all the parts I need from the GVR4 Im currently driving, 931/2000 once I get it cleaned up. 931 is a mechanically sound car, but the body is pretty rough. 931 is getting a 60-1 turbo, tube header, new o2 housing, and aluminum ic pipes next weekend, so those parts will go into 139 when I swap the drivetrain later.
This weekend Im planning to organize parts, start reassembly of the interior, then get started on brakes/suspension assembly. Hope to have the chassis ready for a motor in a couple weeks.
Goal for this car is a solid 11 second pumpgas car and super clean exterior/interior.
So anyway, for a first post, here's some pics as it sits. I don't think the car has been washed since it was parted out in like 2007.
It's pretty empty under the hood. Unfortunately, the wiring has been taken apart. so I'm going through it for sure before goes in. Might remove the harness and paint the engine bay while it's empty.
Way to mangle a perfect hood to glue in vents. Looks to have been cut with a sawzall. Guess that's something else needed, another hood.
I got a nice uncut white front bumper and white roof strips, so those need to be painted.
GVR4 #418/2000: [email protected] - pump/alky -
GVR4 #431/1000: [email protected]+
GVR4 #139/1000: T3T4: [email protected] - 14B: [email protected] (sold)
www.PerformancePartout.com
Posts: 2052 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (76.6.40.155) | Report this post to a Moderator
Andy_S
Overcomplicated
Galant VR-4 org Post #: 786744 posted 04/30/09 08:46 PM     Remind Me!  Send Private Message   Edit Post
Eww at that hood. Looks like a nice clean car though. Your goals sound very familiar to my own.
BTW, I just noticed your numbers are 931 and 139. Thats quite a coincidence.
I found v8's...
Edited by Aspod (04/30/09 08:47 PM)
Posts: 982 | From: Shithole Wisconsin | Member Since: 01/30/07 | IP: (209.225.102.231) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 787461 posted 05/02/09 10:28 PM     Remind Me!  Send Private Message   Edit Post
I got #139 into the garage today and up on the lift to check out the situation. Emptied the interior of misc parts and started organizing. The interior is pretty much together other than rear seats, radio, and ecu. Undercarriage has a bit more rusty stuff than #931, mostly on the subframes and suspension members. Steering rack is leaking bad and looks beat.
So my plan now is to swap even more out of 931 Thinking of removing the complete engine/trans/xcase and all of the front subframes, steering rack, control arms, hubs, axles in one big monster unit. Most of those parts are in better or non rusty condition on 931.
  • disconnect the engine wiring, radiator & heater hoses, shifter cables, clutch slave, side engine mounts, steering shaft, strut tops, wheels, brake lines all from the top.
  • lower the car on the lift until the subframes are on a rolling dolly.
  • unbolt the subframes from the unibody
  • lift the unibody up.
  • roll the whole front end away.
  • swap cars on the lift and set the new car down onto the complete front end assembly and bolt it up
Tentativly Im thinking of doing the drivetrain swap around the weekend of May 23. I think I can get everything out of 931 and have 139 atleast rolling in one weekend. The the next week I should be able to button it up and have the car running.
Anyway, here's some pics from tonight:
General undercarriage pics. Rust is really not too bad.
Unfortunatly, Tomas cut off the stock fuel feed line, so Im forced to do AN feed line.
clear silicone covered SS brake lines. Never seen this before.
Q: How much do I trust welded suspension that was done by the person who hacked that hood
Wow. Clear plastic lens.
Headliner is absolutely mint. I'm floored by this as the one in 931 is all stained and groddy.
Dash in in great shape, no bubbling by the vents. I haven't found any cracks or imperfections yet.
Trunk and rear seat area has been gone over with some sort of undercoating that is hard and sandpaper like. It looks decent and clean.
The guy I bought the car from did a good job with the trunk mounted battery and running the cables, but I think Im going to remove it and use the lawnmower size battery mounted to the steering rack subframe. (lighter and no NHRA issues with the cutoff)
Edited by NateCrisman (05/02/09 10:38 PM)
G
obsessed with the turds of others
486/1000
Galant VR-4 org Post #: 787797 posted 05/03/09 10:35 PM     Remind Me!  Send Private Message   Edit Post
Nice save, looks like a nice project. I like the way the 1gb wheels look.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8811 | From: zompton | Member Since: 02/24/04 | IP: (208.43.6.211) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 787801 posted 05/03/09 10:47 PM     Remind Me!  Send Private Message   Edit Post
heh, you know, they wouldn't be so bad if there were 4 of them. the drivers front wheel is a 1gA swirly that's reverse of the other 3. I'm going to use the aftermarket 16x7 wheels that are currently on 931.
