Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Which Trans Shep, Tre, Jacks ? Im tired of breaking my Trans
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 721280 posted 11/11/08 04:52 PM     Remind Me!  Send Private Message   Edit Post
I know I know the same question everyone asks which company makes the best trans? I bought my parts from Shep last year when I broke my shift fork and also replaced my 3-4 shift sleeve. I was very happy with his products his service and his prompt shipping. Also he was the only one that called me back the day I called. As far as this time I tore the teeth off my third gear. I was in third gear under power and then there was nothing I am getting sick of these crappy transmissions so.....
Basically I want to buy a trans that is capable of holding power. I do not like to do things twice so I am thinking of going with a Shep stage four with EVO III first gear Electro polishing (REM ISF) all the gears and a 4 spider center diff. When I talked to Shep he suggested not going with a Quaife center diff because it wont hold up too daily commutes which I do.
Now Tre seems to do a lot more things like I can get every thing cryogenic treated and Electro polishing (REM) a Speed Design 4 spider center diff and a double syncro 5th gear also he has a shot peening process he does.
A couple of things I noticed wail I've been looking at peoples builds and web sites it seems that Tre cuts down the gear to add a extra syncro now since I have already shredded my gears wont this increase the chance of doing that again? I mean less gear area mean weaker gears correct? Now as far as center diff's what are the diffrence's in 4 spider diff to a Speed Design's 4 spider diff? Is all of this really needed too make it stronger? Would I be better going with a Quaife ATB helical limited slip front and center differential?
This is kind of a daily car / weekend warrior I like to drive it aggressive but I want it to last and be able to commute I do take it on 1200 mile trips. Any opinions and recommendations feed back or anything I am open too so please share and discuss
Lack of boost
Posts: 1076 | From: NY | Member Since: 06/03/07 | IP: (205.188.116.6) | Report this post to a Moderator
14bCrazy
turdpolisher
Galant VR-4 org Post #: 721305 posted 11/11/08 05:10 PM     Remind Me!  Send Private Message   Edit Post
My advice would be to buy a 96 Civic 4 door. I have a TRE one but don't have enough miles to give you a good opinion but I won it so I aint going to complain.
1240/2000 - Sold
2004 Honda Pilot"It has VTEC!!!" Gave it back.
2005 WRX Wagon - Deer Hunter Edition--RIP
2003 Suzuki Katana 600
2000 Passat wagon crap car
Posts: 5707 | From: Virginia | Member Since: 03/25/03 | IP: (66.16.241.220) | Report this post to a Moderator
Spott
The Deer Hitman
Galant VR-4 org Post #: 721314 posted 11/11/08 05:26 PM     Remind Me!  Send Private Message   Edit Post
I had a used TRE build tranny in mine. It worked well, I never had any problems.
91 sold #657/2000
-Mike
Ever notice how when you get behind the wheel of a car,
you are the only person in the world that is not a complete moron?
So what do I do with these other two doors?
Posts: 1529 | From: Las Vegas | Member Since: 01/05/04 | IP: (68.224.229.35) | Report this post to a Moderator
4Grim
I deliver.
1948/2000
Galant VR-4 org Post #: 721338 posted 11/11/08 05:50 PM     Remind Me!  Send Private Message   Edit Post
I have a fully built TRE tranny with all the bells and whistles. Its held up like a champ and haven't had one single issue with the it.
91 GVR4 1948/2000
96 Galant 5sp DOHC 4G64T
2002 Montero Limited
1998 Montero SR (Winter package w/ adjustable suspension)
Edited by 4Grim (11/11/08 05:51 PM)
Posts: 2454 | From: Orlando FL | Member Since: 09/30/04 | IP: (72.186.66.105) | Report this post to a Moderator
Dialcaliper
Flagration Member
1269/2000
Galant VR-4 org Post #: 721342 posted 11/11/08 05:54 PM     Remind Me!  Send Private Message   Edit Post
TRE, Shep, Jacks - all have reputations for reliable work apart from the usual freak incidents that happen from abuse or defective parts
Personally, I plan to send mine to Jack when I'm ready, mostly based on the fact that he's helpful and explicitly states everything he will do to the box. He was also very friendly and helpful answering questions by email.
Shep, while he has a good reputation and good customer service, tends to assume you don't know anything and won't spend the time to answer technical questions, or explain why exactly you do, or do not need a particular thing.
TRE I don't have much interaction with, but I'm not attracted to their fondness for front diff inserts and welded diffs. Probably just my personal preference, and more focus on drag specific setups.
1269/2000 Summit White
Edited by Dialcaliper (11/11/08 06:10 PM)
Posts: 1284 | From: Mountain View, CA | Member Since: 06/22/07 | IP: (158.184.37.55) | Report this post to a Moderator
GVR-4
Creative Name Huh?
77/1000
Galant VR-4 org Post #: 721350 posted 11/11/08 05:57 PM     Remind Me!  Send Private Message   Edit Post
How well the tranny holds up depends on how much torque you are producing and if you load the gears up suddenly or not. You should email jackstransmissions.com after you have checked out his site. A lot of FAQ's are answered on his website. Try to figure out what you want from that info and then ask him if you can't decide what you want from the info he provides on the website.
