Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Installing springs and struts, the rears are kicking my a**
TurboTrader
Galant VR-4 org Post #: 761837 posted 02/21/09 10:50 PM     Remind Me!  Send Private Message   Edit Post
I'm installing mild drop springs and KYB GR2 Struts on number 145, and these rears are just giving me a ton of headache. For having done this before on the Eclipse, I can't believe I'm having so much trouble.
The rear pass. side I got done in an hour or so, and the shock wasn't too much to get off, but the drivers side is the real trouble. I just can't get the damn thing off the lower control arm. Probably because these things have been on here since 1991, considering they are original springs/struts.
So, I'm wondering, if anyone that has done this before, what did you do to get it off?
I'm just all out of ideas, so...
Posts: 161 | From: Pemberton, NJ | Member Since: 01/30/09 | IP: (97.96.170.242) | Report this post to a Moderator
CarRacer
Giant Sack of Ginger
83/2000
Galant VR-4 org Post #: 761839 posted 02/21/09 11:00 PM     Remind Me!  Send Private Message   Edit Post
If you have access to an air hammer, it worked really well on my car. Just buzz it a little at the 3,6,9, and 12 parts of a clock.
I tried the torch method, and the air hammer worked ten times better. The torch just destroyed the bushing and made a horrid smell. You could hardly tell the air hammer touched the other shock.
James
83/2000
Missed Shift | Auto News
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (75.73.133.56) | Report this post to a Moderator
Ian M
waiting for the bus
487/2000
Galant VR-4 org Post #: 761852 posted 02/21/09 11:59 PM     Remind Me!  Send Private Message   Edit Post
If it's really rusted on,you can take a cut off wheel or a Dremel,and cut a slot or two in the metal around the lower bushing,then pry it apart. Pull out the strut. Cut off the rubber,then carefully do the same (not to cut too deep and cut into the stud) with the inner sleeve.
#487/2000 Summit White
Edited by Ian M (02/22/09 12:03 AM)
Posts: 2342 | From: Martinsburg,WV | Member Since: 01/11/02 | IP: (69.140.24.65) | Report this post to a Moderator
bazeng
work in progress
Galant VR-4 org Post #: 761865 posted 02/22/09 01:19 AM     Remind Me!  Send Private Message   Edit Post
I used a slide hammer on mine with some chains.
Australia's Slowest VR4
Posts: 2520 | From: Melbourne, Australia | Member Since: 02/06/03 | IP: (58.109.190.215) | Report this post to a Moderator
BluFalcon
Fantastic Parts Seller
Galant VR-4 org Post #: 761882 posted 02/22/09 02:37 AM     Remind Me!  Send Private Message   Edit Post
I used a big honking prybar, and some Kroil to try and free it up. Find a good spot and try and pry it off the perch. I ended up tearing the rubber insert, and cutting off the metal sleeve when it was all said and done. Sounds like Ian M's method of cutting the bottom of the strut bushing and peeling it apart is going to be the easiest and quickest way to get it done.
Ed
93 Eagle Talon TSi/AWD
92 Dodge Stealth R/T TT
06 Mitsubishi Raider V8 DuroCross
521/1000
"SOLD"
Edited by BluFalcon (02/22/09 02:38 AM)
Posts: 1307 | From: Wichita, KS | Member Since: 01/20/02 | IP: (173.57.97.83) | Report this post to a Moderator
TMG
Galant VR-4 org Post #: 761906 posted 02/22/09 08:17 AM     Remind Me!  Send Private Message   Edit Post
I sprayed it with something like a W40 for a few days (soak it real good) and use a puller. It took me a few days to get it off this way.
Posts: 131 | From: NJ | Member Since: 10/01/07 | IP: (67.85.16.97) | Report this post to a Moderator
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.215 seconds in which 0.2 seconds were spent on a total of 14 queries. Turbo powered.
