Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Speedlimit problem
Previous thread Next thread
Speedlimit problem
Jorkki
Unregistered
Galant VR-4 org Post #: 469188 posted 04/25/07 01:21 AM     Remind Me!  Send Private Message   Edit Post
Hello, i have little problem with my car (galant vr4 -91) for the speedlimit sensor..
My car is "japanese version" so the topspeed is 180 km/h (limited) so my question is how to change or eliminate the sensor?
| | | IP: (194.137.66.74) | Report this post to a Moderator
zzz_vr4
Unregistered
Galant VR-4 org Post #: 469191 posted 04/25/07 01:58 AM     Remind Me!  Send Private Message   Edit Post
remove the instrument cluster and there's a wire behind the speedometer held in place with a screw. remove that and you'll have no speed limit
| | | IP: (60.50.173.76) | Report this post to a Moderator
brisvr4
Oceania Distict Enforcer for the Galant VR4 Mafia
Galant VR-4 org Post #: 469192 posted 04/25/07 02:10 AM     Remind Me!  Send Private Message   Edit Post
The following text passage is "borrowed" from Rob323 over in aus. (thanks Rob!)
Below is a photo of the back of the instrument cluster on a late model J spec. I'm pretty sure that if you remove the top screw circled in green, that you remove both the speed cut and the 105 kph chime but still pass the speed signal to the ecu. If you remove the bottom screw circled in green, you still get rid of the speed cut, but still have the chime and still pass the speed signal to the ecu. If you disconnect the grey wire, you disconnect EVERYTHING including the speed signal to the ecu.
Posts: 949 | From: brisbane australia | Member Since: 02/13/04 | IP: (58.108.98.131) | Report this post to a Moderator
zzz_vr4
Unregistered
Galant VR-4 org Post #: 469193 posted 04/25/07 02:19 AM     Remind Me!  Send Private Message   Edit Post
so is there a negative effect of not having a speed signal to the ECU? or does it make the ECU think the car isnt moving at all? i'm not using vr4 instrument cluster, so i guess i have none of intelligent features of the vr4 cluster :P
Jorkki
Unregistered
Galant VR-4 org Post #: 469203 posted 04/25/07 04:58 AM     Remind Me!  Send Private Message   Edit Post
Ok, so that doesn`t harms the ECU if i do that? I have Greddy E-manage support tool to modifying to the ECU and turbosmart bleed valve to controlling the bar/psi. So i need more speed be cause it`s cut the speed to 4th gear..
zzz_vr4
Unregistered
Galant VR-4 org Post #: 469204 posted 04/25/07 05:04 AM     Remind Me!  Send Private Message   Edit Post
no, it wont damage the ECU at all. but shouldn't e-manage be able to by pass the speed limiter?
Jorkki
Unregistered
Galant VR-4 org Post #: 469288 posted 04/25/07 09:14 AM     Remind Me!  Send Private Message   Edit Post
I don`t know, may be.. but that speed limit sensor can`t remove or tuning pass the e-manage, so is it possible to fix or change the value for ohms to some kind of potentiometer? I heard that for somewhere...
| | | IP: (91.152.12.90) | Report this post to a Moderator
curtis Galant VR4.org Moderator
Space Blanket from NASA plumbed into the attic
475/1000
Galant VR-4 org Post #: 469431 posted 04/25/07 12:35 PM     Remind Me!  Send Private Message   Edit Post
If one of you JDM members has the pin out on the harness it would be helpful...I have a JDM rs cluster I've been wanting to put in the usdm car.
I know over kill but it looks damn cool and has lights and stuff that I don't even know what there for. The cluster reads 220 and has the same revs/min as the us so thats the same and will work but the tach and speedo is mounted opposite and the wires are all differnet so they will have to be repinned.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Ass, Gas or Milkbones. Nobody rides for free" Jon AKA Toybreaker
Posts: 11891 | From: Clarksville TN | Member Since: 05/04/03 | IP: (24.183.205.195) | Report this post to a Moderator
Hertz Galant VR4.org Administrator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 469439 posted 04/25/07 12:42 PM     Remind Me!  Send Private Message   Edit Post
Hmm, can we datalog speed?
