Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Radiator setup
Radiator setup
4dgs6m3
Galant VR-4 org Post #: 598873 posted 02/01/08 09:36 PM     Remind Me!  Send Private Message   Edit Post
Alright the radiator went out today on the galant with a big crack in the plastic and i was just curious if i put a honda radiator and a pusher fan on would it be sufficient enough to keep her runing cool? im not sure if its too small to keep it cool so i thought i would just ask before I drop 400 on a new one.
Thanks.
| | | IP: (70.92.182.95) | Report this post to a Moderator
BadVr4
wanted a different answer
801/2000
Galant VR-4 org Post #: 598880 posted 02/01/08 09:45 PM     Remind Me!  Send Private Message   Edit Post
in this weather it probably wont. i have one on mine and it never over heated in 90* weather.
Posts: 678 | From: manchester, ct | Member Since: 12/30/04 | IP: (67.189.198.47) | Report this post to a Moderator
G
obsessed with the turds of others
486/1000
Galant VR-4 org Post #: 598893 posted 02/01/08 10:15 PM     Remind Me!  Send Private Message   Edit Post
I can get you a koyo replacement for $100 & change.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8811 | From: zompton | Member Since: 02/24/04 | IP: (72.135.196.218) | Report this post to a Moderator
4dgs6m3
Galant VR-4 org Post #: 598906 posted 02/01/08 11:00 PM     Remind Me!  Send Private Message   Edit Post
Never heard of them. any pics?
G
486/1000
Galant VR-4 org Post #: 598917 posted 02/01/08 11:47 PM     Remind Me!  Send Private Message   Edit Post
You've never heard of koyo?
www.nostalgic.co.jp
daenan
Galant VR-4 org Post #: 598940 posted 02/02/08 01:03 AM     Remind Me!  Send Private Message   Edit Post
I have a honda radiator and a permacool 14" fan. Not a problem at all so far.
| | | IP: (68.62.239.118) | Report this post to a Moderator
turbotwin77
Galant VR-4 org Post #: 598960 posted 02/02/08 02:01 AM     Remind Me!  Send Private Message   Edit Post
Planning to go with a two row aftermarket radiator for a civic to free some space for my setup i am going with this year.
| | | IP: (76.166.229.144) | Report this post to a Moderator
spartan
Rusty ++
1699/2000
Galant VR-4 org Post #: 598980 posted 02/02/08 07:16 AM     Remind Me!  Send Private Message   Edit Post
Is the koyo radiator that you speak of aluminum or just a stock replacement?
1699/2000 Nile Black- Rusted out... SOLD
DD- 2007 Subaru Legacy
Posts: 546 | From: Sheboygan, WI | Member Since: 12/20/05 | IP: (99.139.166.110) | Report this post to a Moderator
mr.mitsu
Member +++
Galant VR-4 org Post #: 599046 posted 02/02/08 12:34 PM     Remind Me!  Send Private Message   Edit Post
Just curious...OEM or aftermarket (aluminum)?
Posts: 797 | From: canada | Member Since: 04/28/03 | IP: (99.230.151.179) | Report this post to a Moderator
daenan
Galant VR-4 org Post #: 599047 posted 02/02/08 12:41 PM     Remind Me!  Send Private Message   Edit Post
It's the small aluminum one. Something along the lines of (or quite possibly exactly) the one linked.
I'm fairly certain all of the half-sized civic ones are the same. Not sure, I bought it from digit. He probably knows more about it.
Install wasn't bad. Had to make a bracket for the bottom of the radiator, then used the stock pass. side rubber mount and moved the top mount. Stock upper hose works fine, and I had to do a little fiddling with the lower hose. I'll snap a few pictures if you'd like.
4dgs6m3
Galant VR-4 org Post #: 599050 posted 02/02/08 12:47 PM     Remind Me!  Send Private Message   Edit Post
yes please post a pic.
daenan
Galant VR-4 org Post #: 599059 posted 02/02/08 01:09 PM     Remind Me!  Send Private Message   Edit Post
That fan will remove limbs.
Ralli380Gvr4
Bearded Snow Leopard
380/1000
Galant VR-4 org Post #: 599063 posted 02/02/08 01:16 PM     Remind Me!  Send Private Message   Edit Post
is this an aluminum replacement, if so sign me up!