Adorsey
Member +
1942/2000
Galant VR-4 org Post #: 787876 posted 05/04/09 08:17 AM     Remind Me!  Send Private Message   Edit Post
looks like it'll be a fun one.
lol on the hood cut out.
1942/2000 DD
[email protected]
93oct b16g
Posts: 355 | From: mass | Member Since: 04/22/09 | IP: (69.16.64.66) | Report this post to a Moderator
Romanova
the coolest person to ever post in the past 2 hours
Galant VR-4 org Post #: 788022 posted 05/04/09 04:03 PM     Remind Me!  Send Private Message   Edit Post
Wow, that looks really good!
tyler
oh-eight crown victoria
oh-five xb
oh-four excursion
Posts: 3840 | From: Cypress, TX | Member Since: 08/07/02 | IP: (98.199.14.23) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 788525 posted 05/05/09 07:57 PM     Remind Me!  Send Private Message   Edit Post
So today's progress:
After I gutted the engine bay. Removed the engine wiring harness, throttle and shifter cables, clutch master, brake master, brake booster, detached most of the chassis wiring harness, wiper motor, and bunch of misc other crap.
That got me to here:
Then a generous soaking of simple green, a box of brillo dish pads, and a long ass time of bending over:
So, while it came out pretty clean, I still need to sand some rust in a few spots. Majorly under the oem battery spot, that's going to need some wire wheel work. wonder if I can get close enough to a match of the stock green or just go black engine bay?
That kinda sucks. The sending unit and the -8 feed line are hacked up. Stock fuel line is gone.
Edited by NateCrisman (05/05/09 08:02 PM)
BoostedAWD91
815/2000
Galant VR-4 org Post #: 788527 posted 05/05/09 08:00 PM     Remind Me!  Send Private Message   Edit Post
looks good so far nate, glad to see u building a galant instead of parting it out
#815/2000- Lexus Pearl White
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (159.240.11.254) | Report this post to a Moderator
NYC86ZC
30-Something
541/1000
Galant VR-4 org Post #: 788537 posted 05/05/09 08:40 PM     Remind Me!  Send Private Message   Edit Post
Very nice progress in a short period of time. Man, i wish i had a lift.
-92 Grey #541
-05 WRX
Posts: 1001 | From: Long Island, NY | Member Since: 12/05/05 | IP: (98.116.175.74) | Report this post to a Moderator
mean_green
Member +
1632/2000
Galant VR-4 org Post #: 788551 posted 05/05/09 09:02 PM     Remind Me!  Send Private Message   Edit Post
Nice Work,
-Alan
1632/2000
Posts: 310 | From: Park City, MT 59063 | Member Since: 11/12/07 | IP: (24.72.223.108) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 788719 posted 05/06/09 10:25 AM     Remind Me!  Send Private Message   Edit Post
Quoting BoostedAWD91:
I think sometimes that you guys really misunderstand me. I really like these cars, granted, Im not anywhere near the delusional state that some people here are in, but yeah, these cars are super fun. I got into 931 last fall with intentions of restoring the body and modding the drivetrain to suit. Ends up that the far easier route was to buy a better body rather than repair/paint 931. Pretty much "everything" from 931 is going into 139.
Unfortunatly that means 931/2000 becomes a parts car in 3 weeks. When I'm done with it I may offer it up for free if someone wants to try and save it, but it will likely be no more than a bare unibody with dented panels and "should" become a steel pancake.
But one really nice GVR4 will come out of it all, much nicer than the one it replaced, so the breed is improved.
I'm hoping that 931 will get one last hurah on May 20th, to go to the dragstrip with the t3t4 setup, improved pipes, and better setup. Maybe it can crack of an 11 and 120mph before it becomes an organ doner the following day.
BoostedAWD91
815/2000
Galant VR-4 org Post #: 788853 posted 05/06/09 05:09 PM     Remind Me!  Send Private Message   Edit Post
yeah i understand what ur doing, i just meant its nice to see u building a car from the bottom up
Edited by BoostedAWD91 (05/13/09 07:50 PM)
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 788869 posted 05/06/09 05:35 PM     Remind Me!  Send Private Message   Edit Post
Is that AN line your fuel feed?
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15454 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (173.20.47.24) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 788889 posted 05/06/09 07:02 PM     Remind Me!  Send Private Message   Edit Post
That is a fuel feed that Tommy put in. Its a 1/2" aluminum line with #8 AN lines on it.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.62.73) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 788954 posted 05/06/09 09:48 PM     Remind Me!  Send Private Message   Edit Post
Quoting blacksheep:
That line is going to get removed, Im going to put a stock feed line in. Personally I have no use for monster fuel lines, the stock line will do fine for the power Im planning to make.
