Exhaust Question again I know I know
Brunoboy
San Bruno,CA Home of SFO
Hey guys, I know this has been covered MANY times before, ok well I know a 1g dsm dp works on our cars because they are all the same, I know that the 1g AWD Cat backs are shorter in length than the galant, so If i were to buy a 1g DSM cat back could I just extend it by cutting the pipe and adding pipe??? Thanks
-Shane
Dialcaliper
Mountain View, CA
Unless you already have a 1G downpipe, the most common "pretty good fit" seems to be combining a 2G downpipe and a 1G catback. If you have neither, you can get VR-4 specific full exhausts from someone like Garfield.
If you already have the 1G downpipe, you could bolt in an extension before or after the cat (kind of like a race pipe with the right flanges)
Brunoboy
Thats what I was thinking, of getting a 2g dp, and then a high flow cat and the 1g dsm awd catback, will it all fit though is my question? Because my friends brother has many parts for the awd dsm's and would sell me these for cheap. So I would rather spend 400 on an exhaust system than 800 on one. you know?
yeah im pretty curious too. i always see 2g downpipes going for less. i thought about using a 2g dp and making the rest.
EMX5636
Bucks County, PA
i Have a 2G awd downpipe on my Galant. They are Cat-eliminator (longer than a 1G) and fit about perfect. Here's an underside pic. I made the rest from the DP back.
Lonewolf64
Birmingham, Alabama
It fits great. Buy a 3inch 2g Megan Racing downpipe and it fits like a charm. Downpipe and back needs to be fabbed up after that.
Brunoboy
So what I ask is that will a 1g DP be ok bolted with a High Flow cat, and then with a 1g AWD Cat Back that has been Extended so its longer. is that ok? because For all that its still cheaper than a Exhaust system for our cars. Right now I have a Custom FULL WELDED straight pipe so No flanges, and I want flanges.
-Shane
ktmrider
Tempe, AZ
The 2g DP flange clocking at the cat matches the GVR4 better/exactly ( you would need to cut the 1g TEL flange off and re-weld it at a different angle ). This is why everyone is saying go with a 2g DP for more Plug and Play.
Cat-wise use a CMPE high flow model made specific for the GVR4 ( again due to the front flange clocking ) or a test pipe for the GVR4 ( bad in Cali or IMO on any DD street car ).
Then you can use a 1g TEL cat-back system and extend it slightly near the cat to make up for the longer GVR4 body.
Or the easy, and more expensive route, get with Garfield Wright. I found an older model CMP 2.5" exhaust with cat that bolted up in 20 minutes. Hardest part was going to the store for some gaskets and hardware...
Brunoboy
thats the exact info I wanted ^^^ thanks for that.
-Shane
