Galant VR-4 Forums » Galant VR-4 » Newbies » engine oil dipstick pops!
chrisb33
Member +
Galant VR-4 org Post #: 679967 posted 08/10/08 02:43 PM     Remind Me!  Send Private Message   Edit Post
Hi,
This is the first time it happened to me, i was driving at around 40-60% throttle, .8 bar of boost, 5k rpm, the all of a sudden some oil squirted out of my hood vents on to my windshield.
When i got home, i saw some oil splatter all over the engine bay and found out that the source of the oil splatter is because the oil dipstick poped out a bit (around 1/4 out).
My question is, what may have caused this, second, how can i tighten that dipstick on so that it wont pop out again.
thanks.
chris b
No worries
Posts: 363 | From: Manila, Philippines | Member Since: 05/03/07 | IP: (122.53.197.177) | Report this post to a Moderator
4orced4door Galant VR4.org Moderator
Out Standing
Galant VR-4 org Post #: 679973 posted 08/10/08 03:18 PM     Remind Me!  Send Private Message   Edit Post
Take a pair of pliers and crimp the tube a bit so that the dipstick is locked in a little tighter. It's common for the rubber stopper on the dipstick to get worn out and let it pop out.
'17 GTI Sport, '02 V70
96/1000, 229/1000, 1788/2000... a long time ago
Posts: 9843 | From: Raleigh, NC | Member Since: 07/19/02 | IP: (68.101.90.8) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 679981 posted 08/10/08 04:26 PM     Remind Me!  Send Private Message   Edit Post
crimp it or buy a new dipstick
#815/2000- Lexus Pearl White
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (72.79.177.94) | Report this post to a Moderator
OSiRiS
Galant VR-4 org Post #: 679984 posted 08/10/08 04:29 PM     Remind Me!  Send Private Message   Edit Post
It's popping out due to excess crank case pressure, the engine is getting tired. Crimping the end of the tube or getting a new stick is only masking the problem.
Help it breath by doing a catch tank breather setup like this:
Obviously doesn't have to be too drastic, but you get the idea.
Edited by OSiRiS (08/10/08 04:30 PM)
| | | IP: (203.109.144.196) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 679997 posted 08/10/08 05:05 PM     Remind Me!  Send Private Message   Edit Post
thats not always the problem. i have a catch can setup on my car as well and at full boost a few weeks ago i popped the dip stick out
stealthtt24
Holy deer monkey donkey balls looking for a pole
Galant VR-4 org Post #: 680002 posted 08/10/08 05:30 PM     Remind Me!  Send Private Message   Edit Post
Quoting OSiRiS:
Mine did the same thing, dipstick popping out, till I had a setup EXACTLY seen in this picture. Get a catch can with two inlets and a filter, and it will fix it! It only pops out a little bit instead of all the way. Also, replace dipstick with a 2g one and you should be good to go.
91 GVR4s 1332, 1635, 1507, all sold
Posts: 2746 | From: Orlando, FL | Member Since: 05/25/05 | IP: (67.8.57.55) | Report this post to a Moderator
brisvr4
Oceania Distict Enforcer for the Galant VR4 Mafia
Galant VR-4 org Post #: 680037 posted 08/10/08 07:07 PM     Remind Me!  Send Private Message   Edit Post
From Vfaq.
Dipstick popping out - happens due to crankcase pressure pushing the dipstick up:
* A good running motor will blow out a dip stick with a shriveled hard rubber seal
* A dead motor (lots of blow by, busted pistons) will blow out a good dipstick
* A 1/2 dead motor will blow out a 1/2 dead dip stick
Depending on the actual cause and the severity, the fixes can be:
* A spring/wire to hold the dipstick down
* Pinch the tube at the top a bit
* Get a new dipstick
* A full engine rebuild or new pistons
Tim
1992 Auspec
11.37 @ 131.46 - E85 goodness and stock block!
Official Australian home of the Ugh decal!
Posts: 946 | From: brisbane australia | Member Since: 02/13/04 | IP: (60.231.137.243) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 680054 posted 08/10/08 08:03 PM     Remind Me!  Send Private Message   Edit Post
Quoting OSiRiS:
Maybe the rubber seal on the dipstick is getting tired?
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.59.65) | Report this post to a Moderator
RedTwo
Rangi Kiwi
Galant VR-4 org Post #: 680130 posted 08/10/08 11:15 PM     Remind Me!  Send Private Message   Edit Post
I wrapped some cloth tape (duct tape, electrical tape, masking tape, etc.) around the rubber bit and it worked a treat.
Problem with crimping the dip stick pipe when you've got old, hard rubber is it will eventually break if you keep forcing it into a tight hole.