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 791943 posted 05/13/09 07:06 PM     Remind Me!  Send Private Message   Edit Post
So here's the paint results:
The seam of the paint on the fender attachment area. The line goes right down the 90* corner. That spot seemed like the least noticable place and it was easy to tape. really, the best option would have been to take the fenders off, but this isn't too bad.
The subframes are still groddy and rusty, Im going to swap those with #931 next weekend with the entire drivetrain, engine wiring harness, fuel system, brakes, suspension, and all 931's modifications.
Edited by NateCrisman (05/13/09 07:10 PM)
BoostedAWD91
815/2000
Galant VR-4 org Post #: 791957 posted 05/13/09 07:47 PM     Remind Me!  Send Private Message   Edit Post
looks alot better nate!!! Did u paint that yourself?
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (159.240.11.109) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 791968 posted 05/13/09 08:00 PM     Remind Me!  Send Private Message   Edit Post
yeah. degreased and washed it one day. This monday I scuffed the engine bay with 180 grit sandpaper after wire wheeling the rusty sections down to decent metal. Had to sand some rust spots by hand and that took a while. Then another wash & rinse with simple green. Sat for an afternoon to try. Quick mask with tape and newpaper to cover the fenders and windshield. Three cans of Dupli-color 500* engine block paint in Semi-Gloss Black. It came out decent although I really wish I had been able to find a close enough green to look correct. Oh well, black is fine too.
Tomorrow Im going to start putting the engine bay back together, wiring harness zip tied back in, brake master, clutch master, that kinda stuff.
Also gotta sand and paint the cowl cover, wiper blades, hood hinges & latch. Have a ton of things to clean/sand/paint and get ready for the big swap on 23rd.
Adorsey
Member +
1942/2000
Galant VR-4 org Post #: 792955 posted 05/16/09 03:19 PM     Remind Me!  Send Private Message   Edit Post
this looks awsome man. i hope everything goes well. GL.
1942/2000 DD
[email protected]
93oct b16g
Posts: 355 | From: mass | Member Since: 04/22/09 | IP: (76.119.241.16) | Report this post to a Moderator
HHIVR4
Aluminum Lung
1280/2000
138/2000
Galant VR-4 org Post #: 793128 posted 05/17/09 01:39 PM     Remind Me!  Send Private Message   Edit Post
Nice..138 was green too..
Posts: 5446 | From: Hilton Head Island SC | Member Since: 10/06/03 | IP: (67.216.144.225) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 793217 posted 05/17/09 08:24 PM     Remind Me!  Send Private Message   Edit Post
Got some work done on the turbo system changed and the fmic setup fixed yesterday pulling an all-day/all-nighter with my buddy Brent from JMFabrications.
Installed:
  • T3 tube header & Tial MVS external wg.
  • Turbonetics 60-1 stage 5 turbo
  • Brent fabbed up a stainless o2 housing
  • modified my existing fmic core: flipped the inlet end tank and welded on a 2.5" cast elbow.
  • custom 2.5" polished aluminum upper and lower ic pipes
  • knockoff tial bov.
Edited by NateCrisman (05/17/09 08:29 PM)
Woody
164/2000
Galant VR-4 org Post #: 793400 posted 05/18/09 10:51 AM     Remind Me!  Send Private Message   Edit Post
Nice, when your planning on going back to the track?
Posts: 88 | From: Plainfield, NJ | Member Since: 02/09/09 | IP: (96.242.250.195) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 793407 posted 05/18/09 11:03 AM     Remind Me!  Send Private Message   Edit Post
Planning to run #931 at Island on wednesday as a "last hurah", hopefully something in the 11's and 120mph.
I was planning to start removing everything from #931 this coming weekend to put into #139.
Sorry if it's confusing, but Im sorta working on two parallel projects at the same time:
Chassis & paint on #139
Engine/tuning mods on #931.
Very soon the two projects will come together and become just one car.
Edited by NateCrisman (05/18/09 11:28 AM)
Assmilk Pearl
Galant VR-4 org Post #: 793411 posted 05/18/09 11:25 AM     Remind Me!  Send Private Message   Edit Post
Looking good. When you gonna do that to mine?
-mitsuturbo
Posts: 18891 | From: Flemington, NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4 | 5 | 6
2 registered and 93 anonymous users are browsing this forum.
Rating: ***
Generated in 0.257 seconds in which 0.197 seconds were spent on a total of 15 queries. Turbo powered.