-E
#380/1000 A72 Summit White E39A - Daily click
1993 Mustang GT - Resto Mod/Project Car
Posts: 587 | From: BOULDERADO/UWS-NYC/BURQUE | Member Since: 12/27/06 | IP: (216.84.60.26) | Report this post to a Moderator
4dgs6m3
Galant VR-4 org Post #: 599065 posted 02/02/08 01:20 PM     Remind Me!  Send Private Message   Edit Post
it is not a AL radiator. its a stock replacement.
G
486/1000
Galant VR-4 org Post #: 599068 posted 02/02/08 01:34 PM     Remind Me!  Send Private Message   Edit Post
It is a copper oe replacement.
www.nostalgic.co.jp
iLLeffeKt vr-4
Hertz pulverized mine
1759/2000
Galant VR-4 org Post #: 599107 posted 02/02/08 02:59 PM     Remind Me!  Send Private Message   Edit Post
I have a civic radiator too with a 14" Spal puller mounted on it. So far no problems/issues.
Here's the thread I made about it after I installed it click me
Adrian
1759/2000 Summit White Sold
1991 Eclipse GS-X Sold
2013 EVO X MR - Daily
Posts: 2153 | From: NYC | Member Since: 07/26/04 | IP: (74.64.97.204) | Report this post to a Moderator
digit
Galant VR-4 org Post #: 599111 posted 02/02/08 03:12 PM     Remind Me!  Send Private Message   Edit Post
That was the original thread that got me turned onto the civic radiators. A suggestion to anyone purchasing a fan for a civic radiator or even oem is to use perma cool over spal or slim line.
Edited by digit (02/02/08 03:15 PM)
| | | IP: (216.220.216.158) | Report this post to a Moderator
4dgs6m3
Galant VR-4 org Post #: 599117 posted 02/02/08 03:23 PM     Remind Me!  Send Private Message   Edit Post
whats the details behind that?
digit
Galant VR-4 org Post #: 599136 posted 02/02/08 03:58 PM     Remind Me!  Send Private Message   Edit Post
Using a perma-cool fan over a spal or slim line?
| | | IP: (70.121.121.147) | Report this post to a Moderator
tsiboy
has one ambihelical hexnut
810/1000
Galant VR-4 org Post #: 599137 posted 02/02/08 03:58 PM     Remind Me!  Send Private Message   Edit Post
you may also want to consider a vw scirocco radiator.
link
web page
-alex
810/1000 Nile black
damn it where did all my 12mm's go
Posts: 1137 | From: Los Angeles, Ca | Member Since: 01/26/05 | IP: (69.230.54.69) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 599351 posted 02/03/08 03:54 AM     Remind Me!  Send Private Message   Edit Post
I'm running a sicrocco unit and a passat fan. Its a two speed belt driven unit. one motor two fans. You can feel the air blowing off of it at the back of the car.
The fan motor from a corrado can be used and its not so long but just as fast. The radiators can be bought at jegs for $100.
Its never gave me a problem and cools fine.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11885 | From: Clarksville TN | Member Since: 05/04/03 | IP: (66.168.102.199) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 599352 posted 02/03/08 04:02 AM     Remind Me!  Send Private Message   Edit Post
50 and up here.
Also check for passat radiators and audi ones as well. I've seen passat complete units go for 200 or so on ebay not bad for a fan and radiator The passat ones are about 4 inches longer than the sicrocco. They still fit the galant but not with the 3 inch short route piping I wanted.
92 GVR4 0475/1000
Scientist
Secretary of the Interior
Galant VR-4 org Post #: 599389 posted 02/03/08 09:15 AM     Remind Me!  Send Private Message   Edit Post
Anyone ever tried using Honda Integra radiators?
1988 VR4....Needs a lot of TLC
Posts: 530 | From: Roseau/Dominica | Member Since: 01/18/07 | IP: (69.57.241.213) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 599399 posted 02/03/08 09:47 AM     Remind Me!  Send Private Message   Edit Post
Same thing as Civic right? If so then yes.
I love my crazy mother!!!
Posts: 1531 | From: Manchester, NH | Member Since: 07/17/06 | IP: (24.91.188.195) | Report this post to a Moderator
Scientist
Galant VR-4 org Post #: 599400 posted 02/03/08 09:49 AM     Remind Me!  Send Private Message   Edit Post
integra is full size...not half.
Pages: 1 | 2
Generated in 0.079 seconds in which 0.056 seconds were spent on a total of 15 queries. Turbo powered.