Ryan Hertz
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (69.209.93.194) | Report this post to a Moderator
OldHairyBastard
I take bottom on trannies
1/0000
Galant VR-4 org Post #: 469507 posted 04/25/07 03:05 PM     Remind Me!  Send Private Message   Edit Post
The speed wire is the same pin on both USDM & JDM ECU. I have a JDM wiring harness and ECU and it has the same pin for the speed sensor as for the USDM. I have a USDM non turbo cluster and it is not wired the same as the turbo and doesn't have a speed chime but does cut out at 180KMH/115MPH. I'm thinking of placing a switch between the speed sensor wire from the cluster and the ECU so all I have to do is flick the switch for when I want to go over 115MPH and then flick it back when I'm done. I measure the KMH on my AVCR and have changed to 3 different speed sensors and all of them are very jumpy and don't give a very steady reading. I was thinking that is why our cruise controls are so finicky.
Doug
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-202M
2008 Toyota Sequoia 5.7L V8-113M
2013 Toyota Tundra 5.7L V8-88M
2017 VW Passat 1.8L Turbo-23M
Posts: 4497 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (206.82.153.206) | Report this post to a Moderator
keydiver
Unregistered
Galant VR-4 org Post #: 469548 posted 04/25/07 04:19 PM     Remind Me!  Send Private Message   Edit Post
I don't think the cruise control uses the speed sensor, but I'd have to check. I think its just rpm.
Anyway....the speed limiter can also be removed from the chip code if you have an EPROM.
| | | IP: (74.225.111.19) | Report this post to a Moderator
Jorkki
Unregistered
Galant VR-4 org Post #: 469746 posted 04/25/07 10:22 PM     Remind Me!  Send Private Message   Edit Post
Ok, so.. what differents are beetween the ECU and the EPROM? If you have any pics or something documents where i can see and check for my vr4?
Jorkki
Unregistered
Galant VR-4 org Post #: 469816 posted 04/26/07 05:54 AM     Remind Me!  Send Private Message   Edit Post
Please???? photos or something else?
keydiver
Unregistered
Galant VR-4 org Post #: 469820 posted 04/26/07 06:03 AM     Remind Me!  Send Private Message   Edit Post
If you look at the EPROM in your JDM ECU is should have a number on it, like E952 or E769:
http://www.tmo.com/howto/ecu1g/checkeprom.htm
The E952 and E769 code has a speed limiter in it, which is easily defeated by changing one byte.
Jorkki
Unregistered
Galant VR-4 org Post #: 469830 posted 04/26/07 06:20 AM     Remind Me!  Send Private Message   Edit Post
Than you Keydriver! i check that.
Jorkki
Unregistered
Galant VR-4 org Post #: 469831 posted 04/26/07 06:22 AM     Remind Me!  Send Private Message   Edit Post
Sorry, came little mistake... "learning to write" heh.. I mean Keydiver.
Scientist
Secretary of the Interior
Galant VR-4 org Post #: 474125 posted 05/04/07 11:28 AM     Remind Me!  Send Private Message   Edit Post
the other ways is using the APexi Rev Speed Meter or using a SLD from HKS or Greddy
1988 VR4....Needs a lot of TLC
Posts: 530 | From: Roseau/Dominica | Member Since: 01/18/07 | IP: (204.188.166.174) | Report this post to a Moderator
Pages: 1
Extra information
0 registered and 26 anonymous users are browsing this forum.
Galant VR4.org Moderator:  curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, iceman69510, pot, FlyingEagle
Print Thread
Forum Permissions
      You cannot start new topics
      You cannot reply to topics
      HTML is disabled
      UBBCode is enabled
Rating:
Rate this thread
News & Events: News | Events
Community: Members' Showcase
Generated in 0.117 seconds in which 0.09 seconds were spent on a total of 14 queries. Turbo powered.
Hertz's Galant VR-4 Page