Posts: 1917 | From: New Zealand | Member Since: 07/16/08 | IP: (210.54.239.228) | Report this post to a Moderator
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 680131 posted 08/10/08 11:16 PM     Remind Me!  Send Private Message   Edit Post
The PCV valve, when working, 1) uses intake vacuum to help relieve crankcase pressure, and 2) stops positive (boost) pressure from moving from the intake to the crankcase.
OP, you should change your PCV, it can only help. Use OEM only! $10 part.
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (67.175.247.182) | Report this post to a Moderator
chrisb33
Member +
Galant VR-4 org Post #: 680143 posted 08/10/08 11:39 PM     Remind Me!  Send Private Message   Edit Post
Thanks guys for the suggestions. i learned a lot from it!
will try to replace the dipstick and get a catch can then will know what happens. thanks guys!
chris b
No worries
chrisb33
Member +
Galant VR-4 org Post #: 680192 posted 08/11/08 03:29 AM     Remind Me!  Send Private Message   Edit Post
How do you do those fittings on the oil breather outlet on the cylinder head?
chris b
Quoting stealthtt24:
Quoting OSiRiS:
No worries
Posts: 363 | From: Manila, Philippines | Member Since: 05/03/07 | IP: (124.104.76.26) | Report this post to a Moderator
Mark
Trying To Sell Out
Galant VR-4 org Post #: 680320 posted 08/11/08 02:00 PM     Remind Me!  Send Private Message   Edit Post
Crimping doesnt always work either.. I recommend putting a small hose clamp towards top and zip tieing the thing down.
Posts: 2515 | From: Naperville, IL | Member Since: 10/11/05 | IP: (74.7.44.169) | Report this post to a Moderator
chrisb33
Member +
Galant VR-4 org Post #: 680605 posted 08/12/08 08:30 AM     Remind Me!  Send Private Message   Edit Post
what about this two oil catch can set up i saw in the dsm forums? i read there that they prefer a filter-less system. dont know why.
i have a couple of questions about this set up:
1. im planning to DIY my own catch cans. is there any special materials that are inside a catch can? or is it just a plan can that stores oil? can someone show me an inside of a catch can?
2. on this set up, why do i have to connect one of the catch cans on the intake manifold, and the other on the intake pipe (please see diagram)?
Edited by chrisb33 (08/12/08 08:58 AM)
Posts: 363 | From: Manila, Philippines | Member Since: 05/03/07 | IP: (122.53.199.101) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 680795 posted 08/12/08 05:26 PM     Remind Me!  Send Private Message   Edit Post
Quoting chrisb33:
Thy wanted to run it pretty much the way it came from the factory. Probably for emissions reasons, or to prevent the smell of oil vapor, or possible to put a vaccume on the crankcase(which is a good thing to do, but the hp gains from doing this on a small displacement engine debatable).
-Ryan
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock
Posts: 2758 | From: Savannah, GA | Member Since: 08/30/05 | IP: (71.229.63.35) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 680797 posted 08/12/08 05:30 PM     Remind Me!  Send Private Message   Edit Post
^^ +1, without a vacuum source ( in reality a lower pressure area than the head ) the vapors don't evacuate as well.
Excellent write-up with dyno testing in this months Import Tuner mag showing that filters don't anything and can even cost power.
Mike O.
#464/1000 - Sold
05 Legacy GT - slush box
#86/2000 - Sold ( again )
Edited by ktmrider (08/12/08 05:31 PM)
Posts: 3114 | From: Portland, OR | Member Since: 09/10/07 | IP: (76.113.121.3) | Report this post to a Moderator
Dialcaliper
Flagration Member
1269/2000
Galant VR-4 org Post #: 680838 posted 08/12/08 06:32 PM     Remind Me!  Send Private Message   Edit Post
The "filterless" system is better because it pushes and pulls air from the intake, past the MAF sensor, and also routes to the intake manifold when it's under vacuum so it pulls fresh air in from the intake. The stock vacuum routing was actually designed pretty well from a performance standpoint, as well as from an emissions and economy standpoint. Double catch tanks and a check valve are the most optimum setup short of actually running a crankcase vacuum.
A breather catch can open to the air either doesn't replace with fresh air and doesn't pull a vacuum, or you're constantly pulling in unmetered air to the intake. Filter setups with no manifold/pcv connection also tend to spray oil vapor in the engine bay, which both gunks things up, and is also vaguely flammable if it ends up somewhere like on the exhaust manifold.
1269/2000 Summit White
Edited by Dialcaliper (08/12/08 06:36 PM)
Posts: 1284 | From: Mountain View, CA | Member Since: 06/22/07 | IP: (158.184.37.55) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 681109 posted 08/13/08 11:47 AM     Remind Me!  Send Private Message   Edit Post
On another note ( sorry for highjack ), my dipstick began popping out after turning the boost up at a 1/4 mile event last week. First time it ever came out.