Dave Peter
Can't polish a turd.
Posts: 2597 | From: Asheville, NC USA | Member Since: 04/22/02 | IP: (152.18.67.40) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 721391 posted 11/11/08 06:25 PM     Remind Me!  Send Private Message   Edit Post
On the topic of processes to treat your tranny with. Anyone have any non-anecdotal evidence that cryo treating really helps gear strength?
EDIT: K. I think I found some articles by ASM. Hope that answers my question.
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Edited by BarnesMobile (11/11/08 06:34 PM)
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (71.37.142.66) | Report this post to a Moderator
gaylantvr4
Joe
Galant VR-4 org Post #: 721427 posted 11/11/08 07:13 PM     Remind Me!  Send Private Message   Edit Post
i have a built tre transmission and so far it has treated me good.
998/1000
Posts: 850 | From: Omaha ,NE | Member Since: 10/03/04 | IP: (72.213.32.229) | Report this post to a Moderator
Dialcaliper
Flagration Member
1269/2000
Galant VR-4 org Post #: 721429 posted 11/11/08 07:34 PM     Remind Me!  Send Private Message   Edit Post
The phenomenon you're looking for is "Cryogenic Martensitic Transformations" if that helps you research or look for white papers. It is mostly observed in steel, and a few other exotic alloys (like shape memory metals). It more related to phase transformations like melting, freezing and other solid-solid phase transformations like tempering of steel. Think of boiling liquid nitrogen for example. Since it is not a diffusion or chemical process like most hardening processes, the rate doesn't halve every 10 degrees or so, which is why it still progresses at cryogenic temperatures.
Cryo treating of steels, exotic alloys and some ceramics by this mechanism has been researched and the physics behind it is fairly sound, with modest improvements in strength, and better resistance to wear and fatigue similar to the same transformation occurring at higher temperatures. The evidence appeared before the question when parts launched into space were returned to earth, after seeing severe temperature extremes, showed unexpected mechanical behavior.
As far as cryo treating of aluminum, brass, plastics, and other common materials goes, no properly controlled experiments have been able to show noticable improvement that stands out from the noise, and noone has put forth a good theory that is reproducible.
The general consensus is that cryo treating improves fatigue life and surface wear properties, which in turn prevents or slows the formation of fatigue cracks, which is how most transmission failures actually occur. The gear and gear teeth, barring defects, are plenty strong to carry the load, but once you load cycle them hundreds of thousands, or millions of times (every revolution of the shaft), cracks can eventually form which concentrate stress and eventually fail.
I'd hazard a guess that if you could actually apply enough torque to tear the tooth off a new, perfect gear, the output shaft or one of the diffs would rip itself clear out of the aluminum case first.
Cryo your steel parts if it makes you happy.
ISF surface treatment works similarly to shot-peening. It hardens the surface of the material by "cold working", and smooths out sharp corners and machining marks that concentrate stress and become initiation sites for cracks.
If you wanted a no-expense spared transmission, cryo-treat, then shot-peen, followed by ISF, then send them to Microblue for tungsten disulfide dry film for good measure. But that would be overkill and a waste of money in almost every case.
Edited by Dialcaliper (11/11/08 07:43 PM)
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 721446 posted 11/11/08 07:49 PM     Remind Me!  Send Private Message   Edit Post
^ very good info
Thanks for responding too all and I still have a 91 crx so no need for 96 civic 4dr hehe
Lack of boost
Sean92AWD
372/1000
Galant VR-4 org Post #: 721661 posted 11/12/08 10:51 AM     Remind Me!  Send Private Message   Edit Post
Hey i sent you a pm man. Let me know if your interested.
1992 Kensington Grey 372/1000 Needs paint!!!
2007 Tundra 5.7L ToyTec Lifted
Posts: 247 | From: Newington, CT | Member Since: 12/17/07 | IP: (72.221.93.185) | Report this post to a Moderator
LunarShadow
Galant VR-4 org Post #: 721732 posted 11/12/08 01:15 PM     Remind Me!  Send Private Message   Edit Post
Quoting onesickcrx:
I wouldn't call holding up to twice stock power "crappy".
Isn't heat a major contributor?
| | | IP: (130.218.10.1) | Report this post to a Moderator
14bCrazy
turdpolisher
Galant VR-4 org Post #: 721742 posted 11/12/08 01:42 PM     Remind Me!  Send Private Message   Edit Post
Quoting onesickcrx:
^ very good info
I'll give you a good deal on it. How about $4000.
1240/2000 - Sold
Flip4G63
Den Mother
1439/2000
Galant VR-4 org Post #: 721957 posted 11/12/08 08:05 PM     Remind Me!  Send Private Message   Edit Post
dogbox.. stop bitching and buy it.
91 GVR4 1439/2000 White
Posts: 1154 | From: Abilene Tx | Member Since: 08/28/07 | IP: (74.197.80.60) | Report this post to a Moderator
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 722162 posted 11/13/08 07:38 AM     Remind Me!  Send Private Message   Edit Post
A asked about a dog box and the reply was something along the line of race car not used for daily driver use
Listen I understand its asking alot for our trans to hold alot of power but I want too know who and which trans to go for. If in deed I do need to go with a dog box I will eather A buy one or B turn my car down permently which is not what I want to do but I will if need be.