I was on about 18-19psi and thought I had torched the clutch ( synthetic oil burning on the mani smells much the same as fried clutch ). Cleaned up the surface oil, no more runs, turned the boost down to the usual 15psi, and drove her home with no issues. Checked the intake tract the following day, no excess oil in the tube nor in the turbo lines. Kept an eye on things, no change.
Replaced my tired 14b with a small 16g on Monday. Put about 50 miles on it then ran her thru the gears at full boil. Hit 18psi ( no change to MBC from old turbo ) with a little taper to 16psi. Checked everything at home, dipstick was out about an inch or just past the rubber seals. Pulled the intake tube, again no oil from the head vent.
Gosh I drone on.
Anywho, could my BOV be leaking above 15psi and reverse pressurizing my head and crankcase?!? I am on the the stock 1g, uncrushed, and recirculating. I do have a JDM intake that uses the stock route and has the oval opening for the 2g MAS. The recirc tube points directly at the EVAP and head vent tubes.
Again did not want to start another thread but apologize if I step on some toes. Any thoughts are appreciated.
Mike O.
#464/1000 - Sold
chrisb33
Member +
Galant VR-4 org Post #: 681560 posted 08/14/08 07:01 AM     Remind Me!  Send Private Message   Edit Post
thanks to a guy in the dsm forum i am now in the process of making my dual custom catch can set up. much like the dual catch i posted above. I will post pics soon when it's installed wish me luck!
chris b
No worries
chrisb33
Member +
Galant VR-4 org Post #: 684613 posted 08/21/08 06:26 AM     Remind Me!  Send Private Message   Edit Post
ok im almost done with my dual catch can set up all i need to do now is to buy silicone hoses so that i can hook them up!
here are some pics to share with you guys. the catch can is made out of 3" stainless steel with a drain plug underneath. the big tank you will see with the radiator cap is also a custom made 6" stainless steel methanol tank that holds a gallon of meth. fittings are 3/8 NPT's
will post again when i get the hoses and everything is connected already.
chris b
No worries
Posts: 363 | From: Manila, Philippines | Member Since: 05/03/07 | IP: (122.53.197.3) | Report this post to a Moderator
JSchleim18
Minor 69er
1157/2000
Galant VR-4 org Post #: 790337 posted 05/10/09 05:29 PM     Remind Me!  Send Private Message   Edit Post
Quoting ktmrider:
Gosh I drone on.
Bumping the last part of this reply up because I have the same question. I have a brand new 1G dipstick, 2 catch can setup properly routed with a working PCV valve (OEM). I have a GReddy RS BOV and I heard that they can leak above 19 PSI. My car is at 20 PSI right now and my dipstick fully popped out. Could Mike's above question be true?
-Jeremy
A88 Summit White - CD (No Sunroof)
Posts: 4738 | From: Long Island, NY | Member Since: 10/16/06 | IP: (173.52.112.26) | Report this post to a Moderator
KevinDunaway
Galant VR-4 org Post #: 790473 posted 05/10/09 11:44 PM     Remind Me!  Send Private Message   Edit Post
I have zip ties holding mine in because it pops. I bought a PCV valve but still have this problem so im keeping it zip tied. Im thinking about ordering a new dipstick from JNZ, hope this fixes the problem.
| | | IP: (173.26.25.23) | Report this post to a Moderator
9t1tsi
Galant VR-4 org Post #: 790596 posted 05/11/09 10:01 AM     Remind Me!  Send Private Message   Edit Post
the dipstick is common on these cars. And just like stated above its too much crank case pressure.
My rebuilt motor with 1500 blew mine out at boost with dual catch cans non filtered.
Another member on here gave me some "heating and cooling duct tape" like whats used on air ducts! This shit is strong and held if great! Never poped out again....just the oil filer vibrated loose
| | | IP: (71.244.143.27) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 790677 posted 05/11/09 02:05 PM     Remind Me!  Send Private Message   Edit Post
Quoting JSchleim18:
Hey J, my problem ended up being the Framinator PCV valve.
Bought an OEM model, no dipstick problems since ( about 2000 miles so far ).
Mike O.
#464/1000 - Sold
Posts: 3114 | From: Portland, OR | Member Since: 09/10/07 | IP: (192.55.60.26) | Report this post to a Moderator
9t1tsi
Galant VR-4 org Post #: 790679 posted 05/11/09 02:11 PM     Remind Me!  Send Private Message   Edit Post
Quoting 9t1tsi:
This was also with a brand new oem pcv
Pages: 1 | 2
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.164 seconds in which 0.077 seconds were spent on a total of 15 queries. Turbo powered.