Lack of boost
Posts: 1076 | From: NY | Member Since: 06/03/07 | IP: (64.12.116.6) | Report this post to a Moderator
Flip4G63
Den Mother
1439/2000
Galant VR-4 org Post #: 722250 posted 11/13/08 10:39 AM     Remind Me!  Send Private Message   Edit Post
what kinda power are you making??
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 722321 posted 11/13/08 12:21 PM     Remind Me!  Send Private Message   Edit Post
I am not sure what kinda power exactly yet. I just want to know about peoples feed back on the transmissions they have bought or driven on or heard of
Lack of boost
eviLntt
eVIL_DNB
938/1000
Galant VR-4 org Post #: 722350 posted 11/13/08 01:51 PM     Remind Me!  Send Private Message   Edit Post
The dogbox transmissions are pretty noisy from what I have heard. I have about 1500 miles on a road race transmission from jacks and it is doing great. The engine in my galant is completely stock and I can tell the trasnsmission wants to keep reving (I shut it down around 5000 rpms). Nice shifts and strong pulls, I recomend one. Plus Jacks is great with customer service and turned around my core charge early because I was trying to get more parts to finish the instal.
Posts: 1025 | From: Santa Rosa, CA | Member Since: 04/03/06 | IP: (71.6.101.129) | Report this post to a Moderator
Lonewolf64
Obviously the answer is......
889/1000
1247/2000
Galant VR-4 org Post #: 722424 posted 11/13/08 04:46 PM     Remind Me!  Send Private Message   Edit Post
I run a TRE "stage 2" transmission on my vr4. My car is a full bolt on 16g setup with cams powerwise. The tranny is as smooth as butter and there are no signs of issues at this power level.
1992 Galant VR-4 #889
1991 Galant VR-4 #1247
2007 Civic Si DD
Posts: 1195 | From: Birmingham, Alabama | Member Since: 05/18/06 | IP: (141.166.156.35) | Report this post to a Moderator
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 722467 posted 11/13/08 06:16 PM     Remind Me!  Send Private Message   Edit Post
thanks for all the feed back guys and pmed info as well keep it comming
Lack of boost
Yao
Galant VR-4 org Post #: 722606 posted 11/13/08 11:33 PM     Remind Me!  Send Private Message   Edit Post
I've TRE and Jack's on both my eclipse and galant. Neither has problems after 1 year, If anything, I think Jack's shifts a little bit smoother.
Posts: 810 | From: Denver, CO | Member Since: 03/06/01 | IP: (67.176.110.81) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 722666 posted 11/14/08 07:34 AM     Remind Me!  Send Private Message   Edit Post
Don't forget that TRE has supported us in the past with Trannies for raffle during the '3 Speed GT' meet in PA .
| | | IP: (75.74.8.7) | Report this post to a Moderator
deez
Nutz
Galant VR-4 org Post #: 722717 posted 11/14/08 10:11 AM     Remind Me!  Send Private Message   Edit Post
I have a Jack's trans with the evo3 first gear and so far its fine. I have about 7k on it with no issues. One thing I was bummed about was the shifting feels the same as stock, not smoother like I would have hoped and still very notchy, but I guess thats just these transmissions. It does shift into gear and any rpm very well, a huge improvement over stock.
#802/1000 Daily Driver SOLD!
1960 Austin Healey Bugeye
Posts: 1150 | From: Chico, CA | Member Since: 05/29/04 | IP: (71.148.52.71) | Report this post to a Moderator
GVR4_1057
Member ++
1057/2000
1604/2000
Galant VR-4 org Post #: 722720 posted 11/14/08 10:16 AM     Remind Me!  Send Private Message   Edit Post
This is a good thing to consider if anyone is debating as to which tranny to purchase. It seems as if all 3 shops make a great transmission. I like to support shops that give back to us.
Quoting Garfield Wright:
Billy B,
1057 Back after 5 years JSB
1604 all fixed again.
1986 Audi 4KQ
1997 BMW E36 328I
Posts: 676 | From: Brucetown VA | Member Since: 09/03/08 | IP: (12.171.68.176) | Report this post to a Moderator
thecman02
too lazy to look
580/1000
Galant VR-4 org Post #: 722945 posted 11/14/08 06:29 PM     Remind Me!  Send Private Message   Edit Post
I had my trans built by TRE this summer. I live 10 minutes away so I always stop in and bounce questions off him when I need good advice. The guy is a maniac, in a good way. He knows his shit. My transmission is flawless. I got a hybrid build between two and three. I also got my gears shot-peened for good measure. Just tell him what your goals are and he'll be honest with you.
580/1000
2013 Max Effort Winner
-Chris
Posts: 911 | From: Kalamazoo,MI | Member Since: 11/03/07 | IP: (69.221.240.191) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.247 seconds in which 0.188 seconds were spent on a total of 15 queries. Turbo powered.
